Member postings for Graham Titman
Here is a list of all the postings Graham Titman has made in our forums. Click on a thread name to jump to the thread.
Thread: Steel Machinists Tool Chest
25/03/2017 13:38:17
Hi if you are after a wooden chest you could try these no connection just a customer
Thread: Arduino Rotary Table MEW 249
15/02/2017 07:17:14
Thanks Dave i will give it a try later on Graham
11/02/2017 13:57:23
Hi thanks to the help from forum members i got my dfrobot keypad to work running a r/t but i then bought a sainsmart one for another project and in the house in the warm it seems to work ok but take it down to the cold workshop and make it work hard driving a small Emco milling head up an down in the run mode and it does what Roger Williams 2 does.Graham
Thread: What web browser
23/01/2017 14:39:10
Hi Firefiox on win 10
12/01/2017 07:13:56
Thanks Andy i will give it a try this afternoon.Graham
11/01/2017 19:47:44
Hello thank you everybody for your invaluable help i have just got both arduinos and the keypads to work after putting so many numbers to get the right hand key to work i arrived at
850 return no key
85 return right key
230 return up key
35o return down key
450 return left key
850 return select key.
The only problem now is even with a 24volt supply it only revolves at about 14rpm as i had hoped to drive a small mill head up and down with one of them with a 3 to 1 reduction Thanks again Graham
10/01/2017 21:12:39
Andy thanks very much i will have a try tomorrow .Graham
10/01/2017 20:19:27
Good evening thank you all for your help but you are talking a completely different language to one i understand on Johns diagram i can find the analog pin on the board i then i need a satnav my understanding of electronics is nil. I can follow a drawing the above means nothing at all.
Thanks Graham
10/01/2017 18:00:46
Hi i wonder if any one can help i have tried two Arduino Uno boards and two different DF Robot keypads and get the same result that the up and down left keypads go through the menu but pressing select makes no difference they just show the menus .I have downloaded the software on two different computers and get the same result.
Thread: MEW 250 Pocket Mags problems (again)
05/01/2017 14:09:56
I emailed them 2 days before christmas and am still waiting a reply although i did managed to sort it out myself.When you went to the help page it said it could not be found . On a different note how can i use the Mew archive without using adobe flash with windows ten and firefox i have tried two of the firefox add ons but they do not seem to work.Thanks Graham
Thread: Marchal
02/12/2016 18:05:48
Hello Mike they were available in the mid seventies i fitted one to a 750cc honda 4 the difference was unbelievable no wasted light above the handle bars and see where you were going at 70+
Thread: Beer engine
20/10/2016 20:58:02
You want the proper stuff not the commercial rubbish.A small farm in the heart of Gloucestershire a single track road you sit there quietly sipping your glass until he has blended it to your taste from three massive vats at the end of the bar,he then fills up your 5 gallon barrel and you get up and realize you could be very close to the drink drive limit.
Thread: I need something made, can anyone help?
07/10/2016 20:29:15
Hi Dan you could try these
http://www.rdgtools.co.uk/acatalog/Extension-Jump-Sleeves.html
and do what Ian suggested hope this helps Graham
Thread: Just Started a 4 inch Foster
05/09/2016 15:35:22
Hi Mike if you click this link it should take you to a page of the errors Jason was wrote about i don't think you have to log.
http://modeleng.proboards.com/thread/3225/errors-on-drawings?page=2
Graham
Thread: Aircraft General Discussion
24/07/2016 20:31:13
Hi Martin you should have gone yesterday there must have been 6 or 8 took off and flew low over the rally field,I have never seen so many stationary engines in one place according to the programme 180 plus.A good day out.Graham
Thread: LBSC Evening Star Boiler
07/05/2016 12:48:15
Hi there is a thread on the Model engineers clearing house which has quite a few errors on drawings that was started by the late Alan Stepney
hope this helps.Graham
Edited By Graham Titman on 07/05/2016 12:49:26
Thread: 'Maybe'of interest to some. (pic heavy)
07/04/2016 14:13:26
Hi Kwil i think they were for a firm call oxford instruments they came in to us as a bare casting and we machined them all over .Graham
07/04/2016 08:16:34
Good morning Nick excellent video brought back a lot of memories.I worked on Ward and Herbert capstans as a setter operator and occasional periods on a 36inch Webster and Bennet.We did work as diverse as tractor parts,Aston martin engine parts,special valves for buses and big 7foot dia ally castings for the early body scanners on a 72inch Webster and Bennet.At another company we did a lot of work for the local sewage company and using a 2inch pepperpot gas torch on big cast iron valves to remove the bronze seat left you with a smell never to be forgotten.Thanks Graham
06/04/2016 18:14:36
Thanks Nick a typical small machine shop of the sixtys and seventies i have spent many hours on the radial drill machining massy ferguson cylinder heads and axle assemblies on the bank of three drills no cranes to lift them up just muscle power,and bits of scrap material and components everywhere those were the days.More pics if you can Nick.
Graham
Thread: What Did You Do Today (2016)
05/03/2016 20:04:12
Parts for a Stirling engine to drive the Super Adept lathe
