Member postings for Dave Halford
Here is a list of all the postings Dave Halford has made in our forums. Click on a thread name to jump to the thread.
Thread: Model of an epicyclic gear made by apprentices
03/10/2021 20:43:31
Obviously in less than 5 minutes as well.
Thread: Small Hydraulic Press Tools
03/10/2021 15:50:03
2 ton fly press anyone?
Thread: Unwanted Taper
03/10/2021 15:46:11
It's possible bed wear is dropping the tool height towards the tail stock so you effectively take less of a cut.
Are those marks on the bed enough to catch your finger nail?
Thread: Bronze or brass
03/10/2021 12:35:28
Doesn't brass change colour when put in an acid pickle due to the surface zinc being dissolved and bronze stays the same?
Thread: Crankshaft Factory
02/10/2021 19:37:16
Thanks for that Andy, now all I need is a longer piece of gas pipe on my chuck key.
To you sir only £160 in Belarus who knows.
Edited By Dave Halford on 02/10/2021 19:41:20
Thread: Home Made Lathe, Safe?
02/10/2021 18:52:55
Posted by Ian Parkin on 02/10/2021 18:34:56:
Interesting use of a variable speed on a single phase induction motor too.
There's probably a trigger off a mains drill somewhere
Thread: cutting spur gears on a mill
02/10/2021 14:41:56
Posted by brian jones 11 on 02/10/2021 10:29:40:
Caustic commentators on this thread must remember its Title "Spur Gears - a rogue method"
If you want to pursue the conventional route on this topic by making precision standard gears then this thread is definitely not for you - it has nothing to offer that mindset, walk away.
My examination of free hobbing is more akin to blacksmithery. The Artisan didnt have equipment to drill holes, he heated up metal and punched holes (even square holes). You would hardly have described it as precision engineering but it served its purpose. Just look at the craftsmanship in a horse shoe, note square holes and wrought square nails - dont twist and loosen. These are slightly tapered so that the thin ends curl up as they are hammered into the hoof and dont fall out - thats smart.
The pursuit of free hobbing which started with using taps - (as is done in making worm gears quite successfully btw - I dont hear any howls of disagreement on that score) and extended to spur gears has been roundly discredited for many reasons clearly explained as per foregoing posts.
And I agree - it results in a non standard form
Yet more by accident and in spite of the naysayers, I managed to produce some credible meshing model gears using the method of slitting a large bolt and this tool is currently under development , waiting for parts, and is showing promise.
I am hoping that with a more precisely made gr 8.8 tool I can predict the number of teeth I will get and also the workable distance between centers.
These rogue gears will never approach the quality of precision gears made by conventional methods and they were never intended for that purpose. I expect them to function as workable gears for light duty by a DIY method available to those with limited workshops who would otherwise never considered knocking up a gear train.
So to all amateurs, hamateurs amatures, armatures, armchairs and nearly 18,000 views, lets not resort to machinist' righteous bigotry give the Blacksmith some room maybe his tool might fly
WaM
All this implies you are on the same level as a blacksmith after serving his 5 year apprenticeship in the accidental production of usable metal goods. You wouldn't catch a Blacksmith making anything in plastic that had no real use.
Thread: WM18 spindle heat
01/10/2021 15:48:11
Over packing with grease has previously been blamed for hot running bearings.
Thread: SM205 mini mill backlash
01/10/2021 15:44:24
Posted by andrew lyner on 01/10/2021 15:23:21:
I was proposing to use a brass shim to eliminate / reduce the slop. Any reason why not? I can't see how that nut can have become loose as there are no signs of damage on it. The previous owner was presumably making do with how it came from the factory.minimill table screws.jpeg
but last time I suggested improvements (e.g. a LIKE button), existing members jumped on me.
Drag and Drop is not a new-fangled idea these days.
The nut should be firm.
Some recollections may vary, I thought most were positive.
Thread: Silver soldering stainless steel
01/10/2021 14:23:04
You could try switching the blocks around as the base slab is touching the job.
Funny how in the UK common vermiculite comes in 1" thick x 4"x 9" yours looks to be 9" x 2" x 3" which is a house building size. We also have a light weight building block for the inside of house cavity walls that you can cut with a hand saw that works nearly as well.
01/10/2021 12:05:14
Posted by CHAS LIPSCOMBE on 30/09/2021 23:10:24:
Hi Chas,
What are the fire bricks made from? The three look like house bricks.
I originally made the mistake of using bricks that line a house fire grate, they make a great job of robbing heat.
Vermiculite barby bricks are best, they actually insulate.
Thread: Grinding tool bits
01/10/2021 11:53:18
Posted by Steve355 on 01/10/2021 10:19:58:
Hi all
Another beginner thread I’m afraid. There will be more.
After my last thread on finish I realised that I’m going to need to grind lathe tool bits. I got hold of some 20cm 10mm HSS blanks. The first thing I realised is that HSS is really hard. My hacksaw basically bounced off. So I cut it with a diamond blade on my angle grinder, but it still took ages and overheated the steel. Any tips for cutting HSS?!
At the grinder, I am lucky in that I already have an adjustable tool rest with an angle fence (used for plane and chisel blades usually). The problems I’m experiencing are:
1) It takes ages. HSS seems to be much harder than plane blades.
2) when grinding a plane blade, of course the grinding wheel leaves a small amount of curvature. But I just hone this off on the sharpening stone, through several levels of grit and then strop it for a “scary sharp” finish. But on the lathe bit, the area I’d need to hone is much bigger, and I don’t have a nice sharpening jig to keep it perfectly flat against the stone.
The result is a curved point (see pic). It isn’t possible to grind a consistent and small radius on this. The radius either ends up as “triangles” at either end of the cutting point, or a larger “saddle” shaped radius across the whole point.
I’ve watched a few YouTube vids but none I’ve seen properly address this.
I could get a bigger grinder, which would reduce (but not eliminate) the problem.
I could get a belt grinder with a circular sanding disc on the side, but I’m not sure they will be man enough for HSS.
Most likely thing is I am doing this wrong!
Any tips ?
thanks
Steve
You really need to get a general workshop book that just covers the basics.
If you check whats written on a good hacksaw blade, you'll read bimetal + the tooth count that means the teeth are HSS and HSS wont cut HSS.
Wood likes a scary sharp blade, but metal will smash the edge quickly if you use the same angles.
Removing the hollow ground effect is a waste of both money and your time and you don't need the double edge look on a metal cutting blade either. Leaving the hollow on a wood blade means the oil stone is usable a lot longer before you need to grind again.
You just rotate the edge of the blank as you lightly touch it on the fine wheel. Touch up with a hand held stone to keep the edge as and when needed.
By all means use an coarse disc on the angle grinder to rough shape a tool
30/09/2021 12:55:07
So photos of 'This job has not gone particularly well ' would help a lot.
Did the solder flow or did it remain lumpy?
Did the flux get into the joint and did it remain clear?
Any steel is slow to come up to temperature and it may be red on the outside but still too cold in the middle.
Loctite 603 is OK with oil and pretty strong.
Thread: Chatter/finish problem
29/09/2021 15:27:11
Posted by Steve355 on 29/09/2021 11:27:25:
3) I have also noticed that in order for the spindle to turn, the bolts that secure the spindle in the headstock need to be only slightly more than finger tight. Whilst it seems that there is no lateral movement on the spindle, if I pull the spindle with a little force, I can feel the headstock slots flexing. So therefore there must be very little rigidity, and it may explain The test cut I did last night, where on an unsupported pace the finish is horrible further out, improving markedly closer to the Chuck.
But if I tighten the headstock bolts, the spindle will not turn. A couple of questions:
Does this make sense? Might this be a problem?
What tension should the V-belt be? Is there any way I can measure it?
It’s a basic cheapo eBay V-belt. Is this the wrong kind of belt? I have seen a myriad of different belt types on lathes.co.uk.
I will get to the bottom of this!
cheers
Steve
Steve,
Don't for one minute believe that when you acquire an old machine that it was assembled properly by the 10 previous owners.
Looking at the 'lathes' Zyto photos there are no grubscrews, come to that I can't see a collar either. The bearing slits are approx. half the size of the head stock slits
If both bearings are the same size I would try swapping front with rear so that the grub screws and oil holes still line up, but the bearing slot is now at the back, and see if that makes a difference. I still think there should be a dense felt strip trapped in the bearing slit which would also help. If this lathe was built like it is now the bearing bolts would be knurled knobs, hex heads imply more than finger tight was required. You can very easily crack the head stock with slits as large as you have using a spanner.
You can also see the proper fit of the belt in more modern pullies, tension is about right when you can twist the belt 90 deg. or deflect the belt inwards 1/2"
BTW your last photo shows a classic case of too much stick out from the chuck causing chatter.
Edited By Dave Halford on 29/09/2021 15:29:33
28/09/2021 16:33:42
Posted by Steve355 on 28/09/2021 15:14:49:
For some reason when I post pics here they are rotated through 90deg anti-clockwise, if you rotate it through 90 deg clockwise then that’s how the pic should look.
it’s not an HSS blank, it’s the rear end of another tool that I have re-purposed. I have ordered some HSS blanks but they don’t arrive until Friday.
I get the rotation, it's the little flat that you ground on the point to widen it looks to have no clearance
Thread: QDM750/Kerry Super 8 spindle bearings
28/09/2021 14:50:01
Don't mix older an new paints, the base formula is different.
Thread: Scam? Definitely!
28/09/2021 14:42:43
Weird Nigel the letter text has escaped the box
28/09/2021 14:39:21
From your photo it looks wrong, but if the point of that little triangle is not as far out as it's base (top of tool) then it will work. A rounded edge would be better.
PS I've never seen an HSS blank that didn't have polished sides.
Edited By Dave Halford on 28/09/2021 14:40:41
27/09/2021 17:41:44
The U tube lathe does not seem to have a slit bearing, but wether it should is debatable.
At this sort of age it's unlikely any survivors have not been modified in some way. I have a T&LM that has slit bearings similar to a collet and the threaded ring is used to adjust the running clearance. The slit also serves to hold a felt wiper that rubs against the shaft. The end float is controlled by a brass washer behind the chuck mount flange however this doesn't really work for cutting toward the tail stock.
Can you confirm that those marks appeared during a single direction cut and you didn't back it out the same way as you went in? They look to be like a coarse thread like I get when winding out much faster after a cut with some spring in the tool.
Thread: Information
27/09/2021 15:16:07
Might be an old one or miss keyed.
