Here is a list of all the postings MichaelR has made in our forums. Click on a thread name to jump to the thread.
Thread: Wyvern engine help! | |||||
26/05/2020 16:14:07 | |||||
Jim. My exhaust has no sound deadening just the expansion box, sounds not to bad noise wise. MichaelR
26/05/2020 09:02:06 | |||||
Jim. You can do your own thing with the exhaust on the Wyvern, my version shown in the picture, I used a Hall sensor for my ignition by Minimag Link , however you can use points and coil ignition. I run my Wyvern on petrol, you can use propane but I am not up on that method but it would be worth looking into. Hope this helps. MichaelR.
Thread: STEAM ENGINE VALVE LEAKS | |||||
19/05/2020 15:42:52 | |||||
Have you got a little bit of float on your slide valve buckle ? which will allow the steam/air pressure to seal the valve to the port face. MichaelR. | |||||
Thread: Silver soldering boiler | |||||
12/05/2020 16:48:12 | |||||
David, You have made a nice job on your boiler very neat, just one point you really need your pressure gauge on a "U" Bend syphon to form a water slug which protects the gauge from damage by direct steam pressure, although you may know this already. MichaelR | |||||
Thread: Fixing a ball to a govenor arm | |||||
11/05/2020 11:59:09 | |||||
Henry, I used ball bearings for my traction engine governor, I softened the balls by heating them to red heat then drilled the balls for the governor arms and fixed the balls to the arms with Loctite. MichaelR Edited By MichaelR on 11/05/2020 12:00:00 | |||||
Thread: masks and metal band around nose | |||||
08/05/2020 15:22:38 | |||||
Some Ideas here Link , nose piece materials for home made masks. MichaelR | |||||
Thread: Whatever happened to... | |||||
21/04/2020 14:47:20 | |||||
A lot of years ago I had a taste for these, a tin didn't last long. | |||||
Thread: Myford 254 Electrics | |||||
11/04/2020 14:22:27 | |||||
On the bottom left hand side of the cover there is a socket head screw you can't see the screw with the guard closed, remove the screw and the cover hinges upwards from the front. | |||||
Thread: Part built Allchin 1.5 inch | |||||
10/04/2020 20:00:53 | |||||
Posted by derek blake on 10/04/2020 19:46:08:
Hi Micheal Do you mean the tips of the lever should be deep inside the poppets and not slightly balanced on top? should I drill down into the poppets so they sit inside. Thanks for the help Yes the tips should be drilled into the poppets so that they are slightly below the valve seating (As in the drawing above) if they are just balanced on top the lever can flop about. Michaelr
10/04/2020 19:19:01 | |||||
To work correctly the ends of the pivot pins on the lever arm should locate slightly below the valve seating, and the valve seating face not too wide, MichaelR Edited By MichaelR on 10/04/2020 19:28:26 | |||||
Thread: Paint for an Traction engine | |||||
08/04/2020 18:59:39 | |||||
Steve The paint was applied direct onto steel after cleaning bright with abrasive cloth. Link for application instructions. MichaelR | |||||
08/04/2020 14:31:34 | |||||
I used Black Friar High Heat Resistant Matt Black paint on my D&NY smoke box which is good for 600C, the paint has stood up well over many years of steaming. MichaelR. | |||||
Thread: CLASSIFIEDS & CORONAVIRUS | |||||
01/04/2020 09:21:09 | |||||
Just deleted my Add with no problem, used the delete button in manage my adds. MichaelR | |||||
Thread: Tool info | |||||
13/03/2020 18:29:14 | |||||
Posted by Alan Waddington 2 on 13/03/2020 18:10:38:
It’s an olive cutter for removing olives from copper pipe I'll second that. Here | |||||
10/03/2020 19:27:43 | |||||
Are your bearings the spilt type ? if so you will be able to take up that very slight play, another area that can cause a knock is the cross head pin bearing, my D&NY engine always had a knock in that area until I fitted a lubricator as photo. | |||||
Thread: MYFORD 254 LATHE TECHNICAL QUESTION | |||||
05/03/2020 22:17:54 | |||||
Posted by duncan webster on 05/03/2020 21:43:25:
Just had a close look, mine has a slot right across which could be used to tighten it up perhaps? Page 22 of the manual refers, but nothing about adjusting it. Does your manual mention it Michael?
Duncan, My manual doesn't mention anything about feed shaft clutch adjustment, The tool list for the lathe includes a Slotted nut spanner (Feed shaft adjusting) which came with my lathe. MikeR
05/03/2020 20:10:56 | |||||
On my 254s the clutch is at the same position as on Duncan's lathe, but mine is adjustable it has a "C" spanner that has two lugs that engage in slots in the clutch and was supplied with the lathe when I bought the Lathe from Myfords. MikeR | |||||
Thread: DVLA Scam | |||||
28/02/2020 14:58:46 | |||||
I got side tracked to that site when taxing my car, then realising after signing up that it was nothing to do with the DVLA, I returned to the site and found that I could cancel if done within a certain time which I did. (You don't get the 50P back) but you get conformation that your account is closed.
Edited By MichaelR on 28/02/2020 15:00:01 | |||||
Thread: Where's the spindle lock? | |||||
20/02/2020 19:23:31 | |||||
Edited By MichaelR on 20/02/2020 19:24:54 Edited By MichaelR on 20/02/2020 19:26:35 | |||||
Thread: Why? | |||||
18/02/2020 15:47:54 | |||||
