Member postings for Sam Longley 1
Here is a list of all the postings Sam Longley 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Trouble at mill
20/03/2016 07:53:53
Changing the subject a bit ( apologies to OP) i noticed that he cut a circular indent in the steel
Probably a dead silly question but:
Forget clamping or material thickness for now - but how would one cut ,say, a 30mm diam sinking of only a couple of mm in the face of a flat steel. Would the method be to clamp in a faceplate & cut on a lathe or is there a way to get a circular shape that is not very deep with a non cad mill when the diameter exceeds end mill cutter diam
For example I might want to use the indent to locate something in a precise position but not have a hole right through
Edited By Sam Longley 1 on 20/03/2016 07:56:09
Edited By Sam Longley 1 on 20/03/2016 07:56:39
Thread: c 30 carbon steel
10/03/2016 16:52:52
thanks John
That is what i wanted to hear. I know i can buy reinforcing steel but when i had tonnes of it ( contractor) i found much of it difficult to turn in that it was poor quality. I suspect anything i make with this steel can be re hardened & give a good wearing product
09/03/2016 07:58:13
Being a beginner I have not built up a scrap box yet & I need a cheap source of metal to practice on. Annually I purchase a 1 tonne pallet of 19mm diam long link chain which I sell for moorings. I have to cut into short lengths so I end up with lots of half links. I have noticed that if I cut the links on one side each time I get a length of near straight steel about 3.25 inches long.*3/4 diam
I tried turning a piece but it is very hard & the best tool for cutting seems to be tungsten tipped tools
The chain is specified as C30 carbon steel & in manufacture gets welded at the join. ( I cut my piece from the opposite side to the weld) so has some form of heat treatment in manufacture
What my beginner question is - If I go ahead & build a forge ( I have been thinking of having a go at casting aluminium) could I heat the steel & anneal it to make it softer , or will it always remain hard due to the carbon content?
Thread: Brain Teaser
06/03/2016 16:39:59
Posted by Phil Whitley on 06/03/2016 15:14:30:
Tube is a hollow structural member of any shape or section..
In the construction industry we would not call that tube but either RHS ( round hollow section) or SHS (square hollow section ) etc etc -we certainly would not call it tube in the context you suggest
I cannot recall ever using  the term "square tube" in the construction of structural units. Although I admit we would refer to "tubular structures" in context of describing components in  lattice roofs etc made from hollow sections
Edited By Sam Longley 1 on 06/03/2016 16:41:31
Edited By Sam Longley 1 on 06/03/2016 16:41:58
Edited By Sam Longley 1 on 06/03/2016 16:44:43
06/03/2016 16:29:25
Tube is a hollow structural member of any shape or section.. Because it is used in construction, its most important dimensions are the external dimension, and the wall thickness as an indicator of structural strength.
Pipe is used to convey liquids or gasses.and because of this use, the only important dimension is the internal size, which gives an indication of the carrying capacity of the pipe, and the wall thickness, which gives and indication of the internal pressure the pipe will withstand.
Whilst pipe and tube are in a sense interchangeable terms in conversational English, in engineering the use of the term"pipe" for a hollow structural member, and tube for something that carries a liquid or gas, used to result in a thick ear for the errant trainee or apprentice.
Wanders off mumbling under breath about falling standards and the kids of today etc etc...................................
You have clearly never used copper pipe for plumbing where ( for instance) you have table X,Y or underground ( think that is it - its been a long time) all with different wall thickness but the same external diameter to suit a standard copper fitting. Changing to wavin flow plastic pipe the outside diam is kept at the same outer dimension as equivalent copper ( ie 15mm etc) but the wall thickness is greater
So that blows your theory out the waterangry 2
But as the Monty Python team said ", try telling kids of today that-- they will never believe you !!!!"
Edited By Sam Longley 1 on 06/03/2016 16:31:38
Thread: Pulley wheels I think‽
06/03/2016 07:32:34
When I first read the post i assumed that the 44 was a miss print & you meant 440mm not 44. Hence my reply was not relevant. Apologies
Edited By Sam Longley 1 on 06/03/2016 07:42:15
05/03/2016 16:49:59
Posted by pgk pgk on 05/03/2016 09:01:49:
I asked this question locally. Best answer:
"Well pipe is like for water and tube for Smarties. End of."
I also learned that you snort coke through a tube but smoke crack in a pipe
Our local junkie always seems to have a straw stuffed up his nose. Never seen him with a tube!!!
05/03/2016 06:21:20
Are you describing plummer blocks & shaft
If so then as a starter try http://www.arvis.co.uk/products.php?product=33
then start googling around that
I do recall seeing saw table sets years ago which had a shaft mounted on 2 plummer blocks & machined to take pulley one end & sawblade the other. Try J & M Belts or a bearing supplier & they may be able to source a suitable set
04/03/2016 21:05:20
Posted by dave george 1 on 04/03/2016 19:46:16:
Just to throw a spanner in the works.. what about scaffold pole.. is that pipe or tube.. ive never heard of a scaffold tube or scaffold pipe
Being a builder I have always referred to scaffolding as tube, as do most scaffolders. Scaffolders rarely call them poles. To support my earlier claim i used to have a lot of scaffold tube that had a butt joint instead of a seam. Have not seen any for years though
04/03/2016 18:09:02
Posted by Trevorh on 04/03/2016 16:31:45:
but sam you are forgetting that you can get seamless pipe in stainless - I use it for my solvent installations, and I think there is also the seamless Black pipe
cheers
You have just confirmed it - seamless is pipe
Jointed or just butted at manufacture is tube
04/03/2016 16:25:23
It is to do with manufacture. tube has a seam - albeit welded after manufacture- pipe is extruded
So your copper pipe is extruded & your steel pipe will have either a butt joint or a welded seam
Thread: Dismantling a Universal Joint
03/03/2016 17:11:55
I had to machine 8 UJ's for my moulding machine in my workshop. They each took drives from 3 HP electric motors so were larger than yours I expect. they came with 10mm holes & had to be increased to 15mm with a woodruf key slot
I had nothing to do the key slot so tried a bodge which may be of use to you if you have to put in a key slot.
I worked out where the circumfrence of the hole came & on the circle I centred a 10mm drill & bored a hole.
When I drilled out the 15mm hole ( may have been 18mm memory a bit slow these days) I was left with a semi- circular slot/groove . The woodruff key in the motors stood up about 5 mm so by grinding a round on that half of the key I was able to assemble it. The machine worked daily for the next couple of years machining 1000's metres of timber.
For the model engineer it must be easier to broach the slot if partially cut out. One would only be taking the corners out of the groove. I mention this because I have never seen it written before & expect that it could be adapted on UJ's with the full hole already cut by sticking a sacrificial plug in the hole & drilling down the join to get the same effect.
I expect that the purist will sigh, but it saved me blowing £ 30K for a new moulder for 2 years !!!!
Thread: Advice sought
02/03/2016 17:43:25
Have you tried a bent coat hanger through the window rubber to hook the door lock. I used a fence wire once & hooked the one on the OPPOSITE side as you can get more of an angle to stop the wire slipping off. Or an icing knife ( nick that from the missus) down the side of the passenger window
Why not see if you can find a door in a breakers & see how the lock works so you know here to hook it. May even get a diagram off the internet.
If it is a 4 door then the rear passenger door may be the one to try as that may have easier access as most thieves go for the driver's door & manufacturers make that part the hardest to access if they can. Are the rear windows electric or manual?
Can you get something in the side door between glass & metal & force the window mechanism rather than the lock so the window drops down an inch
Have you got underneath & looked to see if the rad comes out so you can access the bonnet catch
How does the headlight glass come out? can you get access to the engine compartment & get a jump lead on the battery from there
Edited By Sam Longley 1 on 02/03/2016 17:45:51
Edited By Sam Longley 1 on 02/03/2016 17:47:01
02/03/2016 17:31:54
Posted by NJH on 02/03/2016 17:29:05:
Oh Sam - ye of little faith! I can assure it is mine - I bought it new in 1998. I will report progress ( and the cost to my wallet) in due course!
N
Yes your honour
02/03/2016 17:17:28
Posted by Robbo on 02/03/2016 09:12:58:
Posted by Sam Longley 1 on 02/03/2016 05:22:45:
Just stick a brick through the front windscreen & claim a new one on the insurance policy
(Wind screen that is - not brick)
And pay the compulsory excess??
Edited By Robbo on 02/03/2016 09:14:39
Still the cheapest & quickest way out though. Would have been in the car & driving by now !!!!
Has anyone considered that the OP may not actually own the car but just wants to nick it?????
That would leave egg on the forums face I suspectembarrassed
02/03/2016 05:22:45
Thread: Warco milling cutters & carbide tooling tips
28/02/2016 20:58:13
I have a set of milling cutters & chuck for my Warco 250MV. purchased direct from Warco. as part of the lathe package
I cannot see similar cutters ( part cut out flange on the end opposite the cutting end) on any other web site & wonder if the Warco chuck etc that I bought is a Warco only item & I cannot buy cutters & collets elsewhere
Does any one know what sort of cutter they are - ie is there a special description for them & who sells them other than Warco
In the same vein the carbide inserts on the set of indexible tooling they sold me do not seem as good as an old indexible tool tips that I used with my last lathe. Are the tips interchangeable with other makes & if so can anyone tell me what code etc I should be looking for & if any other makes of tip will improve performance
Any help much appreciated
Edited By Sam Longley 1 on 28/02/2016 20:59:33
Edited By Sam Longley 1 on 28/02/2016 21:00:30
Edited By Sam Longley 1 on 28/02/2016 21:02:13
Thread: High speed steel
27/02/2016 20:11:20
Mine are marked HSS but I assume that there are percentages of colbalt etc in the composition of tool steel
Seems I will have to make a holder for a 20mm blade & hope that the planer steel is OK. I cannot see exactly how to test safely without holding them on edge. Excessive grinding might not be good thing although I do not really know.
Any ideas how to test it first before I source some steel & make a holder
Edited By Sam Longley 1 on 27/02/2016 20:13:29
Thread: Specifying/making a rack
27/02/2016 18:10:36
Just checked my Sealey bench pillar drill. This has a rack for the table which is about 15 inches long although the rack part is 9 inches & same tooth pitch as yours. Other dims the same.
It is a loose fitting that is held in a ring at the base & another at the top. It rotates around the pillar as the table is moved from side to side
This would lead me to suggest that you look at a Sealey floor standing model rather than a bench one & you may be able to buy a long rack as a spare part. You may even find that Clarke do a similar thing
27/02/2016 17:50:02
I have found a bundle of old HSS planer blades. I also have some serated backed moulding cutters about 8mm thick & 70mm * 70mm
Would they be the same steel as HSS cutters used in a lathe?
The planer blades are 3mm & vary 20-35 wide * 600mm long & would make cutoff blades if I ground the sharp splay off & clamped in a holder
