Member postings for bernard towers
Here is a list of all the postings bernard towers has made in our forums. Click on a thread name to jump to the thread.
Thread: Wheel Dresser
30/03/2023 22:16:16
Just google wheel dressing star wheels there are several choices
Thread: Tiplap grinder
28/03/2023 23:19:32
For your indexing could you not use a finger a la clarkson?
Thread: Simple case hardening recipe
28/03/2023 23:17:13
Sorry to disagree but it’s called box hardening and brown paper is put in first
Thread: Blueing
28/03/2023 23:15:03
Surely the gunsmiths do browning
28/03/2023 12:12:23
Clockmakers still blue their screws the same way as always by heating the screws whilst laying in a bed of brass swarf ( heated underneath) until they turn blue then quench in oil. Alternatively you can black your parts chemically, just google blackit solution.
Thread: Coventry Die Head
27/03/2023 20:50:13
Usually if its a 1/2' head that's the max size thread dia, although in later years oversize sets were available.
27/03/2023 17:28:38
Best of luck Chris your problems are only just starting, wait till you start collecting die sets,I hate to think how much I spent. Good thing to make for them is the internal stop which is a must when making batches of Bolt/Screws. I have just made a batch of 5mm sq headed bolts and they were threaded at 300rpm and the head clicks off at the came place every time,Magic. Thoroughly recommend the book Rob mentioned.
Edited By bernard towers on 27/03/2023 17:29:30
Thread: State Pensions - Notification thereof.
25/03/2023 11:17:01
Same as Peter not had mine yet, could it be anything to do with alphabetical order?
Thread: Knurling tool
24/03/2023 18:20:26
Just to chuck my pennyworth in it doesn't look as if you have gone deep enough, as your wheels look fairly coarse.
Thread: Parting off using a powered cross feed
24/03/2023 18:14:27
Didn't a lot of capstans use lever feed cut off slides?
Thread: What did you do today? 2023
23/03/2023 21:12:42
10 square headed QCTP holder bolts today for two new toolholders.
Edited By bernard towers on 23/03/2023 21:13:10
Thread: Rear tool post vs front tool post
23/03/2023 15:43:14
I like the idea of the resetable handles Peter.
Thread: Pocket Sundial
23/03/2023 15:40:03
Could be an interesting project, but I am amazed at how they do it for the price ,that is if its made in Austria.
Thread: Milling machine table motor
23/03/2023 10:48:53
My mill uses a redundant wiper motor with home built speed control.
23/03/2023 10:46:42
Taig toolpost dimensions are, front 1” sq and 1” from base to bottom. Of tool slot, tool slot 0.375” wide total height 1.750”. Rear toolpost is 1” sq, 1.236” from base to bottom of slot, 0.375” for slot withe total height of 2.00”. They also do a rear toolpost for parting off which is made from steel (the others from hard anodised aluminium) The parting version is much beefier and has the slot at an angle a la GHT and I find it works very well, I also use a small QCTP on one of my machines
Thread: What are these clips called?
20/03/2023 18:02:37
Could you put your 3mm pin through the hole (just long enough) then slide a collar over the pin?
Thread: Headband magnifier - blessed relief!
20/03/2023 11:49:38
Hi Kiwi Bloke yes I have a set of those, got them from a RAF Tech about 30 years ago. Mine are bakelite and the headband is now replaced with a Halcyon goggles headband, the fore head piece is not covered the bakelite goes straight to your forehead. I do now use an Optivisor and it's difficult to tell the difference in optical quality it's just that the comfort is better with the Optivisor. I do occasionally walk past the building where they were made as I am a Norfolk Boy.
Thread: Warco V Belt Change
17/03/2023 12:03:37
You would have thought that the idler pulley was the one to move but the pulleys all look as if they are in a straight line which means moving the motor, or could it possibly be that at sometime in its history it has had shorter belts fitted?
Thread: Storage Holder for Change Wheels
14/03/2023 18:44:47
I use 20 dip wheels for my hobbling machine and store them in this box small at the front 16t and large at the back 127t , it has a sloping hinged lid to keep them clean. Sorry about the upside down photo.84a30a42-26a6-4c11-83f5-54b46647d65d.jpeg
Thread: Lathe Breakdown - Source for dovetail bolts or nuts?
13/03/2023 21:04:09
Is there any chance you could silver solder the two halves together for now to finish your job then the mill is available to make new ones???
