E.stop wiring
Grant Allen 109/05/2019 10:28:02
48 forum posts
5 photos
Hello I'm looking for guidance on wiring e.stops in to a new electrical, circuit. I have a inkling but just wanted reassurance or putting right.
I've got a kjd17 5 pin with a link on one of the terminals to the 5th pin. Supply in and supply out I get but where the separate link goes from the negative to A1, is this where I run E.Stops from taking the link of and running through every E.Stop and back to the terminal.?
I'm wondering why it's the negative wire I would of thought it would be the live, but I suppose the negative is just the return of live
Andy Carruthers09/05/2019 10:39:26
317 forum posts
23 photos
Hi Grant
Assuming you have fed live through the NC connections of an emergency stop switch (if fitted)
A1 is the "hold on" supply for the No Volt Release
Feed live to pin 23 - when Green button is pressed, without live to A1 the live supply will drop out as soon as the Green button is released
Link pin 24 to A1 taking live to your motor, if mains drops out, the "hold on" drops out rendering the circuit safe
Bikepete09/05/2019 10:46:14
250 forum posts
34 photos
*deleted"
Edited By Bikepete on 09/05/2019 10:46:50
Grant Allen 109/05/2019 10:47:42
48 forum posts
5 photos
So which terminals are live and neutral, this basic wiring is suggesting 13 and 24 are live, and 23 and 24 with a1 coming from the neutral out to the motor is this correct?
With relation to link wire is it this that runs from 24 through each stop button and back to A1 so if the circuit is pressed it cuts at any of the stops ?
Andy Carruthers09/05/2019 11:07:00
317 forum posts
23 photos
john swift 109/05/2019 11:37:32
318 forum posts
183 photos
KJD17 E-stop wiring diagram
Grant Allen 109/05/2019 12:13:38
48 forum posts
5 photos
So I think I got this now,
power IN neutral to 13
Power IN live to 1st E.stop through and onto next E.stop through and back to 23
Power to motor live 24
Power to motor neut 14
And leave the link in place from A1 to 24
Robert Atkinson 209/05/2019 12:37:44
1891 forum posts
37 photos
Posted by Grant Allen 1 on 09/05/2019 12:13:38:
Not quite.
This would run power through all the e-stops. A combination of your scheme and Johns is the best compromise. If you have a E-stop right next to the KDJ 17 wire it in series with the input as you describe. Then wire any additional E-stops between A1 and 24 as John's diagram shows. It's a debatable point but I would swap the live and neutral on Johns diagram so you don't have 240V live with a high current fuse running to all the e-stops.
The problem with Johns circuit is that it relies on the KDJ 17 working properly. If the closest E-stop is wired in series with the supply then if you press the normal stop and it doesn't work you will naturally hit the nearest E-stop which will. The remote E-stops still rely on the KDJ 17 but you generally won't be using them because the normal stop was broken.
Robert G8RPI.
Andy Carruthers09/05/2019 13:05:45
317 forum posts
23 photos
Robert is right
You want to protect the KDJ17 switch by putting the E Stop Switch first, this is shown in the middle of the three pictures, live feed to the left, live output to KDJ17 in bottom picture
Hitting E Stop Switch must prevent all live feed to downstream circuitry
Grant Allen 109/05/2019 13:10:05
48 forum posts
5 photos
So...
Live in to e.stop next to kjd17 then to 13
Neut in to 23
Neut out 24
Live out 14
Extra stop 4ft away neut 24 link through e.stop back to A1 link.
Andy Carruthers09/05/2019 13:33:49
317 forum posts
23 photos
Assumes terminal post numbers are correct from the above information
The "hold on" relay is internally wired to Neutral, just needs a Live supply to A1
Edited By Andy Carruthers on 09/05/2019 13:34:36
Edited By Andy Carruthers on 09/05/2019 13:40:46
Grant Allen 109/05/2019 13:42:13
48 forum posts
5 photos
Doesnt that diagram put the live on the wrong side ?
Andy Carruthers09/05/2019 13:50:08
317 forum posts
23 photos
The diagram reflects the wiring in the photos and correctly represents how the Emergency Stop Switch protects the KJD 17 and Load
Please PM if you think there is an issue, always willing to be educated
Grant Allen 109/05/2019 14:03:27
48 forum posts
5 photos
Following diagram which has been drawn. Any additional stops replace the small ink wire from 24 to A1 yes
Andy Carruthers09/05/2019 14:41:59
317 forum posts
23 photos
I have read your latest comment several times and am struggling to grasp what you mean
If you wire your switches as per photos and wiring schematic your wiring will be functionally correct and provide the best protection
Mike Poole09/05/2019 15:04:27
3676 forum posts
82 photos
The estops should switch the coil of the NVR not the full load current of the motor.
Grant Allen 109/05/2019 15:33:28
48 forum posts
5 photos
Posted by Andy Carruthers on 09/05/2019 14:41:59:
I've wired it up to the diagram provided. The only thing I was trying to say was the extra e.stop that's 4ft away simply replaces the link wire then when pressed it would break the current, or have I got that wrong.
In relation to Mike's comment that's gone straight over my head. Please elaborate
Mike Poole09/05/2019 15:52:39
3676 forum posts
82 photos
In john swift 1s schematic diagram the coil of the NVR is controlled through the estops button and the motor load is switched by the contacts of the NVR. The NVR contacts will be designed to reliably make and break the load current. An estop button is designed to switch the current of a control circuit and is unlikely to break the full current of the motor without being damaged. The coil of the NVR is a very small load and will not damage the contacts of an estop type button. Andys suggestion will put the full load of the motor through the estop contacts which could damage the contacts when operated.
Andy Carruthers09/05/2019 16:19:13
317 forum posts
23 photos
Mike - You are right - on reflection, the E Stop Switch current rating is 12A @250V so unlikely to be damaged with the loads I have
Grant Allen 109/05/2019 16:25:23
48 forum posts
5 photos
Wired up with the e.stop in same box, reading the latest I'm running a .37kw motor so di I need to be concerned ?
I now need to know how to wire up an additional e.stop, going of Robert's advice would I replace the link wire with an e.stp?
