Here is a list of all the postings Ian Parkin has made in our forums. Click on a thread name to jump to the thread.
Thread: Bandsaw speed |
01/05/2019 19:15:55 |
Is it a Inca saw? I use my Inca for cutting non ferrous materials with no adjustments You cant really speed control that motor replace motor with 3 phase or bring the motor off and use pulleys to slow it down if you think you need to |
Thread: joining green laminated belt |
27/04/2019 14:59:59 |
Though if you just clamp your scarfed joints into 2 slices of alloy and hold it at 100 c for 30 mins you should be good to go |
27/04/2019 14:58:57 |
You probably have a habisat belt this the official kit that they recommend. |
Thread: Building a Belt grinder - advice please. |
25/04/2019 13:59:10 |
Peter i went for the 1440 rpm motor so i can run it from 20hz to 100hz Or 570 rpm to 2800 rpm so with my 200mm driving wheel i can go from 361metres/min to 1758 m/m (that’s 100km/hour) Its been very useful so far i have built a mop shaft to take 200mm dia mops or wire wheels taking the drive with a rubber flat belt |
25/04/2019 11:01:36 |
I built a 2x 72 grinder using a 3 phase 2hp motor 1440 rpm driven from VFD so variable speed It can be stalled easier than i thought or rather the over current trip on the vfd trips out I used a pallet truck wheel as the driver so 200mm dia |
Thread: Heavy Machine Removals - any suggestions? |
19/03/2019 10:41:07 |
What sort of cost is prohibitive? i have a lorry with crane sometimes available in those areas |
Thread: Anyone got a hydrogen generator? |
14/03/2019 10:07:00 |
John R it certainly looks well made its like a small welder 30cm x 20 x 20cm and weighs 5 kg empty i’ve only done edge polishing but the flame looks good enough for precision heating of small parts/jewellery etc it runs for about 20 seconds and then switches off on a pressure switch then cycles on/off as you use the produced gas Edited By Ian Parkin on 14/03/2019 10:08:39 |
13/03/2019 15:55:16 |
Well i filled it with my mix of 150g naoh and 1 litre of water and filled the booster with methanol as directions and it certainly works well. as said teh flame is very hot and virtually invisible though it polished some 15mm Perspex edges very well.. How long should i leave the electrolyte in? And if it should be removed can i save it and reuse?
It was only £110 delivered from Belgium by ups Edited By Ian Parkin on 13/03/2019 15:57:26 |
13/03/2019 11:37:50 |
Has anyone got one of these hydrogen generators i bought it for acrylic edge smoothing but seems it can be used for small repairs on jewellery etc it came with some naoh 500grms.the instructions say make up a 15% solution..so that’s 150gr of naoh to 1 litre of water? anyhow does anyone use one and have any operating tips? |
Thread: Myford Lathe on Ebay |
07/03/2019 07:41:55 |
What’s the part between the 2 biscuit tins that looks like it clamps on the bed and has 2 arms with what looks like a offset centre ? |
Thread: Machine cleaning..... |
26/02/2019 12:47:52 |
whilst i cant speak for flash ultra i can recoomend" elbow grease" which is sold in the cheaper outlets at only a £1 for a spray bottle. i buy it in dozens when i need it spray it on brush and wipe it also works well around the house too |
Thread: Rack operated tailstock |
23/02/2019 07:11:21 |
Thread: Telephone / Internet Scams |
18/02/2019 07:59:43 |
I had a call the other day re stopping unwanted calls. the Indian sounding woman was most insistent that I was responsible for the landline bill and I was a homeowner and younger than 85. i responded with well I’m 87 call ended immediately whats the method in only targeting under 85 year Olds? |
Thread: Overload trip |
08/02/2019 21:06:03 |
Remember that the current draw for this motor is only 33mA so even a fuse will struggle to protect that I’d agree that some way of detecting a stoppage would be best |
Thread: What Did You Do Today 2019 |
14/01/2019 21:02:24 |
Iain They made a mistake on the listing for the sets and cancelled the listing relisted now with proper price for the sets |
Thread: depleted batteries |
11/01/2019 09:43:15 |
I saw a video on YouTube about someone with the same problem He discharged them (if not already) then put them in the freezer for 24 hours then let them defrost well then recharge in the normal way Then all was good (apparently) |
Thread: Anyone near loughton essex? |
24/12/2018 11:57:27 |
Is there anyone near Loughton who could pick up an eBay purchase and post it on to me? Ian |
Thread: Wall Storage Recommendation |
22/12/2018 19:32:24 |
Bisley *. multidrawer filing cabinets 15 drawer ones I use I have about 20 of these scattered around you can get them for about £20 upwards depending on condition Ian * other brands available Edited By Ian Parkin on 22/12/2018 19:51:50 |
Thread: Unusual Tool |
02/12/2018 11:26:28 |
looks like a leather cutter you place the shoe on the work press with your palm on the knob and the blade comes down and just goes under the material and cuts as you glide the tool along your cutting line.. does that seem plausible as i’ve Not seen the blade |
Thread: Wooden display base |
20/11/2018 18:45:08 |
If you just want a piece of English or European oak the size that you quoted let me have your address and i’ll Drop a piece in the post for you i can do it rough cut ,planed, or planed sanded and finished |
