Here is a list of all the postings John Burridge has made in our forums. Click on a thread name to jump to the thread.
Thread: availability of Abrafile saw blades |
15/05/2012 07:24:31 |
Thank you all both on this site and www.homeworkshop.org.uk site which i also posted a request |
Thread: Drawings for the Eureka relieving attachment for hobs |
15/05/2012 07:22:22 |
I have found the picture of the Charles Lessie's hob relieving attachment on one of the Yahoo groups sites no drawings but lots of pictures which i can scale off and the latest version of his device and adaption fron the one found in the gears and gear cutting by Ivan Law in the special intrests book range. Links to the pictures of his first design http://groups.yahoo.com/group/mwmills2/photos/album/2052598602/pic/list charles improvments for ease of use http://groups.yahoo.com/group/mwmills2/photos/album/1286132389/pic/list This maybe of use for other making and relieving hobs
13/05/2012 17:14:08 |
I wonder has anyone either made or got some drawings of the Eureka gear cutter relieving attachment that Charles Lessie made for relieving hobs which is on youtube. It seems to work very well all i need is how much it has been extended from the original Ivan Law/Prof Chaddock version. http://www.youtube.com/watch?v=kJ8kyC_bpHs link to the attachment being used. |
Thread: Where to buy ground stainless round. |
13/05/2012 10:26:56 |
Jonathan, I see that AJ Reeves still stock Stainless steel in imperial size i dont know if they sell metric,might be worth a try. If you need to heat treat for the engine part as Jason said it may pay to use one of the usall steels the old EN8 or EN32 if you want to case harden or EN24 or EN32 if you need to through harden I am not sure if the stainless steels will either case or through harden i use 440C or 17-4PH which will harden without to much difficulty. |
Thread: Lever Feed Tailstock |
12/05/2012 13:33:02 |
I wonder has anyone wrote up an tatical on a making a capstan feed tailstock for the Raglan range of lathes and what you would need to do to convert a standard tailstock |
12/05/2012 13:29:08 |
Thank you all for the reply. I was today using the abrafile to cut out a electric panel on one of our test rigs at work,I could of cut a hole big enough and then split a band saw blade and re--welded it, i could also of used the flypress and cut out as near as possible to the shape that i required. I have pad saws and peicing saws of differing shapes and sizes but i find that the abrafile because you can change direction because it has cutting teeth all around the saw is most usefull. I have considered buying a fret saw but for the amount of times i think i would use it outways the expence,but as they say if you had it i would proberly use it more. One of the people from work who makes clocks says his dad uses a simiar saw in france sold under a nother name, as with my father he used to refer to them as Davis files by the old inventor until another firm started to make them calling them Abrafile. |
11/05/2012 22:56:34 |
does anyone know where you can buy or does anyone have Abrafile saw blades they would like to sell. I can not find any either in catalogues or off the net except the tunsten carbide type that you use for tiles. |
Thread: Antique Denbigh Horizontal Mill |
14/04/2012 20:58:22 |
I think that John Ward who make lots of bits for old and obsolete lathes and mills uses one of these machines which he has converted for gear cutting he maybe able to help you out for information. John's contact details are www.latheparts.co.uk and phone number is 01282-869262 Hopefully this can help you out Regards John Burridge |
Thread: Manual for Realm-Royal 10" shaper |
14/04/2012 20:50:50 |
Please does anyone have a manual for either the Realm-Royal 10"shaper or the Viceroy 250 shaper which is the very simalar machine. |
Thread: spline shaft cutters |
14/04/2012 20:47:05 |
Hi to all, Does anyone know where you can get hold of spline cutter simalar to involute type cutter as i need one to make a batch of replacement leadscrews on a M300 Harrison lathe cross slide leadscrew. I could grind up a single point tool and flycut them but a multitooth cutter would makes things easier. Do anyone know of a secondhand tool dealer who might have them in stock at a reasonable price. Alternatively i could make a multitooth cutter and form relieve it and heat treat afterwards. Regards John Burridge |
Thread: plan for Stuart Turners swan marine engine(5A x 2) |
15/02/2011 21:05:45 |
does anyone have the drawings of the ST swan engine |
Thread: Collets for Raglan lathe |
13/02/2011 09:44:19 |
Hi Ian, The normal collets that Raglan used for their lathes used to be of the 4C type. If you would like to find some suitable collets for your lathe you might try the Raglan Machine Tool web site which is http://groups.yahoo.com/groups/RaglanMachineTools Quite a few of the members have additional spare and there other information for other accessories and spares both new and used. Regards John Burridge |
Thread: Spindle for Raglan lathe |
20/11/2010 14:46:24 |
ai run the Raglan Machine Tool web site on the Yahoo group web site,I am not sure but i may have a spare spindle for the Raglan lathes,both the Little John's and the Raglan 5 inch uses the same spindle. You could also post a request for a spare spindle there are quite a few members that have spares that maybe another port of call. How are you checking for the spindle run out ? yours for now John Burridge P.S. the website address is http://groups.yahoo.com/group/RaglanMachineTools/ |
Thread: Casting of full size engines |
23/05/2009 14:35:04 |
Are there any steam boat owners/constructors which make their own patterns and casting in or around Oxfordshire.
I am also would like to know of any model engineer who do their castings at home who would like to do some castings for me of my own designs of patterns.
