Scrumpy | 18/01/2017 16:49:00 |
![]() 152 forum posts | hi in the cabinet of my Boxford lathe was a full set of change wheels these matched the change wheel plate on the front of the lathe But there were two extras fixed together one with 100 teeth and one with 137 do they belong with this lathe the colour was the same if so we're would I find a screw cutting chart . thanks |
mark smith 20 | 18/01/2017 17:00:17 |
682 forum posts 337 photos | Hi, Are you sure that isnt 100/127 , this is the compound changewheel that allows a good number of metric threads to be cut on an imperial lathe. They are quite expensive to buy for a boxford / southbend / logan lathe. Edited By mark smith 20 on 18/01/2017 17:01:32 |
Saxalby | 18/01/2017 17:49:59 |
![]() 187 forum posts 33 photos | Here is the cart for cutting metric threads with the 100/127 compound gear |
Scrumpy | 18/01/2017 18:54:44 |
![]() 152 forum posts | Hi After counting the teeth it is 127 the reason I got it wrong was on the gear is marked DEH3656-214 followed by G4 -B29 TF2 P29 and 137 which I assumed was the teeth on that gear . How many gears make up a full set as I have 8 plus this double one or should there be more thanks |
mark smith 20 | 18/01/2017 19:45:29 |
682 forum posts 337 photos | All the info is here which is from the lathes.co.uk website. |
Robbo | 18/01/2017 20:01:44 |
1504 forum posts 142 photos | This page from a full copy of "Know Your Lathe" shows the various standard changewheel sets supplied with various machines. Thought the whole thing might be a useful "takeaway" for readers. Your model B will be the first set. Edited By Robbo on 18/01/2017 20:02:52 |
Scrumpy | 18/01/2017 20:56:18 |
![]() 152 forum posts | Thanks for all your help I feel proud to think that the lathe from 1951/2 will soon be back doing what it was intended for and being so complete |
Ajohnw | 19/01/2017 17:44:17 |
3631 forum posts 160 photos | Posted by Saxalby on 18/01/2017 17:49:59:
Here is the cart for cutting metric threads with the 100/127 compound gear That's interesting. I've heard comments in the past that the smallest gear that will mesh with the 100T is 40T so the 56 must mesh with that and the small ones with the 127. Actual 40T may be too small. So if the above chart works it should show the compound as 100 - 127. Thanks. I've just checked one of the values. It does work. 56 stops on the leadscrew gear driiven by the 100 and the other drives the 127. So changing one gear can produce all metric pitches even the ones that are out of the ISO spec. It doesn't work out so nicely with the 100/127 the other way round. John -
Bazyle | 19/01/2017 23:08:55 |
![]() 6956 forum posts 229 photos | The charts given above are for a gearbox type ie model A. Does anyone have it for a model B? I checked my book and it doesn't but I also don't see a lest of the gears supplied as shown above so there must be other versions of the book. |
Robbo | 19/01/2017 23:24:07 |
1504 forum posts 142 photos | Bazyle Is this the one you mean? |
Bazyle | 19/01/2017 23:37:18 |
![]() 6956 forum posts 229 photos | Thanks Robbo. My book has a fig 187 for 3mm leadscrew. Book version is "tenth impression 1981" |
Ajohnw | 19/01/2017 23:51:11 |
3631 forum posts 160 photos | Posted by Bazyle on 19/01/2017 23:08:55:
The charts given above are for a gearbox type ie model A. Does anyone have it for a model B? I checked my book and it doesn't but I also don't see a lest of the gears supplied as shown above so there must be other versions of the book. I can't easily copy them but if you have the parts list off the yahoo group change gears run from 34 to 49 and there is another group including the 100/127 that runs from 213 to 221 but part 217 is a pin. That looks to provide the missing gears. I've only glanced through them quickly but it would make sense to group the extra gears with the 100/127. Maybe the first group provide imperial pitches on a none gearbox lathe.
To be honest I sometimes cut close in TPI and then run a metric chaser over it. So far it's been unusual for me to cut metric as the sizes I've needed can be done with a die. John - |
John Stevenson | 19/01/2017 23:58:23 |
![]() 5068 forum posts 3 photos | Posted by Ajohnw on 19/01/2017 17:44:17:
Especially if it was you that posted it |
Ajohnw | 20/01/2017 16:06:57 |
John -
Robbo | 30/01/2017 12:24:44 |
1504 forum posts 142 photos | Posted by Bazyle on 19/01/2017 23:37:18:
Thanks Robbo. My book has a fig 187 for 3mm leadscrew. Book version is "tenth impression 1981" Sorry Bazyle, forgot to reply earlier My "book" is a bit of a composite. The section that chart came from is different from the usual "Know Your Lathe". Its headed "SCREWCUTTING" "Special Data and Charts" and as well as the two I have reproduced in this thread includes some charts for Hercus Metric/Imperial conversion as well as Boxford charts. |
Bazyle | 30/01/2017 13:16:47 |
![]() 6956 forum posts 229 photos | There must be loads of people with the book who got annoyed at the omission pre web alternative sources. As an aside from Boxford but on general topic I have been looking at the screwcutting plate for the Harrison M300, The great thing about this lathe is that the QCGB cover metric as well as imperial on the selectors - so convenient. Then I read a comment that the M300 either metric or imperial does the other type only approximately though rather well. Initial investigation shows it is rather clever and complex but the largest gear it uses is 50 and none of the usual 63 etc approximations. Anyway those of us without a nice M300 (or the Colchester equivalent) but with a 127 on our plain lathe can be smug that we are cutting more accurate metrics than they are. |
Robbo | 31/01/2017 10:04:56 |
1504 forum posts 142 photos | Bazyle Time for a trip to Specsavers? The 127/100 combi brought to my attention by ebay was £175 plus postage. Still far too much though. |
