Member postings for Steviegtr
Here is a list of all the postings Steviegtr has made in our forums. Click on a thread name to jump to the thread.
Thread: Making Rings
21/01/2020 18:52:35
Posted by Neil Wyatt on 21/01/2020 16:25:32:
Posted by Steviegtr on 20/01/2020 22:53:46:
Forgot to say I am looking for a parallel Knurl for the lathe to recreate the edge of the coin. It will have to be very fine though & only a single wheel one. If anyone knows of a supplier. All the ones I have seen are much too coarse. Also need to make some stepped arbours so I can install in the chuck of the lathe to work on the outside of the rings without damaging them.
Steve.
People have used flint wheels from lighters in the past.
Any pictures of the ring forming process?
I have not taken any pictures yet as have been busy with setting up the lathe. The picture above the Morgan dollar's is a1948 half crown annealed & after the 1st push. I stopped at that because I was using a balling dome & ball. It started to mark the print. I now have some tapered stainless cones of various sizes & just got some Acetal to make tapered & parallel pushers. I also had trouble keeping the coin central whilst pressing the hole out. Had an idea after watching the American's do it. So looking to get a 2" pipe threaded coupling & a 2" cast blank plug. To make my own. Plus some cast reducers from 2" down to what I think will work. Coins you can wear on you tube is pretty much how I do it.
Steve.
21/01/2020 14:10:02
Posted by David George 1 on 21/01/2020 07:56:42:
Hi Steve you can use the wheel from a plastic lighter with a flint the wheel is very hard and its easy to make a holder to make a knurling tool.
David
How do you guys do it, the idea's you come up with, a lighter sparker. Just looked & it does look pretty much the pitch I would need. Thanks you David.
Steve.
21/01/2020 02:44:32
The £5 coin I am going to try & stretch it so that most of the detail is kept. Obviously some of the centre will be lost. The art is in the annealing keeping the metal very soft so it can be stretched & shrunk. My friends who have seen some of my rings cannot get there head round how they are made.
21/01/2020 02:40:34
Thanks for that info. Some more I will be doing. I have a Krugerand coming which is pure. Qe2-1Silver Qe2startedMorgan dollars
Some to start with
Thread: The Car Share Thread
20/01/2020 23:00:11
Well done. Darn good idea. Remember the Bus strikes way, way back. I used to go to town on a morning with the car full of people from the bus stop near me. Most smoked so car was worse than driving in fog.
Steve.
Thread: Centec 2a Gear Box Oil
20/01/2020 22:56:13
Ah did not realise it was a gearbox. Oops
Steve.
20/01/2020 22:53:46
Steve.
20/01/2020 22:43:44
Something I had a go at recently. The old 2 shillings & half crowns are a popular ring to use. But are 50%Nickel 50% Zinc. Pre 1920 british silver coins had .925 sterling silver content. So much better to use but expensive to buy. Just bought some Morgan 1881 Silver Dollars to do. They are 90% Silver. I wore the half crown ring for a few days & it did make my fingers go a bit black. Ones made of none precious metal need either a coat of clear laquer of which I have gallons of 2 pack from doing my write off cars & bikes rebuilds. Or maybe some way of anodising. Got stacks of coins to go at. There was an issue of, sort of destroying coins but seems like no one gets bothered by it. Obviously the coins I am practicing on are no longer tender. There was some bylaw in the states saying that you cannot alter currency that will make it worth more than the ring value. The half crown shape is what is termed the fat tyre. Popular in the states where they use a large ring. Smaller coins not so easy as you have to stretch the metal & lot & the writing is much harder to read. That half crown was annealed 6 times during the process. They work harden very quick once you start to reform them. Half crown1st attempt
Another pic
Edited By Steviegtr on 20/01/2020 22:47:01
Thread: Silver Soldering Brass
20/01/2020 22:16:12
My 1st job an apprentice sheet metal worker involved a full college lecture on gases. The Oxygen was usually at 2000psi full & liquid. The Acetylene was a spongy mass & much heavier to move & was 225psi. Then they brought in anti backfire arresters. Big signs saying no oil near oxygen. Learnt to braze gas weld at 15 years old it was a great 6 mths till I changed careers & became a Sparky. I never did any Silver soldering. Watched my mate do the boilers of his steam engines though.
Thread: Back plunger indicators - does anyone use them?
20/01/2020 22:06:27
I wouldn't mind one in my workshop.
Thread: Fradley Canal Crane Progress
20/01/2020 22:04:40
Brilliant. Love it. Well done.
20/01/2020 22:02:59
Well I know a lot of Classic british bike owning guys. They all use the old Mineral straight oil. I have many times said why on earth don,t you put some semi synthetic oil in. The answer is always that you cannot because the engine tolerances & the way it is lubed will not work.
Thread: Can we have a really clear distinction between Silver Soldering and Brazing
20/01/2020 21:56:16
Well Brazing usually is done with an oxy acelylene torch, or that's how I always did it. You need a lot more heat for brazing.??? Both are only gluing the metal together hence years back I had a MOT failure on a car because I had brazed sill on. With silver solder when it reaches is melting point the solder flows instantly & sinks in to the joint. Brazing does in a way but so much so.
Thread: Only for Myford lathes
20/01/2020 21:48:58
Sorry to add a pic. It looks in one picture that one is not flat. It is where I filed the burrs off, which is showing missing paint. Better pic.Toolholders side by side
20/01/2020 21:35:13
Managed to get the 4 jaw chuck fitted. Need a proper back plate when i can locate one. It runs fine up to around 900rpm & after that is a bit out of balance. Great addition though. Got the toolholders cut down to the size I require. Had a txt to say my QC toolpost has cleared customs & out for delivery. Fingers crossed I will have it in a few days. Then i can see if it was a mistake buying the larger one. These take up the 13mm Not sure what size you can get in the 000 version. In one picture cutting oil can be seen up the back wall. I need to make a decent splash back. toolholder profileCut down to sizeSplash back needed
Bit rough but accurate
Edited By Steviegtr on 20/01/2020 21:37:13
Thread: Has anyone watched this Girl
20/01/2020 14:03:56
Yes & if you listen to Steve Jordan on you tube he raves about the ebay ones & bangood. But maybe he would. Wouldn't you if they were free.
Steve.
Thread: Honda Brake Cable
20/01/2020 13:56:17
Have you got the brake plate in the correct position, i tried to zoom in on your picture.
Thread: Dementia
20/01/2020 13:41:42
A friends wife has had it for a few years now. It has got quite bad.
20/01/2020 00:14:38
Monday's job is to drill & tap the backplate to take the 4 jaw chuck. Then to machine the 250-101 toll holders down by 4mm. Not recommended by most forum members.
Thread: Apologies for raising this again
19/01/2020 22:48:05
Takes me back to my 1st car, a Morris miner 1000. Then 1100, then twin carbs & 3 branch, then 1800 MGB engine & gearbox,, then the car broke in half. Traveller model with alloy roof & bolted side beams was never very strong. Lightened flywheels were a good way of getting the engine to rev more freely but often became lumpy at the bottom end. Bought a MGB GT after that. Jesus that was 50 years ago. Need to sort out a funeral plan & my will.
