Member postings for Brian Wood
Here is a list of all the postings Brian Wood has made in our forums. Click on a thread name to jump to the thread.
Thread: dore westbury mill
24/03/2023 09:28:38
Hello John,
Try HPC gears at Chesterfield, they are a British company, the work is top class and they do mail order. They are not cheap, but you will be buying quality gear that will do all that you want.
If that isn't to your liking, I motored the capstan on my D-W mill with suitable reduction gearing and wrote the work up in MEW 274 and 275. Since then I have moved the head onto my Tom Senior mill and those modifications have become redundant. They include an improved key that engages with the helix in the column, it is now frontal access as a big improvement and part of the lifting modification includes a shop built thrust gearing between the capstan and main support column. A complete ready made system, tried and tested
If that interests you as an alternative send me a PM
Regards Brian
Thread: new to myford lathes
09/03/2023 14:30:12
Colin,
Something odd about the serial number you quote. My Dad bought a new ML4 in 1945; the serial number on that lathe was D 2382. The spindle and 25 T gear fitted to it at the tumbler end were both stamped with the number and other castings etc were also so marked.
The motor drive unit is pure ML4.
Enjoy bringing it back to working order
Regards Brian
Thread: Oddly Built Wall - Can anyone explain why?
07/03/2023 16:15:27
Field walls with random stone are one thing, ornamental walls are usually built with coursed stone
07/03/2023 15:18:50
I have to take issue with you here Jason.
In Yorkshire. dry stone walls are built horizontally, in steps if need be on sloping ground, for the very reasons of stability you mention. The use of the wall doesn't alter whether or not that is the case
Regards Brian
Thread: Disassembling a Pratt 10 inch 3 jaw
05/03/2023 10:10:04
Nick,
Refit three of the rear cap screws at 120 degree intervals around the chuck to get a decent number of thread turns engaged and with a dead blow hammer or regular hammer and a block of timber tap them each in a pattern around the chuck to knock the front part of the chuck away from the rear. Once you have a gap of say 2-3 mm between them you can use a pair of broad bladed screwdrivers on opposite sides to carefully prise the two halves of the chuck apart.
Try lathes.co.uk for a handbook on your lathe, Tony Griffiths has some but maybe not your model. They are not cheap being quality digitally enhanced reprints, but the material is clear, clean and nicely presented.
Regards Brian
Thread: Dead-Blow Hammer Recommendations Please
01/03/2023 11:54:10
Block of wood?
Brian
Thread: Why is there liquid in my Silicone sealant?
27/02/2023 16:12:47
Hello Simon,
Not in my experience and I have been through dozens of tubes over many years, both clear and white.
Throw it away and use a fresh one, there is definitely something odd about it and it may not go off properly either.
Regards Brian
Thread: Why oh Why.
26/02/2023 10:23:03
Have you tried switching off and just restarting?
Brian
Thread: Introduction
20/02/2023 08:45:56
Hello Andrew,
I think it an ML4. the bolting of the headstock and the mounting arrangement for the tailstock being the clues.
I also have a copy of the manual I can send to your email address if you will PM it to me
Kind regards Brian
Thread: Colchester Bantam 127 change gear
17/02/2023 15:04:37
Hello Dan,
These gearings have a special interest for me and the 120/127 combination gear can be approximated to a combination based on 17/18 instead which is very close in result to the pucca version. Thus 85/90 might be a more readily obtainable pair to build into the gear train
Regards Brian
Edited By Brian Wood on 17/02/2023 15:05:05
Thread: Which lathe has 32x1.5mm pitch spindle thread?
14/02/2023 16:01:45
Old Mart,
Surely you have heard of screwing a softwood block into the chuck to take an impression of the thread, so much easier to measure later with decent light etc.
Regards Brian
Thread: Tramming SX3 Mill
13/02/2023 18:27:19
The Dore Westbury is a heavy beast but I found it easiest to slacken the four mounting bolts of the base casting to be able to lean it back and insert a shim. The correction was always to correct forward nod and that avoided the need to lift things
Thread: Finding star point
13/02/2023 15:22:45
Hello John,
I've done this twice, once on an American made motor of 1/2 HP, the second time was on a Chinese 3/4 HP motor, both single phase. I used Jim Cox's excellent WPS book for guidance and got it right both times.
Do be sure you are using high temperature varnish when soaking the windings and binding things up
Best of luck Brian
Thread: new old member
07/02/2023 10:10:01
Hello Paul,
Welcome to the Forum, I'm sure you will find interesting material here and answers to questions you might have. I am another machine tool man, not modelling.
May I recommend early on you check our your Boxford thoroughly to remove all the wood dust, it does nothing for sliding surfaces and dries up all the lubrication
Regards Brian
Thread: NASA & Artemis 1 in MEW324. (On the wire)
25/01/2023 12:39:52
I agree with Peter, there is no relevance whatsoever. How very clumsy of NASA to make that statement
Brian
Thread: "Gearing of Lathes for Screwcutting"
24/01/2023 18:34:00
ega,
A neat idea.
Brian
Thread: Elliot progress drill, help needed
24/01/2023 17:41:35
Michael,
I can't make out much from your photo I'm afraid but if you re talking about the fibre wheel, it is bolted to a flange of some kind with 4 bolts. Maybe if that was released you might get somewhere. I only know this as I made a new fibre gear wheel for another Forum member some months ago, his had ruptured and came to me in three pieces
I hope that helps in some way Brian
Thread: What power supply do I need for this knee power feed project?
22/01/2023 18:01:56
Try a reduced gear ratio, it will reduce the load on the motor on lifting and provide more torque. The downside is of course a slower lift and lowering
Brian
Thread: What is this lathe fixture?
22/01/2023 13:59:42
Carl,
As another Churchill Cub Mk 3 owner I've sent you a PM.
Regards Brian
22/01/2023 10:05:34
Peak 4 has the identification right. There was one with the Cub Mk3 lathe I found in a junk yard 3 years ago. Mine came with two sizes of drive dogs that can be contained within the drum shape but it doesn't have the cut away, a user modification in my view
Regards Brian
