Member postings for ian j
Here is a list of all the postings ian j has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford super 7 tailstock thread
10/01/2023 16:39:33
p1100829.jpgp1100828.jpgscan.jpg 2.jpgDavid/Noel
Here is a drawing showing the basic dimensions. Any more questions just ask.
If you right click on the image and select open in a new tab they are a lot clearer.
Ian
Edited By ian j on 10/01/2023 16:40:51
Edited By ian j on 10/01/2023 16:45:02
Thread: Stepper Motor microstepping
01/01/2023 17:10:54
Posted by John Haine on 01/01/2023 13:46:26:
Ian, I would suggest that you actually try both modes and Mode A may give better performance. And you may be better off using a higher microstep ratio anyway, depending on how fast you want to run.
ok John Mode A it is.
01/01/2023 13:15:48
Thanks to all for your replies. All very interesting and useful information. I think I will use mode B, it's to drive a 4" rotary table and the extra torque will be good.
Happy New Year.
Ian
31/12/2022 23:50:30
Hi John.
As an example a DM 556
DM556 stepper driver
31/12/2022 22:34:59
Looking at various stepper motor drivers, the dip switch settings on some for micro stepping have 1 (200 steps), 2A (400 steps) , 2B (400 steps) etc Can some one tell me what the difference is between 2A and 2B micro steps.
Ian
Thread: Rod's Hoglet
29/09/2022 13:43:38
Hi Graham.
Yes I used the Cox method. But like you I thought Andrews method was back to front. What I did was to prepare the cam blank and drill it 1/4" then loctite it onto 1/4" bar long enough to hold it in the collet chuck (so in effect you are holding it by the short end) Then I machined it as in Andrews video and when done re positioned the 1/4" bar so the long end was on top. ( I may have turned the machined cam around as well) But it ended up looking like the end view drawing. Must be honest it turned my brain to mush, it took two attempts to hopefully get it correct. Just thinking about it again and looking at my trial run one I made out of Ali, you could just make the short end longer to hold in the collet machine the cams as Andrews video and then cut the collet end to length (becomes the short end. ) I think I did it my way because to keep the total length as short as possible. Also looking at my trial one there was no need to turn the cam around.
Hope this helps.
Ian
Edited By ian j on 29/09/2022 14:05:15
28/09/2022 09:26:48
Rod.
I started building my engine after seeing your first post. My cam looks very much like yours, so hopefully we are both correct! My progress upto now; Have you and Graham given any thought to ignition and carb.
Ian
Thread: Norden mill engine
24/07/2022 08:59:54
Posted by Neil Wyatt on 03/09/2019 15:32:04:
Yes, I'm afraid the legs are too long high - they are angled at 8 degrees.
They are about 4 3/16" high so should be made 7 1/4" long, I have no idea why the plan give the wrong dimension as it was auto dimensioned and is drawn the right size.
Sorry about this - the best solution is probably extending the connecting rod by, say 3/8".
I'm surprised this hasn't been noticed before although only a few appear to have been built.
I'll change the plans.
Neil. I think you forgot to amend the leg length on the drawing as I have fallen foul to this error. You suggest making the con rod longer, would just making the piston rod longer be the answer?
Ian
Thread: Machinist level
17/03/2022 17:23:17
Steve.
If you search for Starrett levels I'm sure you will find a suitable replacement, I did. It was not stocked in the UK but my local Starrett agent (Lawton Eng. supplies ) ordered me one from the US. I think starrett have a minimum order of £50 so Lawton's waited until they were placing an order of other parts. If I remember correctly it was around the £14 mark, took about four weeks to arrive..
Ian
Thread: MyFord S7 Carriage Screw
22/12/2021 21:40:23
Posted by Franco Convertini on 22/12/2021 10:14:30:
Evviva, ci sono riuscito. Ecco le foto con screw. Ho in mente di realizzare un stop carriage come questo. hemingway site
Edited By Franco Convertini on 22/12/2021 10:20:26
Edited By Franco Convertini on 22/12/2021 10:21:18
Translation " Hurray, I did it.Here are the photos with screw.I plan to make a stop carriage like this "
Edited By ian j on 22/12/2021 21:43:42
Edited By ian j on 22/12/2021 21:47:26
Thread: ME magazines and early bound volumes
14/10/2021 08:25:11
Mick. I've sent you a message.
Ian
Thread: Hardinge HLV H
30/09/2021 08:46:41
From Lathes.co.uk site
"HLV-H (US production):
1960…..0100 1961…..0210 1962…..0554 1963…..1042 1964…..1540 1965…..1905
1966…..2345 1967…..2864 1968…..3327 1969 to 1971 ……? 1972…..5014-K
HLV (UK production - the only data ever discovered)
1955…..Serial Number 0207 to 1958….. Serial Number 0442."
Thread: Myford super 7 with gearbox - leadscrew stopped turning
24/08/2021 20:04:30
As Philip . R suggests, I'm guessing the three position ( A, B or C ) lever on the top of the gearbox is between positions ie not engaged The Myford manual says this can be engaged (gently) with the lathe running. Or it could also be that the sliding selector lever on the front of the gearbox is not fully latched down (lathe should be stopped before moving this lever)
Thread: Replacing a myford ml10 lathe chuck
14/06/2021 19:40:32
Hi again Jeremy. Photo of the jaws fitted to my 3 jaw chuck (same catalogue number as yours.) but Canada!!p6140625.jpg
14/06/2021 18:57:24
Hi Jeremy.
I have a set of OUTSIDE JAWS for sale listed in the classifieds on this site which will fit your Prat Bernerd 1588-10130 3 jaw chuck. Note these are OUTSIDE JAWS but will allow you to still use your chuck.
ian
Thread: Work Shop Talk - Cleaning Sanding Belts & Sanding Discs Easily
25/03/2021 10:36:45
I'm sure I read years ago that a piece of plastic hose pipe could be used for cleaning belt sander belts.Not tried it my self as I have one of those "sticks"
Thread: Mad Modder site not secure?
10/03/2021 12:59:03
I had the same warning when logging in the other day. But the problem has now been fixed.
Thread: Myford super 7 mk1 clutch
01/03/2021 18:09:23
Roger.
Here is some information.
Thread: Myford Between Centres Boring Bar
25/02/2021 23:03:43
Photo from Myford's Ebay listing.
25/02/2021 22:38:38
Hi Simon.
It's a bit primitive really. The tool bit goes in one hole and is secured by a piece 1/4" diam bar with a flat tapering to the end on one side. Not sure if I have described it very clearly, if not I can take a photo of mine tomorrow.
