Here is a list of all the postings Mark P. has made in our forums. Click on a thread name to jump to the thread.
Thread: I’m struggling! |
24/10/2020 17:41:08 |
Hi John, the belts are A750 and A900, that's what fit my Warco VMC. Regards Mark P. |
Thread: Circuit board repair |
15/08/2020 15:15:08 |
Hi Dave, you could probably get a new board from Arc Euro trade. Regards Mark P. |
Thread: The cost of cheap (Free) materials |
22/06/2020 17:03:10 |
Being time rich and monetary poor, I tend to use scrap bin materials. Mark P. |
Thread: Mag Base |
28/02/2020 18:25:48 |
Would it be the same for magnetic chucks? Mark P. |
Thread: Cleaning an old lathe |
15/02/2020 12:18:59 |
If it was mine I would steam clean it. Mark P. |
Thread: Clarke cl 500 |
04/02/2020 19:02:57 |
John, have a look on ebay, loads there and I think that Machine Mart sell motors cheaper than £400. Mark P. |
Thread: Honda Brake Cable |
18/01/2020 18:42:10 |
How about buying a longer similar one and cutting it down? Worked for m Mark P. |
Thread: Win10 |
31/12/2019 15:22:07 |
Thanks, looks like I'm stuck with W10 then. Mark P. |
25/12/2019 10:35:07 |
As an aside, can you downgrade from W10 to W7 on a preinstalled laptop? Happy Christmas to all. Mark P. |
Thread: Rake angle on Cutting Tools.....memory tips??? |
21/11/2019 21:48:31 |
I tend to grind all mine at about 10°, works for me. Mark P. |
Thread: Rod Stewart's Model Railway |
13/11/2019 20:27:34 |
Neil Young has quite a layout too. Mark P. |
Thread: Warco milling machines |
06/08/2019 19:21:30 |
Manny, I started with a WM16 it gave me good service, I traded up to a VMC as it was more to my needs plus I'd moved house and had a bigger workshop. I also have a Warco WM250 lathe they both do all I ask of them. Mark P. |
Thread: Pendulum enquiry |
24/07/2019 23:07:00 |
Don't suppose that it could be based on a metronome? Mark P. |
Thread: Making from castings or scratch build. |
24/07/2019 16:54:50 |
I'm currently building the Muncaster slipper head horizontal engine from scratch but with a piston valve instead of the slide valve. All parts have been machined from steel and cast bar rather than aluminium. The flywheel is a 5'' cast iron trolley wheel. Mark P. |
Thread: Angle grinders - Dangerous or not |
17/07/2019 19:26:24 |
Quite right Dusty, virtually all power tools can be dangerous without common sense. Mark P. |
Thread: Tapping a thread |
06/07/2019 17:25:44 |
Mick, personally I would have thought that a plug tap although not ideal should be ok if you are careful. Mark P.
Thread: Hemswell Cliff, Lincs |
05/07/2019 18:40:26 |
Adrian, every time I've been there's been nowt there. Mark P. |
Thread: Making a Silicone Soldering Brush |
01/06/2019 18:41:46 |
Just seen some silicone nail art brushes on ebay, various sizes and prices. Mark P. Edited By Mark P. on 01/06/2019 18:42:17 |
Thread: Drill bits |
25/05/2019 10:32:47 |
Loads on ebay. Mark P. |
Thread: What do YOU call it? |
22/05/2019 16:25:22 |
I call it bimbling. Mark P.
