Myford super 7 mk1 clutch
Roger Moore 201/03/2021 14:33:55
1 forum posts
I have an early Super7 with the expanding clutch piece inside the pulley cluster. However the grub screws, adjuster nuts and parts that locate the handle onto the shaft end bearing are missing. Is there a diagram and parts description available. I can probably make the parts if a drawing or spec is available. Clutch otherwise seems ok if you manually move the rod to lock the clutch.
Brian Wood01/03/2021 17:34:02
2742 forum posts
39 photos
Hello Roger,
I have the Myford drawings which I would be happy to send you by email.
Some pesky compatability problem prevents me from posting this material on here
PM me with your email address please so that I can send it to you
Regards Brian
ian j01/03/2021 18:09:23
337 forum posts
371 photos
Roger.
Here is some information.
