Here is a list of all the postings Saxalby has made in our forums. Click on a thread name to jump to the thread.
Thread: Small part holding |
01/01/2019 11:15:08 |
I made this small parts vice some years ago and is very useful. I believe it is a GH Thomas design and appeared in either ME or MEW magazine. Regards Barry |
Thread: What Did You Do Today 2019 |
01/01/2019 10:44:17 |
Watched the fireworks in Sao Bras (Portugal), with a few glasses of port and then to bed. New years resolution to find my bag of Welsh steaming coal (if her indoors has not burned in on the fire) and get my boiler and Stuart compound steamed up. |
Thread: What did you do Today 2018 |
29/12/2018 15:10:16 |
Bought a pair of ER25 collet blocks a while ago. As useful as they are ER collets don't hold short bits very well. So decided to make a pair of hex and square for my 3C collets. Just used some bit of steel I happened to have in a suitable size. Collets are drawn in by a threaded ring. Also made a 3C step collet out of brass to use for holding some cylinder covers I am making. Made from two pieces of brass brazed together (to save on waste). Barry |
Thread: MS 3mm x 25mm rivets? |
04/08/2018 07:53:33 |
GLR Kennions list 1/8 X 1 inch |
Thread: Left hand threads |
08/03/2018 23:44:31 |
Many moons ago at an auto jumble I bought a box of three 5/16 BSF taps. Wasn't till I got home that I noticed the words "Left Hand' on the box. Never had a need for one, let alone three. If you have a problem getting one let me know and I will pop in the post. Regards Barry |
Thread: Dovetail cutter on brass |
06/02/2018 21:08:21 |
I agree with Neil Wyatt, a light cut climb milling with give a good finish |
Thread: Making BA studs |
30/01/2018 14:33:48 |
Thanks Juddy for the link. They apparently can make to size. So I will see what they charge. |
30/01/2018 14:30:17 |
I wanted to make my own as those I could find ready made were either to long or short. I assume they are able to source material in the correct size.
30/01/2018 14:03:28 |
I need to make a quantity of 4 and 6 BA studs. Does anyone know of a supplier that stocks steel and or brass in 7/64" and 9/64" sizes suitable for studs. To save reducing oversize rod. Regards Saxalby |
Thread: Which collet chuck for a Warco GH1236 lathe |
02/11/2017 13:53:45 |
The good thing with 5C is that you can have a back-stop screwed into the collet for repetition work, they can hold short pieces of work, emergency collets can be machined to a special size and lastly square and hex collets |
Thread: Power feed drilling |
17/09/2017 17:00:00 |
A 6mm 3 flute drill is a real bargain at £34.40 |
Thread: Making a Dickson style QCTP |
08/08/2017 16:10:23 |
I have used a Dickson tool post on my Boxfords for some 30 years and have never had a holder come loose or fail to fit properly. The holders (15) are mixtures those bought from Boxford, auto jumbles and few I have made myself. Those I made myself. I measured a Dickson holder, roughed out on the vertical mill and then finished the "V"s with a 90 deg cutter on the horizontal spindle of the Tom Senior. No problem with fit, just need to measure the "V"s separation and depth as accurately as you can.
Regards Barry |
Thread: Identifying 6" Burnerd Chucks for Myford Lathes. |
08/08/2017 12:07:38 |
While my 4 jaw is on a Boxford. There is no logo just the type number as in your last photo. That I bought in 1986 Regards Barry |
Thread: What sort of parallels are these? |
02/08/2017 21:04:15 |
Agree with john S, made exactly the same as apprentice Edited By Saxalby on 02/08/2017 21:05:57 |
Thread: Expansion LInks |
30/07/2017 17:39:03 |
I agree with Mick H, and have used round die blocks on several models and found they work extremely well. Saxalby
Thread: Boxford shaper |
24/03/2017 12:22:15 |
If you look inside the box table there is an alan screw securing the lead screw nut. Or has that already been removed ?? |
Thread: Acme thread |
31/01/2017 17:35:05 |
My Boxford ME10a is 3/4 inch RH leadscrew. |
Thread: Lathe change wheels |
18/01/2017 17:49:59 |
Here is the cart for cutting metric threads with the 100/127 compound gear |
Thread: boxford bud milling table |
06/01/2017 14:32:44 |
James, This link (www.raynerd.co.uk/cross-slide-toolingmounting-plate-for-boxford) shows how to make a plate to go on the cross slide. Regards Barry
