High speed steel
Sam Longley 127/02/2016 17:50:02
965 forum posts
34 photos
I have found a bundle of old HSS planer blades. I also have some serated backed moulding cutters about 8mm thick & 70mm * 70mm
Would they be the same steel as HSS cutters used in a lathe?
The planer blades are 3mm & vary 20-35 wide * 600mm long & would make cutoff blades if I ground the sharp splay off & clamped in a holder
Neil Wyatt27/02/2016 18:27:58
19226 forum posts
749 photos
86 articles
Possibly, they may not be quite as long lived, but thanks for the thought - I have a random planer blade that's been looking for a use for years! Not sure if its HSS though.
Sam Longley 127/02/2016 20:11:20
965 forum posts
34 photos
Mine are marked HSS but I assume that there are percentages of colbalt etc in the composition of tool steel
Seems I will have to make a holder for a 20mm blade & hope that the planer steel is OK. I cannot see exactly how to test safely without holding them on edge. Excessive grinding might not be good thing although I do not really know.
Any ideas how to test it first before I source some steel & make a holder
Edited By Sam Longley 1 on 27/02/2016 20:13:29
Roger Provins 227/02/2016 20:24:28
344 forum posts
Spark testing to identify different metals can be very informative - as well as fun.
http://www.scrapmetaljunkie.com/241/the-spark-test-and-spark-testing-metals-2
https://www.youtube.com/watch?v=D094eBa4S7c
Neil Wyatt27/02/2016 20:58:35
19226 forum posts
749 photos
86 articles
You could put one on its side, packed up in the toolholder to centre height. Bearing in mind it will have no top rake, try taking a light cut in steel, if it bears up it will work OK when ground to a proper profile.
Wear goggles in case it snaps.
neil
Frances IoM27/02/2016 22:17:09
1395 forum posts
30 photos
deleted as misread message
Edited By Frances IoM on 27/02/2016 22:21:43
John Stevenson27/02/2016 22:27:29
5068 forum posts
More than likely HSS or HSSC.
Last place I worked at, piano factory I used to save the 36" and 48" blades off the planers and grind them up into Eclipse type parting off blades.
I make a 4 sided block to hold them on the sticky table on the surface grinder so I could put the top and bottom holding angle and then about 5 to 8 degrees on one side so when in an angled holder it was an equal 2.5 to 4 degrees clearance either side.
Still got the jig somewhere and also still got a load of spare blades in 4" lengths.
Hardly use them now as moved on to tipped tools but they did good service in a home shop when I had more time and didn't have to rush as much.
