Here is a list of all the postings SillyOldDuffer has made in our forums. Click on a thread name to jump to the thread.
Thread: What vacuum gauge for testing smoke box vacuum? |
22/08/2016 18:00:47 |
This thread quotes mentions 0.3, 0.5 and 0.6" of smokebox vacuum as measured by someone called Jim Ewins. Also "anyone who has more than 1" of vacuum on a 5"g smokebox has something very wrong somewhere". They recommend an air-conditioning gauge as being easier to mount than a manometer and using an incense stick to detect leaks. Dave |
Thread: One Man and His Lathe Articles Sought |
22/08/2016 17:01:28 |
Posted by Roderick Jenkins on 22/08/2016 14:52:46:
Posted by SillyOldDuffer on 22/08/2016 14:05:49:
...but the chuck in my Dean Grace and Smith weighs more than your Super...
Sounds like a good argument for owning a Myford to me Rod It's an excellent argument for owning a Myford! When I eventually got to see an ex-colliery DSG in the flesh I was amazed how big it was. I reckon it would just about fit into an empty single garage, but there wouldn't be enough room to operate it. The chuck was at least 2ft in diameter and looked far too heavy to lift manually. If my memory is right the owner told me the motor took a 15kW 3-phase supply. I still want one though, just for the bragging rights... Dave Edited By SillyOldDuffer on 22/08/2016 17:03:06 |
22/08/2016 14:05:49 |
Posted by Raymond Anderson on 22/08/2016 13:15:56:
Proud owner of a [near mint ] DSG 17T and a Warco GH750 don't make models though.[ never tried ] yet. That's a very interesting combination. Any chance you could write an article for Neil that covers the pros and cons of the two lathes and what you use them for? I've had a soft-spot for Dean Smith and Grace since overhearing a chap who owned one slap down a group of raucous Myford fans. About 5 years ago I was in a queue to pay for some bits at the Bristol Exhibition. Three Myford owners were mercilessly ragging a mate about his decision to buy Chinese. Mr DSG turned round and said "I suppose Myfords are OK if you like making toys but the chuck in my Dean Grace and Smith weighs more than your Super..." I would love to own a Myford in good order but think they are over priced. People buying them just for the bragging rights put me off too! Dave |
Thread: Decoding Abbreviations on a Technical Drawing |
22/08/2016 11:41:31 |
I like to provide feedback after asking a question. Firstly the people who offer advice deserve some recognition and secondly others may like to know if the advice helped. In this case a triple thank you to Jason for providing:
All of these were useful aids to progress, Yesterday I assembled the engine to check the fit. I would love to report that it turned first time smooth as silk: in fact the engine has several all too obvious tight spots. The worst problem by far is that the crank assembly is slightly bent, a problem I would have avoided had I made the crank the Stewart Hart way, ho hum. I got away with the "Drill After Assembly" mistake; the crank is bent because an 8mm drill wandered, not because the pin holes are misaligned. I've a few more bits to make before the engine might possibly run. If all goes well I shall be putting air in it later tomorrow. Fingers crossed... Cheers, Dave
Thread: Lenze inverter help |
21/08/2016 20:03:21 |
Posted by Steve Pavey on 21/08/2016 17:40:22:
do I now have to connect up all the low-voltage control wiring (ie on, fwd/rev, potentiometer etc? And if anyone can tell me what the keypad error code means I would be very grateful.
"init" is probably short for "initialise" and isn't an error as such. The persistence of the message may be indicating that the VFD's microcontroller has got stuck doing it's pre-flight checks. It could be that initialisation can't complete because some essential part of the control wiring is missing . Or as Mark suggests it might not be able to initialise with the wrong keypad. I would try lashing up the control wiring to see if that makes a difference. Dave Edited By SillyOldDuffer on 21/08/2016 20:04:03 Edited By SillyOldDuffer on 21/08/2016 20:04:53 |
Thread: Unknown Swiss milling machine |
20/08/2016 21:45:11 |
TN are mentioned as a maker in this Practical Machinist thread |
Thread: Doubleboost, "High Precision ***" |
20/08/2016 20:16:35 |
Just managed to lose a post! Anyway, Industrial Production in US $ Billions (2013) China 4008.35 Bear in mind though that Industrial production is not a good indicator of a nation's per capita wealth. |
Thread: Pickling with Sulphuric |
19/08/2016 13:43:45 |
Posted by Neil Wyatt on 19/08/2016 12:46:30:
Loads of organic acids that do the same job well enough I can't see why anyone would use sulphuric. The advantages of concentrated Sulphuric Acid compared with the alternatives are:
The disadvantages for hobby use are:
I have concentrated acid available but rarely use it. I agree that most hobbyists would be wise to start with a milder alternative unless they know what they're doing and have a good reason for using the real thing. Cheers, Dave
Thread: Torque required for a small mill power feed |
18/08/2016 17:44:10 |
Posted by fizzy on 18/08/2016 15:58:19:
I don't have a spring balance (I do remember them from school) so how do I use tape? Thanks. Im also assuming that the torque required needs to be measured at the crank as it will be a direct attachment rather than from the handwheel? Im confused. Hope this diagram helps. You can measure torque at any distance from the crank because, for a given turning resistance, weight * length is a constant. If length is short, you need a large weight. But as length increases you need proportionally less weight to turn the crank so you get the same answer. In the absence of a spring balance, position the handwheel at 3 o'clock or 9 o'clock and slowly increase the weight until the handwheel turns. Dave |
Thread: Suspect scammer |
18/08/2016 15:51:09 |
I'm sometimes tempted by a life of crime. I'm sure with a little thought it would be possible to make scams like this much more convincing. Fortunately for the well-being of society the thought of prison deters me - I cannot shower with other men. Cheers, Dave PS. Had to look up Mark's "coon ages". My nearest raccoon would be in a zoo, though there are a lot of llamas round here. |
Thread: Aircraft General Discussion |
18/08/2016 15:36:45 |
Posted by Muzzer on 18/08/2016 14:53:35:
... Obviously there must be a lot of cost involved in filling that thing up with helium and you can't go jettisoning a lot of it when you dump the cargo. Perhaps I'm missing something obvious? If they use water as a disposable ballast, that's neither free nor necessarily convenient. You could reduce lift by either re-compressing some of the Helium in flight or by adding air under pressure to the balloon. I doubt an airship would want to carry a hefty compressor, so increasing density by adding air feels more practical. The Helium could be purified later on the ground, thus reducing losses. Just guessing. Dave |
17/08/2016 21:42:24 |
Seems you have to spend money to get a copy of BS8888 but this overview looks useful. Dave |
Thread: What Did You Do Today (2016) |
17/08/2016 19:45:14 |
Parting off is such sweet sorrow. 30mm diameter free cutting mild steel, rear tool-post. Dug in and tore the holder. The work and 3mm insert both survived!
17/08/2016 19:24:32 |
Posted by Neil Wyatt on 17/08/2016 19:06:01:
Posted by SillyOldDuffer on 17/08/2016 19:02:46:
Looking for answers on the web led me to several different drawing standards. What's preferred by Model Engineers? Clarity and freedom from gross errors. Neil That's me stuffed then. I specialise in ambiguous mistakes... |
17/08/2016 19:02:46 |
Many thanks chaps - 'Drill After Assembly' makes perfect sense. What a shame I've drilled the holes already: it will be interesting to see how well the parts line up when I try to put them together! I didn't want to cause embarrassment by identifying the drawing but you've got that right too. With 47 parts (excluding fasteners), the drawing is certainly very crowded. Where necessary I've dealt with that by redrawing the less obvious parts with qcad. I've found redoing the drawing useful to confirm dimensions and to suss out how to make the thing. One item of good news about the drawing - I've made well over half the parts without finding any errors. Looking for answers on the web led me to several different drawing standards. What's preferred by Model Engineers? Ta, Dave |
16/08/2016 20:41:49 |
My current project has me looking at a drawing that uses a lot of abbreviations. Things like: M3x4DP, 8PF, R30, CS, 10PCD, 3RM and DAA. These I've decoded, I hope correctly, as: M3x4DP - Drill and tap M3 4mm deep Can anyone help with DAA please? It's applied to some holes. Thanks, |
Thread: A very accurate lathe quick change tool holder |
16/08/2016 18:11:50 |
Posted by Michael Walters on 01/08/2016 20:43:08:
pounds per square foot/inch was a much better system, It's easy to understand how much force is involved when you imagine it. Originally, like most imperial systems it was based on real life examples. A pound/s weight applied on the leverage of 1 foot long scales. But Michael, confusion abounds. Surely PSI is a measure of pressure, not force... Dave |
Thread: King Cotton |
15/08/2016 22:41:19 |
Posted by Sam Longley 1 on 15/08/2016 20:20:27:
Any mention by the BBC of a foreign ccmpany investing in the uk in the wake of Brexit ---or has that slipped their minds? I suppose you will say it was pre Brexit!!!! Sure is. Supported by a grant from the Regional Growth Fund (British Govt) which was cut in the 2015 Spending Review and is unlikely to provide more help. It will be interesting to see what the government does about the RGF and similar programmes some of which are directly funded by the EU. Will they be maintained? Before Brexit UK economic policy was aimed at reducing the deficit, which is why the RGF was a casualty of the Spending Review. Leaving the EU opens up the possibility that UK government might be able to support industry more than is already allowed by the GBER, but one has to wonder where the money will come from. This must be a concern to a government previously committed to reducing public spending, and one generally in favour of market forces. Higher taxes and more borrowing are the most likely way to raise the cash if government decides to support industry more. PFI and PPI deals are a possibility but they have some serious disadvantages. I think it unlikely that significant private money will come to the UK until investors better understand the likely consequences of exit. Although the company has a German parent, it appears to be half British. Dave Edited By SillyOldDuffer on 15/08/2016 22:42:58 |
Thread: Allen key screw heads |
14/08/2016 21:29:32 |
Posted by Michael Gilligan on 14/08/2016 20:56:23:
Posted by SillyOldDuffer on 14/08/2016 20:40:24:
I hope someone who knows can tell us. . I did Oops, sorry! I over-focussed on the IKEA joke. But do you know why metric preferred clearance holes are bigger? Ta, Dave |
14/08/2016 20:40:24 |
Posted by Vic on 14/08/2016 18:54:15:
I must admit that some imperial nuts and bolts look better than metric ones. It seems to be the ratio between thread diameter and nut/head size. Anyone know why metric seem to have larger heads/nuts? I hope someone who knows can tell us. My guess: general purpose metric fasteners have head and nut dimensions specified to reduce the risk that they'll get chewed up when used in average applications. Dave |
