clogs | 17/09/2018 17:41:32 |
630 forum posts 12 photos | Having trouble with placing photo's on the forum.....the search box is no help.... have replaced the 3ph starter push button on/off switch on my Colchester lathe.... the photo's would explain better but the main wires are no problem...all wires coded by me before disassembly and the switch box's )old and new) use the same wiring term numbers.....my problem is with the reverse switch......just 1 wire...... not fired it up yet as don't want to burn anything out....... So help with the photo placing would be great help anyway but an offer of private email help would be just the ticket, if there would be someone so kind to help...... I live in the boonies and there is no chance of finding a 440volt electrician even if I wanted........ I'm not completely helpless but just worried........as I say the photo's will explain everything.....it's just I'll have a job to do quite soon.......... thanks for looking.....Cl;ogs
Neil Wyatt | 17/09/2018 18:20:27 |
![]() 19226 forum posts 749 photos 86 articles | Hi Clogs. Click all topics. Choose the top of the list: Website FAQ's Then choose the top of the next list: STICKY: How To Post Pictures and Create Albums Neil |
Neil Wyatt | 17/09/2018 18:22:07 |
![]() 19226 forum posts 749 photos 86 articles | I've added the word 'photographs' to both to make it more obvious. Neil |
Robert Atkinson 2 | 17/09/2018 19:07:56 |
![]() 1891 forum posts 37 photos | To reverse a 3 phase motor you just need to swap two phases of the supply, any two, it doesn't matter which two wires you swap. Robert. |
clogs | 17/09/2018 19:27:51 |
630 forum posts 12 photos | thanks R. Atkinson,,,, actually know that one but the reverse switch is wired thru the DOL.......giving the odd wire... will try tom. to get some photos on the forum..... ta Clogs
john swift 1 | 17/09/2018 20:00:57 |
![]() 318 forum posts 183 photos | Hi Clogs
is this what your looking for https://www.electricalonline4u.com/2018/01/forward-reverse-motor-control-diagram-three-phase.html
John |
Les Jones 1 | 17/09/2018 20:05:56 |
2292 forum posts 159 photos | Hi clogs, EDIT. I've just noticed John's post with the schematic that uses two cantactors, one for forward and one for reverse. Is yours like this or does it have a single contactor plus a reveresing switch ? (As opposed to a forward, a reverse and a stop button.) Les. Edited By Les Jones 1 on 17/09/2018 20:11:49 |
