Machining HSS?
Vic27/06/2023 14:17:48
3453 forum posts
23 photos
I’ve turned and milled HSS a couple of times using carbide tools. It was slow going but doable. I have another project in mind that requires milling some HSS but I’ve had to order a new milling cutter for the job. I couldn’t help notice that the stated hardness for most of the cutters I looked at is lower than that quoted for HSS!? Have I just been lucky with some of my existing cutters? The items I’ve machined work ok and seem hard so I’m guessing the HSS stock is ok.
old mart27/06/2023 14:33:10
4655 forum posts
304 photos
Most HSS is milled in the softer state, then hardened and ground. Turning is easy with hard HSS if you use a CBN tipped insert, but I don't know of milling inserts with this feature. APT do list endmills rated to 65HRC.
Edited By old mart on 27/06/2023 14:36:25
Andrew Johnston27/06/2023 14:41:25
7061 forum posts
719 photos
It is straightforward to mill hardened HSS with carbide cutters. As shown below; milling an involute form on the end of a HSS toolbit for use in shaping an internal gear:
The question of hardness for a carbide cutter is a moot point, as the cutters are not homogenous. Instead they are made from fine tungsten carbide powder in a metal (usually cobalt) matrix.
Tony Pratt 127/06/2023 14:46:02
2319 forum posts
13 photos
Cutwel [amongst others] do a range of milling cutters which should cut hardened HSS.
Tony
Martin Connelly27/06/2023 16:12:46
2549 forum posts
235 photos
I have turned HSS with CCGT inserts.
Martin C
SillyOldDuffer27/06/2023 16:17:44
10668 forum posts
2415 photos
Posted by Vic on 27/06/2023 14:17:48:
Can you give examples Vic?
Pure Tungsten Carbide is about 30 times harder than HSS, so in theory no contest! Compared with Carbide, HSS is Cheesium. A few possibilities:
  • carbide tooling is often a percentage of Tungsten Carbide powder inside a softer matrix. This reduces hardness in favour of some other desirable property such as strength, elasticity, toughness, sharpness or cheapness etc. (Only a BF buys £££ solid carbide when a cheaper cutter does exactly the same job on soft materials.) Possibly the carbide tooling looked at isn't the hardest possible.
  • Maybe not comparing like with like? There are several different scales and sub-scales: Vickers, Rockwell, Brinell, MOHS etc.
In my experience HSS is no match for carbide, though it tries to put up a fight. Still good stuff: HSS can be ground into different shapes, including very sharp, and I find it less fussy than carbide for getting a good finish on difficult materials.
Vic27/06/2023 22:30:13
3453 forum posts
23 photos
Sorry Dave, I don’t know what you mean by examples? I’ve turned down some HSS rod on my lathe with a carbide insert tool and I’ve also milled a short groove in some HSS flat with a carbide bull nose end mill.
Vic18/07/2023 22:07:05
3453 forum posts
23 photos
I have another project coming up that needs a 6mm hole in some 5mm thick HSS. Will a solid carbide drill bit do the job?
