Member postings for vintage engineer
Here is a list of all the postings vintage engineer has made in our forums. Click on a thread name to jump to the thread.
Thread: Hydrogen
10/01/2023 21:09:24
I live in the Highlands of Scotland and EV are not practical as their are very few charging points and unless there are EV with four wheel drive and low ratio gearboxes they will never be any good up here!
10/01/2023 18:04:48
The big problem the EV backers hide is the fact the damaged caused to the environment by extracting the raw materials to make the batteries and the pollution problem caused by the end of life of the batteries.
To mine 1000kg of cobalt you need mine 1,500,000 kg of material.
Thread: Build yourself a lorry...
07/01/2023 21:59:35
All the techniques they used to make the truck chassis are the same that are used making and repairing vintage car chassis's.
Thread: Fuel for Petter AB1 diesel engine.
02/01/2023 22:47:57
As of 1st April 2022 it is illegal to run generators on red diesel unless it is for non commercial use.
Edited By vintage engineer on 02/01/2023 22:49:34
Thread: Christmas Cracker Jokes
28/12/2022 22:19:57
What has four wheels and flies?
A dust cart!
26/12/2022 22:05:27
Two parrots sitting on a perch. One says to the other "Can you smell fish?"
Thread: Bob Reeve's Differential Demonstrator
06/12/2022 20:32:23
The wooden wheel device was invented by Dennis Motors as a very cheap way of locking the diff so both wheels were constantly driven.
Thread: Weight driven clockwork roasting spit
04/12/2022 21:17:09
It would now be made on milling machine using dividing head connected to the table leadscrew, Setting up is the hard part machining is the easy bit.
Thread: Over / under size nuts
03/11/2022 22:58:41
Some old British cars (Talbot) had metric threads with Whitworth heads.
Thread: !960s Eterna-Matic automatic watch, Can anyone recommend a repairer?
03/11/2022 22:54:15
Rolex charge about £500 for a standard service.
Thread: Is It The Blue Screen of Death
25/10/2022 19:38:43
I got called out one night because some idiot changed the language to Chinese on a very large IBM printer then couldn't change it back because no one could read Mandarin!
Thread: Mystery ancient thread size
22/10/2022 18:07:13
I work on early vintage cars and this is quite common. Bugatti are know for using odd threads even bsp threads on their gear boxes!
Thread: Galvanitic/electrolytic reaction
01/10/2022 21:26:14
I soak parts I have silver soldered in boiling water to remove the flux.
Thread: Parting tool trouble
03/08/2022 20:14:00
Are you hand feeding it or what speed is the power feed running at?
Thread: Does anybody know this company? Please Help
06/06/2022 22:12:00
Been using Brundles for years very good company. Family owned, on fourth generation I think now. If you tell them you are from REMAP you may get them for nothing.
Thread: Looking for uncommon propane tank fitting
24/05/2022 22:22:32
Why can you not make one?
Thread: Metal Cleaning Using Vinegar?
19/02/2022 21:19:14
acid on amzon
Thread: Alternatives to Loctite
18/02/2022 22:14:23
Another old method is to coat the part with solder paste and heat up after assembly.
17/02/2022 16:59:30
Sulphuric acid is still readily available. Just buy Oneshot drain cleaner.
30/01/2022 23:34:12
A saturated solution of salt and vinegar will remove zinc plating from nuts and bolts.
