david archer 2 | 02/12/2018 17:00:00 |
5 forum posts 4 photos | A friend of mine has described an interesting model engine that uses air and has a ball bearing type valve - not sure about spelling of knock !
david archer 2 | 02/12/2018 17:09:32 |
5 forum posts 4 photos | I have a pulse jet built many moons ago from plans in the model engine book - the Brauner design - have never got it to run . Is there anyone who could look at it please? based near Carlisle |
Trevor Crossman 1 | 02/12/2018 17:10:18 |
152 forum posts 18 photos | Yes,co2 engines for very lightweight model aircraft operate on this principle, the piston has a small peg on its crown which as the engine turns through TDC the peg lifts the ball briefly and releases a small charge of gas which expands, pushing the piston down and is exhausted at the bottom of the stroke. Most of them will run in both directions, Gasparin is one brand, Czech made. Trevor |
JC54 | 03/12/2018 00:04:37 |
![]() 154 forum posts 14 photos | Stan Bray in his book "Making Model Steam Engines" shows drawings for a Clapper engine called "Clarence" this is a steam/compressed air engine using a ball bearing valve lifted by a pin in the top of the piston. Hope this helps JC |
Speedy Builder5 | 03/12/2018 07:08:57 |
2878 forum posts 248 photos | David, I too made (probably) the same engine. I got it to run a couple of times - once on cup final day which brought the neighbours out during the match. I ran it on petrol, with the aid of a blow lamp and compressor. Difficult to start and latterly found out that the radius of the washer behind the petal valve was all wrong. I need some new petals and will need to find someone who could laser cut some from different thicknesses of steel shim. In hindsight, I think that a shop vacuum cleaner would be better used as a blower to get the initial start. Take my advice and use ear mufflers -they are very LOUD - - - LOUD ! - ! - ! - ! |
