Member postings for Brian Oldford
Here is a list of all the postings Brian Oldford has made in our forums. Click on a thread name to jump to the thread.
Thread: Boxford wiring
07/06/2016 08:26:11
Try the examples shown at https://www.google.co.uk/search?q=dewhurst+drum+switch+wiring&client=firefox-b&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi0ucyZsZXNAhWLC8AKHYTlD3wQ_AUICCgC&biw=1280&bih=895#imgrc=_
Thread: Boiler Marking/serial number
07/06/2016 08:23:02
If you are going to make any indentations into the boiler fabric I would have thought the best place would be on the firebox wrapper along the foundation ring. Just saying.
Thread: Windows 10...more worries so listen...
30/05/2016 16:59:31
All the more reason to consider migration to a Linux distro and Open Source applications. It gives those into programming to keep an eye on what it's internals are doing.
Thread: Timing Belts
30/05/2016 16:55:58
If it happens to be an interference engine I'd not take the risk of a home-brew belt.
Thread: Cutting Metric thread on an Imperial lathe
10/10/2015 08:29:06
Many thanks for all the suggestions. I'm sure the solution is there.
09/10/2015 21:26:00
Not so much a thread but I've been asked to make some single layer coil formers for an amateur radio application using my clunky old S7. To prevent the wire moving I'm proposing to machine a shallow semi-circular groove at a similar pitch to the wire diameter. In this case the insulated wire is 1.3mm O/D. I've got a pretty comprehensive collection of change wheels including a 127 tooth. Accepting I mustn't open the half nuts, can anyone suggest a change wheel set-up to cut that pitch or very slightly coarser..
Thread: Myford Super 7 Reservoir front bearing oiler information
17/08/2015 17:47:30
I'm reassured to discover what I've been doing for years because it just "seemed" right is pretty much the same as others.
Thread: another mystery machine
03/08/2015 22:08:20
It'll never work properly until the laughing shaft is connected to the giggling pin.
Thread: George H Thomas Books
30/07/2015 22:52:32
Posted by Dsel on 30/07/2015 02:39:34:
Has anyone made their own patterns? I'm interested in knowing if they were done separately or as a set and how the risers and in gates were set out.
I haven't yet made patterns for the UPT but I have for the VDH. (I have a spare set of castings here at the moment). Gating should not be anything to worry about. The foundry will sort that out for you, in fact, from personal/professional experience I've found no two foundries work alike.
Edited By Brian Oldford on 30/07/2015 22:53:03
Edited By Brian Oldford on 30/07/2015 22:54:15
Thread: evening star locomotive
12/07/2015 21:20:49
Posted by Nigel Bennett on 11/07/2015 17:01:40:
. . . . . .The frames and horns are not as the full-size 9Fs, which had the horns affixed to the outside face of the frames. . . . . . .
Not strictly correct.The 9Fs along with the other larger BR standards had the frames centred over the horns. A clear example may be seen where the horns can be seen being welded centrally into the frames of Hengist at http://www.72010-hengist.org/hengist-components/frames?start=40
This feature was also common to DoG (71000), the Brits (70XXX) and Clans (72XXX)
Thread: Price of aluminium
01/07/2015 23:23:54
Apologies for highjacking the thread but can someone recommend the best place/price for circa 200 x 3/16" snap head ali rivets?
Thread: Todays update from Bodgers Lodge
30/06/2015 21:41:48
Posted by John Stevenson on 30/06/2015 01:32:28:. . . . . . .
Sorry it's a bit out of focus but you get the gist on how bad a state the pin is in after whacking the bearing out.
Job done and paint unmarked, another pie and a pint.
Edited By John Stevenson on 30/06/2015 01:34:10
Significantly quicker than try to spark it out.
Thread: Cleaning brass plate
28/06/2015 18:00:26
Would a good rub with something like solvol autosol help?
Thread: Fusion 360 - full, free 3D CAD and CAM
22/06/2015 16:37:03
Posted by Russell Eberhardt on 22/06/2015 11:07:50:
Shame Linux isn't supported. Especially when they provide a LinuxCNC post processor. Guess I'll just have to reinstall W7 on my machine as dual boot.
Russell;
Would it be possible to get it to run with WINE?
Thread: Archive of millions of books, available free
16/06/2015 16:23:03
Warning heeded after spending far longer there than I really wanted to. face 5
Thread: Couple of things at Lidl
12/06/2015 22:33:40
Posted by Jeff Dayman on 12/06/2015 21:16:46:
You probably want a D-humidifier rather than a humidifier in the workshop.
I've found the D ones best, the C humidifiers are too small and the E humidifiers are too big. (sorry) JD
Schoolboy snigger,
Thread: The end of an era ?
07/06/2015 10:38:54
It says a lot but just don't get me started on the politics of our UK home railways.
Thread: Fitting Super 7 headstock rear bearings
07/06/2015 10:35:17
Malcolm Martin, Ken?
The reason why I asked one C spanner or two was because I need two (different sizes) for the spindle of my mill.
Thread: Heat shrink tape -how to use
07/06/2015 09:08:17
Posted by frank brown on 07/06/2015 08:47:37:
For self amalg tape, when applying stretch it so it goes to a half of its original width. Lot easier to say then to do!
Frank
By all means stretch it slightly as you apply it but I'd not recommend stretching it that far. It sounds like any advice you received to use it that way was trying to avoid the use of the PVC tape over-wrap to apply pressure.
Thread: What did you do today (2015)
07/06/2015 08:37:07
Continued to make some overly complex brass fittings to go into a GWR Bow-end composite carriage being restored on the SVR.
Edited By Brian Oldford on 07/06/2015 08:40:05
