QUESTION FOR EXPERTS
ray jones 1 | 05/03/2020 19:07:48 |
54 forum posts 29 photos | HI , Can anyone advise me please On the Myford 254 lathe (any variant) Feed shaft from the multi speed gearbox to the saddle / apron.. When using Power feed or cross feed, as a safety measure, is the drive protected by a shear pin or adjustable slip type clutch? On some Lathes such as the Myford 280, there is a user adjustable slip clutch built into the saddle. so it acts as a safety measure , or if you are using a bed stop will trip out when the saddle reaches the bed stop.. I have checked the manual and can't find a reference to it. Appreciate the advice , thank hyou
duncan webster | 05/03/2020 19:40:22 |
5307 forum posts 83 photos | On mine there is a clutch at the left hand end of the hexagonal shaft. I don't think it is adjustable. Page 41 of manual item 27 refers. I've never had the nerve to just drive the saddle into a dead stop, but I think that is the idea. It wouldn't work using leadscrew Edited By duncan webster on 05/03/2020 19:41:21 |
ray jones 1 | 05/03/2020 19:52:01 |
54 forum posts 29 photos | Hi Duncan , thank you will check my manual again . Agree we are talking feed shaft only .kind regards ray |
MichaelR | 05/03/2020 20:10:56 |
![]() 528 forum posts 79 photos | On my 254s the clutch is at the same position as on Duncan's lathe, but mine is adjustable it has a "C" spanner that has two lugs that engage in slots in the clutch and was supplied with the lathe when I bought the Lathe from Myfords. MikeR |
duncan webster | 05/03/2020 21:43:25 |
5307 forum posts 83 photos | Just had a close look, mine has a slot right across which could be used to tighten it up perhaps? Page 22 of the manual refers, but nothing about adjusting it. Does your manual mention it Michael? |
lfoggy | 05/03/2020 22:05:37 |
![]() 231 forum posts 5 photos | There is definitely a clutch on feed shaft which can be used when turning to a dead stop. Works well. |
MichaelR | 05/03/2020 22:17:54 |
![]() 528 forum posts 79 photos | Posted by duncan webster on 05/03/2020 21:43:25:
Duncan, My manual doesn't mention anything about feed shaft clutch adjustment, The tool list for the lathe includes a Slotted nut spanner (Feed shaft adjusting) which came with my lathe. MikeR
