Member postings for Nick Wheeler
Here is a list of all the postings Nick Wheeler has made in our forums. Click on a thread name to jump to the thread.
01/01/2019 10:06:41
Rang out 2018, chimed midnight and fired in 2019 on Rochester cathedral bells.
I also repaired one of our handbells so our visiting friends could do some ringing with us.
Thread: Min lathe steady rest for up to 65mm diameter
26/12/2018 23:15:44
You could easily fabricate a steady from your 6mm plate by screwing and welding it together after cutting out with a jigsaw; barely any milling required.
Thread: New Products from ARC
26/12/2018 14:18:33
Posted by JasonB on 26/12/2018 13:15:58:
Didn't think you had enough hair to crimp Neilsmile p
1.5mm hair is pretty impressive whatever head it might be on....
Thread: Christmas disaster
26/12/2018 14:17:37
Posted by Mike Poole on 26/12/2018 13:10:34:
I wonder how long an earth pit oven would take to do a turkey?
Ages.
You could deep fry it: LINK
Thread: Drill sharpener
26/12/2018 09:56:01
Posted by Russell Eberhardt on 26/12/2018 09:41:38:
Posted by Nicholas Wheeler 1 on 26/12/2018 09:27:04:
Mainly because I've got better things to do with the time.
That is, of course, just a personal preference to which you are entitled.
Some here are profesional engineers working for money, some are cheque book engineers, and some are hobbyists. Each to his own.
I'm a hobbyist. My workshop is to support the hobbies, so a professional approach is necessary. Spending hours to make a tool that will only get a few minutes use per year when I can buy one for a few quid isn't going to happen.
26/12/2018 09:27:04
Posted by Russell Eberhardt on 26/12/2018 09:12:19:
Why not just build one of the many designs for a four facet drill grinding jig? Four facet works nearly as well as split point, is much easier to get right, and doesn't need a sharp corner on the wheel.
I do sharpen large drills by hand, but I do it so rarely that it takes me several attempts. As I mentioned in my first post, I sharpened every blunt drill I could find in about 1/2 hour which I reckon paid for the tool.
Thread: Bearing puller from hell
24/12/2018 16:47:30
Posted by Neil Wyatt on 24/12/2018 16:02:35:
Once sorted the front crossmember of a mate's Escort using a landrover and a rope
We straightened the front of a colleague's Metro by chocking all four wheels and pulling the damage with the winch on one of the recovery trucks. Longest bit of the job was waiting for the boss to go home!
Thread: Fasteners
21/12/2018 14:28:30
The answer to Vic's original question is this: Carroll Smith's Nuts, Bolts, Fasteners and Plumbing Handbook. It's American, but fasteners don't know that.
Thread: Jaguar XK8
16/12/2018 10:57:45
Posted by Dave Halford on 16/12/2018 10:02:45:
Nikasil bores, be carefull
You're unlikely to find one that hasn't been sorted.
But the cars do rust, and they're heavy on suspension that's expensive to fix. Also, they're at the dangerous stage where people can afford to buy them but not give the open wallet maintenance that they need.
Thread: Barrier cream
15/12/2018 11:28:20
This stuff DERMASHIELD is excellent, effective, long lasting and cost effective
Thread: It's not rocket science
13/12/2018 22:45:34
Posted by Mick Charity on 13/12/2018 20:11:28:
Posted by Neil Wyatt on 13/12/2018 20:03:57:
Having read the article . . .
I'm having a lot more than a little chuckle at your sense of humour, but one BIG thing missing is just how much this issue 550 will £cost ???
just 22 years after Brexit it will cost about £11 billion. But it's OK, it's an American billionwink
Thread: ML7 questions
11/12/2018 20:06:13
Your normal inch spanners will work fine with BSF bolts.
It's Whitworth that you have to experiment with
08/12/2018 22:28:09
Posted by Howard Lewis on 08/12/2018 22:13:57:
+1 for making a Centre Height Gauge. A great saver! of time and frustration when changing tools. (thinking in terms of toolposts, other than QCT types, although it helps in setting up those for the first time)
Is it really that useful?
I just use my digital height gauge, having put a label on the lathe with the height from both the bed and carriage. Saves having to store a tool that I might use a couple of times a year, let alone making the thing in the first place.
Thread: Thread Wires.
05/12/2018 17:34:23
Posted by Hopper on 04/12/2018 23:51:11:
I am surprised this many people use thread wires in the home workshop. Why? Is the conventional thread depth calculation plus a bit of "try and fit" at the final stages not precise enough for some types of home shop work? Or is it simply for the joy of knowing that it's "spot on"?
What if you only have one piece of material to make the part, and the female thread is firmly attached to an aeroplane 3 miles away? Or the matching part is too awkward to fit onto the lathe?
Surely the whole point of owning a thread cutting lathe is so you can make parts that don't use readily available threads? I wouldn't dream of screwcutting an M12 thread for instance, but an M24x1(Russian fuel system) is a totally different matter!
Thread: Interests other than Model Engineering
04/12/2018 22:13:37
Posted by Bodger Brian on 04/12/2018 13:24:45:
Posted by Nicholas Wheeler 1 on 03/12/2018 22:05:12:
Other hobbies are bell ringing - I've just got in from one of the tower practices that I go to - modified cars, and cycling.
That makes at least 3 bellringers on this forum. I'm in Oxfordshire (there is another ringing Brian Curtis in the New Forest area), although I'm somewhat lapsed at the moment) and I believe Julian Atkins is also a ringer. Where's your home tower?
Rochester Cathedral, where I learnt over thirty years ago and returned to 3 years back after a long break.
03/12/2018 22:05:12
I'm only a 'model engineer' in the sense that we don't have a better term for having small machine tools in the cellar.
Thread: New Lathe Tooling
19/11/2018 21:47:31
Posted by SillyOldDuffer on 19/11/2018 20:22:02:
Posted by Terry Kirkup on 19/11/2018 19:07:31:
Can anyone say if four beefy bodies will be able to carry a 290V through my garage and up the garden path to its new home?
That's pushing your luck. The lathe weighs 230kg, which is 57.5kg each (about 127lbs or 9stone). Roughly that's 4 men lifting 4 women. Do-able, but well over a comfortable lift that could be kept going for long. More is better if there's space - being an elderly weed, I had trouble lifting a 40kg mini-lathe on my own, my daughter and I lifted it easily.
Wow that's twice as much as the only slightly smaller 250V! And my mini-lathe was no where near 40kg either.....
When I bought my 250V I had it delivered to work, where it was unloaded with the forklift. I broke it out of the crate, and removed the tailstock, steadies, chuck and topslide. ! wound the carriage to the end of the bed to balance the weight.
Two of us then lifted it into the boot of my car.
I drove home.
Then, a friend and I lifted the lathe out of the car, carried it across the road, down the cellar steps, through the obstacle course and lifted it onto the bench. While that wasn't fun, it's not difficult or dangerous either. If I'd bought it ten years earlier when I worked in a warehouse, neither of us would have raised a sweat doing it. I don't have the space to use an engine crane to lift it onto the bench, and think it would be more work than lifting it on by hand.
Thread: ground silver steel round bar
18/11/2018 11:28:39
Posted by JasonB on 18/11/2018 10:08:22:
Don't forget the size of your hole will affect the "fit" just as much as the pin, most off the self reamers are H7 or H8 so your SS will be a sliding fit, you really want it a bit tighter for a dowel pin.
I did have a feeling that proper dowel pins were slightly plus on size.
Don't you want a very light press fit on one part, and sliding fit on the part you're going to remove(cylinder head for example)?
Thread: The new talking Mercedes
15/11/2018 22:56:12
Posted by Mick Charity on 15/11/2018 19:47:11:
I used to work in vehicle recovery & often got asked what's the best car to buy
Best answer was to pop in the workshop, count how many ramps, count how many fitters over the age of 17 then count how many spaces left in the rear car park. Add all these together then pop round to the local Mazda dealer & have a cuppa with their solo fitter
I used to get the same question, although my answer was slightly different:
I told them that we all went to the local Mercedes dealers on a daily basis, closely followed by BMW and Audi. The last year I worked, I went to Toyota dealers three times; one was a clutch wornout at 120,000 miles, another was an immobiliser issue and the third was a turbo fault on a diesel. The Korean manufacturers are pretty good too. My experience of modern German cars is that they are overengineered, under developed and surprisingly poorly built. Plus, they're horrible to work on.
Thread: AF socket sets. Are they extinct
11/11/2018 22:31:54
Posted by ronan walsh on 11/11/2018 17:07:25:
Well the metric is what you said the AF should be to imperial. 6mm threaded fastener, but a 10mm AF spanner.
That.
One of the things that make metric a pleasure to use is that there are no coded sizes that appear to have been created by a random number generator. Like number or letter drills, dash hose fittings, weird wire gauges or thread sizes.
