Silver solder ?
Packmule08/07/2013 10:28:40
133 forum posts
6 photos
Is there any particular reason why parts are silver soldered instead of normal brazing?
Michael Gilligan08/07/2013 10:35:44
23121 forum posts
1360 photos
Silver Solder is available in a range of melting points; all lower than "normal" Brazing temperature.
It is adaptable to very fine work.
It flows very well, and makes neat joints.
< etc >
Some useful notes here
Edited By Michael Gilligan on 08/07/2013 10:39:14
peter walton08/07/2013 11:44:40
84 forum posts
The use of brazing rod on boilers is a no no as it will dezincify over time and could blow up!
I suppose you could use a bronze brazing rod!
Peter
Packmule08/07/2013 13:17:17
133 forum posts
6 photos
Thanks Guys,
knew there must be a reason , dont know ? ask yes
Cheers Bob
peter walton08/07/2013 15:04:22
84 forum posts
Just been in the garage and noticed my pack of 'Sil-Phos' brazing rod, ok for car or gap filling jobs not sure it is of any use for boilers etc but the bees knees on the body work!
peter
Keith Hale09/07/2013 07:49:34
334 forum posts
Why silver solder? Please bear with me !
There are several types of brazing alloy.
nickel brazing alloys - marine
gold brazing alloys - jet engines
palladium brazing alloys - jet engines
copper brazing alloys (includes brass and copper-phosphorus alloys eg silfos)
silver brazing alloys (silver solders)
Brazing defines the metal joining process not the alloy
Copper alloys are the cheapest and very versatile. So there has to be a very good reason to move away from them . That is invariably due to a technical reason. These include melting temperature, parent material combination, corrosion resistance, even colour or a combination.
The success of the process depends on correct joint design, heating technique and fluxing. If these criteria are not met no brazing alloy will work.
Peter, a word of caution. Silfos contains phosphorus. It appears to work well but combines with iron (in all steels) and nickel to create a very brittle intermetallic compound that can lead to catastrophic joint failure when stressed.
Copper phosphorus brazing alloys used to join copper nickel pipes on a submarine is thought to be the reason a submarine did not return from its' test dive.
keith
Keith Hale09/07/2013 08:08:24
334 forum posts
The decision to use brazing as the metal joining process in preference to soldering or welding is based on technical reasons eg parent material combination, temperatures, strength, corrosion resistance.
Brazing defines the process not the alloy used.
There are several sorts of brazing alloy.
Nickel brazing alloys - marine, nuclear applications
gold and palladium brazing alloys - jet engines
copper brazing alloys (eg brass and silfos)
If the basic principles of the process - correct joint design, heating technique and fluxing - are not followed no brazing alloy will not work satisfactorily.
Peter a word of caution re silfos.
It contains phosphorus which will produce very brittle joints on steel and nickel bearing materials. Such a material is thought to be the reason a submarine did not return from its' test dive
Phosphorus does not like hot sulphur containing atmospheres eg boilers. your technical reason for using a silver brazing alloy (silver solder!)
CuP Alloys09/07/2013 08:37:29
45 forum posts
Hi there.
Brazing is a means of joining metal, as applies similarly to soldering and welding. It defines the process not the filler metal.
The decision to braze and the alloy used is decided by technical reasons eg temperatures involved, parent metal combination, strength, corrosion resistance, even colour.
If the basic principles of joint design, heating technique and fluxing are not followed, no brazing alloy will work satisfactorily.
There are several forms of brazing alloys.
Nickel brazing alloys - nuclear and marine applications
Gold and palladium brazing alloys - jet engines
copper brazing alloys (brass and copper phosphorus alloys eg silfos)
silver brazing alloys (silver solder)
The success of all depends on the same principles.
Peter - a word of caution re phosphorus containg alloys. They produce very brittle joints on parent materials containing iron or nickel. Such a material was used to braze copper nickel pipes on an american submarine. It did not return from its test dive.
Phosphorus bearing alloys corrode very quickly in hot sulphur containing atmospheres eg coal fire boilers. One of your technical reasons for using silver brazing alloy (silver solder!)
