Here is a list of all the postings bernard towers has made in our forums. Click on a thread name to jump to the thread.
Thread: Locktite |
24/08/2020 10:10:46 |
If you make your crankshaft a built up version even if you use loctite I would definitely pin it as well which would help if the loctite was ever to breakdown over time. I machined mine from solid and it’s not too difficult the worst bit is the hacksawing ( no bandsaw) Edited By bernard towers on 24/08/2020 10:11:40 Edited By bernard towers on 24/08/2020 10:12:09 |
Thread: Thread identification |
11/08/2020 21:52:35 |
Try wiseman threading tools |
11/08/2020 21:46:54 |
Yes it is a special but they are available from the firm that now owns them (the name escapes me at the moment) it is a company that makes thread rolling heads. From memory the are about a fiver each!. I am surprised that you have only one missing most of the ones I’ve seen only ever have two screws left in them! |
Thread: EN8 |
07/08/2020 20:50:18 |
Instead of using en16 use USACUT55 from acenta steels this is a modern easy machine en16t. |
Thread: What lathe tool for deburring holes? |
02/08/2020 09:28:48 |
Graver everytime |
Thread: Magnetised digital calipers |
25/07/2020 13:10:44 |
Not to my knowledge I demag my mitutoyo fairly regularly |
Thread: Small drill bits, <<1mm |
06/07/2020 15:20:32 |
The only problem with a .3 centre drill is that the .3 tip is very short and fragile why have the problem when there is a solution that’s cheap to make and almost impossible to break, |
06/07/2020 13:48:28 |
Unfortunately the spade tip of even a small center drill is larger than the intended drill which can allow the drill to wander. If you have a piece of 1/8 carbide or hss grind 3 or 4 facets giving a approx angle of 60deg and a sharp point, make a small divot which will be the lead in for the drill. The idea came from a cnc website and they were charging over £40 for just one of these!! |
Thread: internal grooves for o rings |
01/06/2020 18:20:05 |
Not sure what use you are putting your o rings to but I personally have not ever seen an o ring groove with a rounded profile, all the ones I have seen are square bottomed to allow it to deform when fitted and usually they are wider than the ring dia. Not sure if this will help but food for thought |
Thread: DRO error |
23/05/2020 11:40:49 |
I fell into the trap in the early days of my dro but have now got into the habit of adding an extra hole and using an end angle of 360 as Jason suggests which suits most of the work and only requires a little extra thought if starting at a different angle. |
Thread: ER collet adapter |
23/05/2020 11:32:06 |
Just goes to show you get what you pay for even in fasteners. I machine a lot of stainless socket heads for HD’s as in the supplied state the heads can be up to 20 thou eccentric!! It would never have occurred if they had supplied Unbrako’s. |
Thread: Set up tool??? |
20/05/2020 11:54:57 |
Thanks a lot it’s obvious once explained, just couldn’t figure out how to use the pointed rod which was enclosed in the center. Amazing the information out there! |
Thread: Turning oil filled bushes! |
19/05/2020 17:17:30 |
I use oilite blanks and machine them with hss tools that are honed sharp without trouble and ream them successfully. I machine them dry and when finished fill them with lube and pressurise with your fingers on either end and you’re ready to go. |
19/05/2020 17:03:16 |
Edited By bernard towers on 19/05/2020 17:04:13 |
Thread: Painting |
08/04/2020 23:50:59 |
If the parts to be primed are steel why are you using etch primer. Etch primer has been specifically designed for hard to bond materials and steel is not one of them. Much better to use a zinc chromate. |
Thread: What are these for |
08/04/2020 23:34:31 |
Valve guides for ford v8 side valve circa 1940s, they bring back memories! |
Thread: Double ended milling cutters |
09/05/2019 11:28:19 |
I have used double-ended cutters for a few years now in er 11/16/25 collets with no problems. I would think that clarkson type collet chucks would not be of any use as they do not have a through hole which is necessary to get the cutter far enough through the collet to reach the plain shank. |
Thread: 7/8" x 5 tpi acme threaded rod |
07/05/2019 09:26:49 |
Try **LINK** . I have used them in the recent past and were very helpful |
Thread: edm machines |
09/04/2019 10:34:02 |
Thanks for all the info I will get the book from Camden and see what that looks like but after looking at the pics it looks a little bit daunting to a mechanical man with only simple electronic knowledge. Again thanks for all the info.
06/04/2019 21:53:18 |
would like to build a EDM machine but finding information hard to come by. any assistance would be appreciated . |
