Matt Harrington | 29/11/2022 15:22:40 |
![]() 212 forum posts 16 photos | Having delved into ELS and been happy with the functionality, I'm now left with wanting more!! Has anyone fitted a stepper to the rear of an S7 cross slide? I'm interested to see how neat I can make it. I would also like to add an engage/disengage mechanism for the stepper (although the new ELS system can be set to switch off the stepper motor) Any thoughts most welcome. Matt |
John P | 29/11/2022 16:29:35 |
451 forum posts 268 photos |
I converted my Myford about 17 years ago the stepper motor is |
John Haine | 29/11/2022 16:31:53 |
5563 forum posts 322 photos | Matt, you are teetering on the brink of a slippery slope! I think (can't quite recall as it's years since mine was removed) the problem is that the standard screw doesn't reach the back of the slide casting so would need an extension which is a bit fiddly. Easier to drive from the front end. If you were replacing the screw with something longer you might fit a ball screw to get rid of most of the backlash as well as being easier to drive. A non-PXF S7 can only accomodate (I think) an 8mm ballscrew, mainly because of the diameter of the nut which won't fit the "tunnel". Those are available but expensive compared to larger sizes like 12 or 16mm, and need a bearing at the back as well. This is the approach taken by cncyourmyford. I use a 12mm screw but in a PXF machine which has a much larger tunnel, and I have the nut "turned round" so the parallel section that normally locates in a bored hole projects out. I drive it direct from a NEMA stepper with an Oldham coupling. As you see I've fabricated a new bracket. Once you have a stepper on the cross slide you'll need to be careful not to slide down the full CNC rabbit hole, though I can tell you that it's very nice once you're in! |
Matt Harrington | 30/11/2022 09:59:58 |
![]() 212 forum posts 16 photos | Thanks for the photos. John P, I notice you still have a handwheel on the cross slide - is it OK to use when the motor power is off? I still like the idea for a manual operation for very quick jobs. Yours looks a neat solution. John H, Ha! I've been down quite a few slippery slopes with CNC. I have been considering 12mm ball screws as I have a spare cross slide to play with. I still fancy the idea of the stepper at the back of the cross slide for those manual jobs. I have on order a Rocketronics ELS System on order and this will retrofit my exsiting ELS - just on the z axis initially whilst I look at options for the cross slide. Matt |
Ronald Morrison | 30/11/2022 11:39:58 |
98 forum posts 4 photos | If a stepper motor has power applied it acts as a brake. With power disconnected is turns freely but...it then acts as a generator so it can backfeed any electronics attached to it. Turn it slowly and there is no problem, spin it fast and it can provide too much voltage for the electronics and burn them out. |
duncan webster | 30/11/2022 14:18:55 |
5307 forum posts 83 photos | Posted by Ronald Morrison on 30/11/2022 11:39:58:
If a stepper motor has power applied it acts as a brake. With power disconnected is turns freely but...it then acts as a generator so it can backfeed any electronics attached to it. Turn it slowly and there is no problem, spin it fast and it can provide too much voltage for the electronics and burn them out. I turn mine quite quickly, never had a problem |
John P | 30/11/2022 16:32:42 |
451 forum posts 268 photos | Here are some better photo's ,the rear bracket is just fixed with 2 screws ,originally John |
Matt Harrington | 30/11/2022 16:55:54 |
![]() 212 forum posts 16 photos | Thanks John, that gives me a clearer picture. The Rocketronics system has a button to power off an individual axis. I shall see how that works when fitted. I'll probably stick with the standard screw for the moment but ball screw maybe a future upgrade. Matt |
Matt Harrington | 30/11/2022 17:11:07 |
![]() 212 forum posts 16 photos | Any thoughts on the power required for the cross-slide stepper - not much I suspect? Matt |
John P | 01/12/2022 10:20:10 |
If you decide to modify your machine in this way and have a rear As far as i can remember the crosslide stepper motor came from |
John Haine | 01/12/2022 10:27:41 |
5563 forum posts 322 photos | Posted by Matt Harrington on 30/11/2022 17:11:07:
Any thoughts on the power required for the cross-slide stepper - not much I suspect? Matt Mine is driven directly by a NEMA 23 motor probably running at about 1.5 amps 40v. It is a ballscrew so a conventional screw may need more - originally I used an ordinary screw in a bronze nut and had a 2:1 pulley reduction. |
Mike Poole | 01/12/2022 12:10:29 |
![]() 3676 forum posts 82 photos | A ball screw will require to be connected to something to restrict free rotation. If a stepper is intended to be always connected then that should be ok but if a manual only handwheel operation is provided then the cutting loads could move the slide. Mike |
Matt Harrington | 01/12/2022 13:21:08 |
![]() 212 forum posts 16 photos | Yes, I agree Mike. Let me experiment first and then I'll see which direction I go in. John, Thanks for that - a starting point for me..... Matt |
John Haine | 01/12/2022 13:41:54 |
5563 forum posts 322 photos | Just another data point. As the lathe was switched off I tried leaning on the cross slide, it didn't move. Then as an experiment I loosened one side of the motor coupling and leaned again, and it still didn't move. There isn't a lot of friction in the bearing, it has 2 ball thrust races either side and a needle roller in the bracket, but clearly enough to resist the screw rotating under at least some load. |
Matt Harrington | 02/12/2022 13:21:58 |
![]() 212 forum posts 16 photos | I found this article and it looks to be along the right lines for my install - at least for my cross slide. I already have the Z stepper installed as is the encoder. Matt |
Matt Harrington | 05/04/2023 09:20:39 |
![]() 212 forum posts 16 photos | Well, the warmer weather has allowed me to carry on with the ELS project. One point to note - if you choose the Rocketroincs system the software for the PRO4 version is not the same as the BASIC system. The basic has a facility for threading if you only have the Z axis motorised. (auto pauses for retracting and feed in) The PRO version does not. (although the website at the time claimed the software was identical)!! Anyway, on with the update. This photo shows the general layout. (I'm using the standard screw for the moment) This shot compares the standard cross slide 'v' the modified. The next shot is the underneath. The bracket needs a little work here. Initially to give a little space for the screw. I will 'hog' out the underneath as well should I need extra travel for the dovetail. (I can't remember ever having to use the cross slide so far forward. The screw was extended using 10mm rod - this cleared the leadscrew nut. It has been dowelled and will be loctited into place. Whether it needs pinning, we will see later. I will probably turn the stepper adapter around to reveal the oldham coupling and allow me to easily unclamp when assembling. Still a bit to go but it gives you an idea..... |
Alan Jackson | 05/04/2023 10:18:58 |
![]() 276 forum posts 149 photos | You could do it this way and used an eccentric to engage or disengage the stepper motor from the feedscrew. It will also enable about a 10:1 reduction gear ratio. My one is geared down 10:1 Alan |
Matt Harrington | 05/04/2023 10:42:37 |
![]() 212 forum posts 16 photos | The idea of an eccentric lever is an elegant one. Once my 'proof of concept' is working, I think that setup in place of the coupling would be a decent upgrade. Matt |
Dell | 14/04/2023 18:26:17 |
![]() 230 forum posts 44 photos | I have been reading this post with interest, due to the problem I have with my hand and getting worse and eyes not as good as they used to be , I have bitten the bullet and ordered the full kit from Rocketronics, I ordered some pulley’s from makers hut and what a load of rubbish they are serves me right for cutting costs so they are going back, I have now ordered some from gear & sprockets, although the kit hasn’t arrived yet ( but cleared customs ) I can’t do to much but I have worked out where to fit the Z stepper and pre made the bracket and yes I did make a mistake and drilled the holes in wrong place but it’s only a mounting plate and the plate is fixed using the 2 bolts that bolt the motor mount so no hole drilling , I am also fairly sure I can mount the encoder where the change wheels were ( fingers crossed) I will start a new post when I get going properly. Dell |
Matt Harrington | 25/04/2023 18:11:49 |
![]() 212 forum posts 16 photos | Dell, I'm sure you can get the encoder to fit within the gear cover on an ML10. I will photo the arrangement for a non gearbox S7 machine and a gearbox one for reference. The encoders have such little resistance to turning that thin bracketry is only required. Matt
