Member postings for HomeUse
Here is a list of all the postings HomeUse has made in our forums. Click on a thread name to jump to the thread.
Thread: Editors Deliberate Mistakes
17/01/2015 12:00:28
Think my Super is greyembarrassed
17/01/2015 08:54:45
Just viewed latest M E W and was happy that the main feature on front page is “Drive to saddle of a Super 7”
Is there not a differance between the 7 and the Super 7 ?crook
Thread: seig SX3 dead???
01/01/2015 11:59:19
Seems to hav corrected itself on page 2
Thread: Connectivity Issues
19/12/2014 10:06:04
No faster for me - mind you I never had any problemscrook
Thread: Suitable primer for painting aluminium?
02/11/2014 09:35:13
Zink Chromate primer is available on EBay and in many D I Y shops - would recommend for use on alloyyes
Thread: Trouble with M2 thread
20/09/2014 09:51:05
Never had any problem but I always use a 1/16” drill (I have a lot of them) and they always seem to drill oversize so seem to give the correct engagement
Thread: Favourite Engineering quotes.
18/09/2014 09:46:14
A quote from an old engineer “ If it don’t knock a bit and don,t rattle then it aint going proper” - He worked on Steam and first age Gas Oil
Thread: Backyard Casting
08/09/2014 08:53:14
This link is good for anyone contemplating home casting
http://www.backyardmetalcasting.com/index.html
Good crucibles can be made from empty “non refillable CO2 (disposable) cylinders cut in half - use bottom end - Take care when releasing any pressure left in cylinder
Thread: steam locomotive valve gears II
09/08/2014 09:39:00
The only problem I have had with the software in your link is that it won’t work on “Apple” frown
Thread: Aluminium Rod
16/07/2014 08:35:47
Had some similar but 1inchx1/4inch rod - marked PURE-D - used by electrical engineers to “solder” underground cable joints. A case was clipped over the spliced wire joint and molten aluminium was poured in.
Think the stamp means that it is “pure”
Hope this helps
Thread: Festive Port Pourer
26/06/2014 09:22:54
Peter Hall’s link - It should have a live steam engine (compound of course) with “Mill” type boiler
And of course a ready supply of “vino”
Thread: Any model engineering clubs in Mid Wales?
04/06/2014 13:54:23
This may be useful http://www.modeleng.org/ukclubs.htm
Thread: New to Model Engineering
04/06/2014 13:52:56
Thread: Superheater
09/05/2014 10:57:15
Normally they are set up for the steam to enter into the inner pipe and exit as superheated from the outer - one design I seen had spacer blocks soldered to the inner to give spacing and support inside the outer - the outer had end caps that had small longitudinal fins that gave positioning in the boiler tube (Design seems to originate in Spain)
Thread: Using a die to cut a thread on brass/copper pipe.
08/05/2014 09:16:28
Hi - Just a thought - have you tried a mic. on the tube to make sure it is in fact 3/16 and not 5mm - I had similar problem with on line supply of copper rod (3/16 listed and ordered but 5mm sent)
06/05/2014 08:02:57
A tip for threading/drilling copper - use full cream milk or single cream for lubrication - commonly used in past times. Make sure all residue is washed away as the acid in milk (lactic) will damage metals (and cement based items)
Edited By HomeUse on 06/05/2014 08:04:43
Thread: Soldering Hot rolled mild steel
01/05/2014 18:14:32
Try dilute Hydrochldoric acid (Brick cleaner) to clean steel sheet - wash off with clean water and coat joint area with Borax paste - clamp in position and heat to just under cherry red and apply Silver Solder to edges of joints - solder will flow towards flame/heat position (Capillary action) - let cool normally - DO NOT COOL IN WATER - causes brittal joint
Thread: Rhombic Stirling Engine
01/05/2014 18:03:00
Been looking thro. scrap box - found bit of thin wall coper tube with heavier copper end that could have been the cap from the one i was building - Internal dia is 1 1/2 inch and about 2 inch long with a flange on the open end.
Might be something from another project - can’t remember - Might need some brain lubrication to remember
30/04/2014 11:15:47
Can remember it as started to build one - thought it was 1981/2 - about the same time as the 2 1/2 inch gauge Flying Scotsman was serialised (I did build the Loco smiley but not finish the Sterling engine sad)
Thread: Lost wax casting
19/04/2014 11:08:11
Hi - This site is quite interesting for anyone interested in melting metals
Unfortunately there is not much about lost wax casting
