Member postings for Trevor Crossman 1
Here is a list of all the postings Trevor Crossman 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Pesky Government Announcement!
18/06/2020 11:26:14
I would agree with the OP that repeated Government announcements would be annoying, but rotating multi -horsepower machinery and sharp and pointy tools require my full uninterrupted attention at all times. They might not function quite as well as they once did but I've still got all the bits of me that I started with and intend to keep it that way 🤞so no radio at all in my workshop.
Trevor
Thread: Sharpening Files
13/05/2020 16:38:54
I remember from my apprentice training days 60 years ago an instructor on a sheet metalwork course said that worn files were reclaimed by an electrolytic process using conc. Nitric acid. I cannot remember the details, but definitely not really something that could be done in our backyard workshops 😲
Trevor
Thread: Sort of a Straw Poll
12/05/2020 22:06:50
Leslie, if it's your cash and your life,it's your choice what you buy. Use every hour of every day as if there's no tomorrow..........there just might not be!
Whatever happens after we expire is another person's choice and does it really matter what any surviving relation receives for the deceased's possessions? They too will die. Money is simply a measure of our labour and has no spiritual value, and while in all good relationships each partner will make good preparations for when the 'other' is alone, surely the whole point of living is to try to achieve something.
So go for it, buy your machine and use it as well as you can!
Trevor, (75+ and enough projects, plans and ideas to last for another 50😄
Thread: 5" gauge tender horns
16/04/2020 10:43:15
Posted by Peter Simpson 1 on 16/04/2020 09:42:40:
Hi Trevor nothing has arrived in my in box.
Peter
Oh well, it's adrift somewhere out in the ether, check your spam folder though.
Here's the support piece, angle has two pieces of titanium sheet angle bolted to each end which supports the horn angle piece and is solder proof. If you don't have any or can't find any locally, PM your address and I will post you a piece. Not shown in the picture is the hold down which was a vertical bar with a guide piece at the top through which a piece of pointed stainless steel rod passed and held down the small gusset pieces.
16/04/2020 09:05:58
Posted by Peter Simpson 1 on 15/04/2020 09:35:20:
Trevor how did your soldering jig work. trying to work out design that will not get soldered to the angle iron,
Peter
PM and a picture sent.
Thread: Concorde model maden flight
13/04/2020 11:03:29
I missed the Abingdon debut of model gas turbine engine when the Service had other plans for me, but I remember having long conversations with Gerry Jackman about his engine building when we met a couple of times in the Reading model shop while buying stuff. These model engines have really come a long way, much aided by the development of micro electronics.
Trevor
07/04/2020 20:38:05
Hello Peter, fabricate them from 1/8" steel angle and save yourself around £85. The picture below shows those that I made for the tender to my 5" Salisbury. They took me a couple of hours to saw the pieces for all 6 and file them to size, and an afternoon to silver solder together. I made a simple jig to hold the parts together while heating or the small pieces float on the molten flux 😄
Edited By Trevor Crossman 1 on 07/04/2020 20:43:54
Thread: Aluminium black
10/02/2019 17:35:35
Ian, many of these chemicals will give varying results dependant upon the composition of the aluminium alloy , however, whatever the alloy, it is important that at all stages of cleaning and preparation the item is not handled with bare hands no matter how clean they might appear to be, fresh rubber/pvc/nitrile gloves are essential. Perhaps on some dots the liquid formed a bubble across the top of the depression leaving the base clear?
Thread: Every Tea Room needs a toaster topic...
10/02/2019 10:09:15
Many years ago a former wife owned a toaster almost the same as Robin's which was shown in the original post, it worked perfectly and without fail turned the toast when the lid was lowered. It was slightly different in one detail however and that was that the ridge upon which the slice of bread rested when in the closed position, was curved i.e. convex, so that as the lid was lowered the slice easily slid off of the curved base toasted side downwards. When the said wife departed, the toaster departed too- - -and despite looking for many years, I never saw another ( toaster that is smile d  until last year our mutual friend Google found this ………….img_20190210_094140742.jpg toaster.jpg
which is not bad at all, but not automatic, though with a bit of additional metalwork could be made so! It is Moulinex, seemingly only available from Spain where they are sensible enough to not worry that stupid people might be able to electrocute themselves by being able to touch the elements, or burn their house down because the only control requires enough brain function to be able to operate the OFF switch.
I suppose that really it's a just a posh version of Duncan's electric fire and coat hanger, but you can do perfect toast on it...…………………………………...or burnt embarrassed
Trevor
Thread: WHERE ARE THE SHAPER USERS ?
05/02/2019 16:49:02
Posted by RICHARD GREEN 2 on 05/02/2019 15:19:34:
I picked up this Invicta 6 MR , 24 inch stroke shaper last year
I guess that when it comes to shapers, size does matter !
That Invicta 6 will shift a lot more metal than my little 'ole' Boxford
Thread: US/UK Lexicon
24/01/2019 11:17:29
Posted by Bazyle on 23/01/2019 22:57:20:
The pictorial instructions cut across language barriers which is essential nowadays. I have a problem getting enough appropriate pictures in our instructions, though we do have a lot of words as well. Which again is a problem with engineers in general and especially when they don't speak 'BBC English'.
I have never been able to understand why people needed the written part of the Mecanno instructions. when there were plenty of pictures.
We used to have to provide detail maintenance instructions for the RAF. If you have a box in front of you with the cover held on by ten screws why on earth do you need to be told to undo the screws to take off the cover. What you really always need is the type, thread and length of the screws for when you lose some. Next time you get in a plane just think of it, the maintenance was done by a bloke who is so thick he needs to be told to take the screws out to get the cover off.
Bazyle, if you took a moment to think about it instead of pouring scorn on people you would see that the reason for listing the obvious is not because the person doing the work is thick , but because it is necessary to have the work split into quite precise and unequivocal language describing the maintainance process. Within large organisations where more than one person might work on a task and part way through the procedure may be replaced by others, the work that has been done by each individual has to be certified, so that in the event of any failure or damage of the component or of the system of which it is a part, which may be a very heavy and fast aircraft, missile, bomb or critical communication; it it easier determine the cause and possibly responsibility for that failure.
Apart from the legal aspects, there are very many aviation components where the internal components are assembled by the manufacturer in such a way that it is imperative that it must be dismantled in a precise order to prevent damage to the internals or possible injury to the operator. This is particularly so with military and other public and civil organisations equipment because it is taxpayers money that is involved and are everyone in those organisations are, quite rightly, held legally responsible for the use of it.
Trevor
It may well be obvious that
Thread: Drill chuck releasing drill bits.
23/01/2019 12:08:20
Yes, exactly the same problem with my 2 year old Dewalt 18v . It was okay when new, but now after a lot of serious concrete drilling and large drill work, the snap action of the brake upon trigger release always causes the chuck to loosen. If the speed is slowly reduced the braking is less or not at all and the chuck is okay, I doubt that the chucks on these lower end machines are of good quality anyway, and since it has resisted all attempts at removal to fit a new one I'll live with it until I need a new one.
Trevor
Thread: Gatwick Drone 'Attack'
24/12/2018 17:03:09
Posted by Danny M2Z on 24/12/2018 16:39:16:
A pre-programmed flight such as this one does not rely on the r/c transmitter, just a link to GPS satellites **LINK**
The chase drone just had the Litchi co-ords offset by ten feet. An impressive flight but probably quite illegal where I live.
In fact one could theoretically fly the Gatwick mission from Australia given a Google map of the area and somebody to place the drone for take-off.
Scary but true,
* Danny M *
On that note, I remember that several, maybe 10, years ago a radio control modeler in New Zealand built a large model cruise missile using components generally available in the retail market and it worked perfectly well,( apart from no explosions of course!)and so it wasn't surprising that his website was taken down as soon as this became known to his national authorities!
Trevor
Thread: Modern efficiency !!!!!!!!!
19/12/2018 23:23:54
Modern cars,vans and motorbikes are indeed many ways a fantastic improvement over the leaky,rattly rubbish that I had in my youth, but I'm not sure about the ''greenness'' of modern motors due to parts being shipped to and fro across the globe before final assembly. By co-incidence a Guardian article today shows how a (BMW) Mini crankshaft starts as a casting in France, arrives and is worked on at a plant in England, sent to Germany for fitting into the engine, which is returned to another plant in England to be fitted to the car. The same sort of process must be going on for many other components and for other manufacturers, so how can 'global' manufacturing be better for the environment than 'local', though of course it may well be deemed to be 'more efficient' by the bean counters that control most things these days.
Trevor
Thread: Combi Boiler fault finding
18/12/2018 22:31:33
I don't do any fault finding with my combi, because when our old, inefficient, 16 years old one finally died,for just £24/month leasing fee we had a new boiler, all servicing,repairs and replacements included. It is now three years old and after 5 years I can purchase it for £1 and pay any future costs or start another leasing with a new boiler. No worries, no hassle, no capital outlay which I consider to be a good deal.
Trevor
Thread: knock ? engine
02/12/2018 17:10:18
Yes,co2 engines for very lightweight model aircraft operate on this principle, the piston has a small peg on its crown which as the engine turns through TDC the peg lifts the ball briefly and releases a small charge of gas which expands, pushing the piston down and is exhausted at the bottom of the stroke. Most of them will run in both directions, Gasparin is one brand, Czech made.
Trevor
Thread: Hi from Nelsons County
02/12/2018 17:03:36
Hi Andrew and welcome, there are quite a few of us amateur swarf generators and horders of ' will come in useful one-day stuff' spread around these parts, so probably someone is tucked away quite near to you, and as there's very little in the way of industrial supply here, you'll probably not have too much trouble in off loading your junk, sorry, useful stuff!
Trevor
Thread: Unnecessary waste of paper
30/11/2018 21:48:01
Probably over 15 years ago I had a conversation with one of our delivery men who once had been the area rep. for Wiggins Teap, one of the paper companies, and he told me that far from being the end of that industry, increasing computer use would help it to flourish. It seems that he is right and what seems to happen is that 'operatives' just do what computer says, they don't have either the time nor inclination to notice whether or not the automatically generated letter(s) is needed. Automated systems make the problem worse because there isn't a human who you can talk to about it, unless of course you want to dial what is laughingly called Customer Services and spend an increasing amount of one's remaining time on Earth 'on hold' and listening to Vivaldi or Clannad or some other boring synthetic 'pop' track on an endless loopangry. My collection of threatening letters automatically generated twice/thrice a month for the past 20 years by the TV Licence Gestapo is now over a foot high since I gave up trying to get them to stop. As someone has said earlier, this and all the other garbage mail helps to keep our posties and refuse/recycling collectors in work and even if most of the junk is unburnable glossy stuff, there's usually an envelope or two good for firelighting ( after being used for design doodles in the workshop- - - two birds/one stone and all that)
Trevor.
Thread: Tungsten Alloy
27/11/2018 20:59:30
Duncan, it might be worth you trying businesses that deal with aviation scrap/used parts. The flight control surfaces use very dense material for the balance weights, sometimes on light aircraft this is lead but more highly stressed aircraft use other heavy metals such as tungsten rich materials, many years ago when I repaired British military aircraft, we would often make up special rivet bucking blocks from discarded balance weights. Aviation tool suppliers stock Tungsten rich riveting bars in a variety of sizes, shapes and weights.
Trevor.
Thread: Stop Start switch
20/11/2018 20:30:12
Vic, you don't say if you've got the 4"belt/6"disc Far Eastern made type but my belt sander suffered the same problem and eventually failed totally, bought a replacement from Axminster.
Part# Kedu KJD20-2 @ £13.73.
Trevor.
