Scrumpy | 31/01/2017 15:17:01 |
![]() 152 forum posts | help required I wish to make a new half nut for my Boxford Cud Lathe the lead screw is 8 tpi , I have been offered a acme tap of 8 tpi X 5/8 does anybody now what dia the lead screw is as I'm unable to measure mine as I'm away for a few days holiday thanks in anticipation |
Brian Wood | 31/01/2017 15:59:12 |
2742 forum posts 39 photos | It could be 3/4 inch diameter. Best to check before launch I think. |
John Stevenson | 31/01/2017 16:45:35 |
![]() 5068 forum posts 3 photos | Also check whether RH or LH Don't know about Boxfords but Myfords are LH |
Saxalby | 31/01/2017 17:35:05 |
![]() 187 forum posts 33 photos | My Boxford ME10a is 3/4 inch RH leadscrew. |
John Reese | 31/01/2017 17:39:14 |
![]() 1071 forum posts | Years ago I had a large lathe with the half nuts worn out. I made a fixture to hold the half nuts in the correct orientation on the lathe faceplate. I welded up the half nuts with cast iron rod, then annealed them for machinability, remounted them on the fixture and single-pointed the threads. If you single point them you don't have to find a tap. |
