Member postings for Tony Pratt 1
Here is a list of all the postings Tony Pratt 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Rotary broaching
04/07/2023 17:18:03
I gave up on my rotary broaching because a] I couldn't harden the broach to my satisfaction, b] a lot of axial force is required? and c] I wasn't convinced the cheapo broach holder was any good but I don't recall seeing any mention of a null point??
Tony
02/07/2023 17:39:48
We don’t need to reinvent the wheel, rotary broaching is a proven technique with decent tools.
Tony
02/07/2023 14:55:13
Following with interest as I had a similar problem. Is the broach holder a decent make, mine was a Chinese offering and just didn't work?
Tony
Thread: Clarke Precision Chuck
02/07/2023 12:04:49
Never seen the like but I have heard of Clare collets with Morse taper arbors.
Tony
Thread: Warco GH600 user opinons sought
01/07/2023 17:20:22
When I wanted to upgrade from my Myford super 7 I lusted after all the usual subjects but ended up with a Warco 290V, a pile of c*** in places but once I replaced the rubbish change gears with an electronic leadscrew it's actually hard to beat, accurate and very quiet, the geared head Chinese offerings seem to be noisy??? Just my opinion.
Tony
Thread: material choice
30/06/2023 14:29:09
Posted by Michael Gilligan on 28/06/2023 20:38:12:
Posted by Tony Pratt 1 on 28/06/2023 16:44:47:
Just use mild steel if you can get away with it, back in the day when we didn't buy everything from China vice handles were normally a one piece forging.
Tony
Very interesting, Tony
I am not doubting your word, but I’m intrigued to know how a one-piece forging would be fitted to the vice-screw.
… was it somehow forged in-situ ?
Don’t think I have ever seen one.
Jeez Michael, are we not talking about a milling vice with removable handle, I had it in my head that we were? Recovering from a nasty bout of Covid so not 'with it' atm. Reading the OP yes it looks like a bench vice.
Tony
Edited By Tony Pratt 1 on 30/06/2023 14:30:26
Thread: Mini Lathe Ways Lapping
30/06/2023 12:55:05
Posted by Russell Allsop on 30/06/2023 11:55:51:
Stripped the carriage of my VM210 mini lathe, re-assembled and shimmed the plates holding the carriage onto the ways. The carriage hits a high spot in the center of the ways, would lapping the ways with grinding paste be an option to level the ways to the carriage and is there a specific technique involved?
Many thanks for your advise.
Russell
No
Tony
28/06/2023 16:44:47
Tony
Thread: Machining HSS?
27/06/2023 14:46:02
Cutwel [amongst others] do a range of milling cutters which should cut hardened HSS.
Tony
Thread: Do I need a J drill or what?
24/06/2023 14:20:08
Plastics tend to push away from drills so using a 7mm drill will produce a hole smaller than 7mm. Also agree with AJ about using larger drills in .1mm increments
Tony
Edited By Tony Pratt 1 on 24/06/2023 14:22:54
Thread: #8-32 x 3/8" countersunk any material, 1/4" OK, preferably allen key
08/06/2023 10:08:27
Posted by larry phelan 1 on 08/06/2023 08:47:37:
As the man said, "Buying anything from the UK is now a pain-in-the-arse "
Sad to say,I found the same thing, just not worth the hassle .
To be fair most of the 'stuff' we buy in the UK is from China, India etc etc so just go straight to them.
Tony
Thread: how much
06/06/2023 19:59:52
Can’t see who the original poster is?🤔Anyway maybe £10 each for tool and holder, maybe.
Tony
Edited By Tony Pratt 1 on 06/06/2023 20:01:07
Thread: Collet chuck
05/06/2023 17:28:49
Posted by Ian P on 05/06/2023 17:10:01:
Posted by JasonB on 05/06/2023 16:28:08:
Your register on the backplate can be turned a fraction undersize then with the fixings just nipped up the chuck can be tapped about to get it to run true at which point you can fully tighten the fixings
Its something that always puzzled me that one would take care to machine a register accurately and then not use it as a precise and repeatable locating device.
The only function of a loose fitting spigot and recess is to roughly align the two before getting out the Manchester screwdriver!
I suppose its an acceptable method for something that is not intended to be taken apart.
Ian P
Puzzle no more, the loose spigots are used to gain acceptable concentricity from poorly made affordable tooling most of us use.
Tony
Thread: Bought a new vice
03/06/2023 09:14:29
Posted by Clive Foster on 02/06/2023 19:56:27:
Never cared much for those folding joint handles.
I know the theory is that the swivel joint gives you clearance between the handle and the end of the vice or milling table without the business end being over long. In practice they always seem to be at the wrong angle so a good deal of removal and re-fitting is involved when adjusting and final tightening the vice. Always seem to need two goes at tightening 'cos they are at exactly the wrong angle.
Totally agree!
Tony
Thread: Bending 12mm square mild steel bar
02/06/2023 09:14:32
Posted by modeng2000 on 02/06/2023 09:03:31:
Hopper, I took on board your advice that a silver soldered joint would not be strong enough to withstand the forces involved in cuting especially intermittently. So I made a joint between two bits of 1cm square mild steel bar. Putting one end in the vice and a lever on the other end, I could feel the bar flexing but the joint remained sound. I couldn't apply enough force to break or bend the bar or joint.
So I'm going to continue with my approach in the knowlege that it will produce a strong tool holder.
I on the other hand thought a silver soldered joint would be fine, glad to be proven right
Tony
Thread: Keyless car theft has never been so easy
01/06/2023 17:43:40
Posted by John Doe 2 on 01/06/2023 11:32:15:
Posted by Steviegtr on 01/06/2023 04:07:43: I have never had any problems with someone trying to steal my identity or anything else. Old farts society is unfortunately a falicy. Have an old computer & a duff old phone if you will. But In this modern world you need to get real. I also have the latest software to keep me safe . I use Bitdefender. Stay safe guys & sorry if you think the world is after you, but matbe there not.
Regards from Steviegtr.
How do you deal with emails, when a company wants a scan of your passport, or other personal data, address, bank account number, for example?
Not having a go at all; genuine question. Do you use encryption software or something?
Do people actually intercept emails containing passport details etc??
Tony
Edited By Tony Pratt 1 on 01/06/2023 17:45:27
Thread: Frozen Morse Taper Arbor
30/05/2023 16:47:14
Isn't hitting the draw bar top etc going to ruin the bearings, unless the spindle bottom is carefully supported?
Tony
28/05/2023 12:57:10
Posted by Hopper on 28/05/2023 11:59:40:
LOL, so they are advising the owners of keyless cars to use a steering wheel lock for security. Err, seems to rather defeat the object and be going back to square one 1970s style. How about they just make a key system that works?
Lot to be said for the old hidden toggle switch in the fuel pump circuit. Simple but effective.
This has been happening for years and now we have battery angle grinders a steering lock is no real deterrent.
Tony
Thread: Scams
23/05/2023 18:01:50
All these frauds must be costing someone dear, hold on it's us!!!!!!
Tony
Thread: Boxford VSL 5C Collet nose piece
23/05/2023 17:50:36
As per Clive above or mild steel.
Tony
