Here is a list of all the postings Jon Lawes has made in our forums. Click on a thread name to jump to the thread.
Thread: Drip feed oiler plans |
09/06/2019 10:48:03 |
I've been thinking lately that the pyrex type glass they use in Vaping machines would be excellent for a drip feed oiler, especially if you are making something petite. I'm aware you have the glass, just an observation. |
Thread: Tyrosemiophilia |
07/06/2019 21:11:34 |
I used to collect interesting cigarette lighters. Mass produced stuff primarily. But charity shops stopped selling them (an angry lady in Salisbury shouted at me for daring to ask if they had any lighters in a British Heart Foundation shop.... how dare I etc. etc.) and ebay means finding anything of interest for a few quid just doesn't happen.
Thread: Small air compressor sufficient to run a Potty Mill |
01/06/2019 13:27:41 |
To think outside the box a little, what sort of boat? Is it a narrowboat or similar? Does the engine of the boat already have some sort of compressor for running other components? Could you find something that would run off of there? Or even have an engine driven compressor feed an accumulator? The compressor doesn't need to be where it is being used, and a pipeline between the compressor and point of use just serves as extra pressure storage if the regulator is done at point of use... I know its all a bit random, just trying to look at other options for you. |
Thread: stamford show vandals |
20/05/2019 12:16:33 |
Mike has said it perfectly. |
Thread: Silvering brass |
11/05/2019 23:30:08 |
How on earth does that work then V8Eng, sounds like snake oil (only sounds like, your results sound pretty convincing) |
Thread: A dynamo question: rotation direction? |
11/05/2019 19:58:52 |
Agreed, I converted my Morris 1000 to negative earth and had to flash the dynamo to achieve it. It wasn't onerous. |
Thread: Pressure gauge help needed please. |
27/04/2019 17:23:35 |
From what I can see of your craftsmanship the world is your oyster. |
Thread: The Chocolate Fireguard as designed by Mercedes Benz |
27/04/2019 17:10:50 |
The jets in my carbs used to have waxstat units that mucked up the mixture when hot. I've fitted normal ones now. Take that technology! |
Thread: EKP |
25/04/2019 22:21:31 |
Noted, I'm motoring through BA fasteners at a rate of knots on my Brit build. |
Thread: Cross slide backlash |
22/04/2019 15:18:55 |
If you turn the handle side to side to expose the backlash you can see the whole thread moving back and forth. That's what indicated to me that was where the problem lay. I suspected it wasn't the nut in my case as the lathe hadn't been used much |
22/04/2019 13:17:32 |
This modification is available for the ML7 (I'm aware you are referring to the super 7), I wonder if something similar could be done. I used the bearings listed for my ML7 and it improved things drastically. |
Thread: Making Holes in Copper Sheet |
19/04/2019 20:20:48 |
Q max would be my vote too, even home made. |
Thread: Aspiring Myford User |
19/04/2019 13:10:37 |
It's a bit north for you (I'm North Dorset) but I travel to Westbury to the WWSME, a fantastically helpful society who have assisted me no end, despite all my daft question. You would be made most welcome if you ever want to visit. |
Thread: Sort of like a guitar... |
18/04/2019 19:47:14 |
Superb. |
Thread: Which triple expansion engine |
15/04/2019 20:51:14 |
My 10H was quite slow to arrive from Stuart; it was a birthday present ordered a few months before my birthday, and my birthday came and went, and more weeks besides. When it did turn up I had a problem with one of the castings, which to their credit they replaced without quibble. However there was the same delay of just over a month for the new one to arrive. The general quality of the 10H kit was very good indeed. Stuart's customer service was good, but you have to wait for them... My experiences with Reeves I have spoken about before. My personal experiences with their customer services encourages me to use other vendors unless there isn't another option.
Thread: French Mystery Tool |
11/04/2019 20:22:21 |
I wonder if the bolt previously was a larger one with a spring under it? |
11/04/2019 19:16:09 |
Do they fit together the other way? |
Thread: odd thread |
09/04/2019 20:06:59 |
Well done Philip |
Thread: myford leadscrew |
09/04/2019 20:06:03 |
I find the handwheel on my lathe annoying (ML7) as the graduations don't go up cleanly in tens for each revolution. I can't explain it very well, but I mean the end of the graduations end in a five when it reaches zero.
I know what I mean if no-one else does... |
Thread: GIFTS |
07/04/2019 19:55:48 |
Could it be a 1-1/8 x 12 tpi whitworth form thread? That would be Myford. My apologies if wrong. |
