Centre drilling 20mm diameter long bar that won't fit through the mt2 head
Chris Richards 3 | 16/09/2014 08:49:40 |
68 forum posts 13 photos | Hello, I am new to the forum and have just bought a Myford Super 7 which I was hoping would replace my slightly worn Boxford. I have noticed the spindle bore is really small on the Myford so the question is how could I accurately centre drill 20mm round bar 240mm long? Maybe sounds a daft question but I was used to placing bar through the spindle and only have about 10mm exposed from the chuck to dial it into centre and then drill. Any suggestions/ advice would be great otherwise I'll have to trade the myford for something slightly bigger. Thanks, Chris |
David Colwill | 16/09/2014 09:54:04 |
782 forum posts 40 photos | The usual way would be to use a fixed steady but if you have to do this regularly it would be a bit of a faff. Regards. David. |
Brian Wood | 16/09/2014 10:13:40 |
2742 forum posts 39 photos | Hello Chris This works well with the appropriate accessories. Length and diameter [within reason] are not a problem Regards Edited By Brian Wood on 16/09/2014 10:15:04 |
Harold Hall 1 | 16/09/2014 10:20:04 |
418 forum posts 4 photos | Again I would suggest a look at my web pages on using a fixed steady, as per David's method. Look here for the appropriate page, Harold |
Chris Richards 3 | 16/09/2014 19:50:23 |
68 forum posts 13 photos | Thanks for the reply's it looks like a steady is an essential part for the Myford that I don't yet have. |
Nobby | 16/09/2014 22:03:32 |
![]() 587 forum posts 113 photos | HI Richard & Guy's |
NJH | 16/09/2014 23:45:54 |
![]() 2314 forum posts 139 photos | Chris You could make your own - see HERE You will need a facility for milling but otherwise it's pretty easy. Norman |
john kennedy 1 | 17/09/2014 06:35:32 |
![]() 214 forum posts 24 photos | A quick and dirty solution is to clamp a chunky piece of wood to the cross slide and drill/bore to bar size from the head stock. You can always slit it to the center with a couple of screws to clamp it. Seeing as you are only centering there will be little or no radial load. Will do for a one off job. |
steamdave | 17/09/2014 13:38:38 |
526 forum posts 45 photos | Posted by Brian Wood on 16/09/2014 10:13:40:
Hello Chris This works well with the appropriate accessories. Length and diameter [within reason] are not a problem Regards Edited By Brian Wood on 16/09/2014 10:15:04 Like that idea, Brian. Dave |
Brian Wood | 17/09/2014 13:58:34 |
2742 forum posts 39 photos | Hello Dave in the Emerald Isle, Thank you, but the idea isn't really that novel. It was a furniture commission job, the bars were 16mm grade 304 stainless steel 800mm long, to be drilled and tapped M4 at one end, there were I think 12 such bars to do. It worked very well, the steady at the tailstock end was only there as a loose support, all the thrust for drilling came from the X slide. Setting up was a doddle using the co-axial indicator which allows viewing from one side over a full rotation around the work. It had been a christmas present to myself the previous year. I did test it against the more traditional method with a finger DTI, using a mirror to view the difficult sides; there was really no contest. Regards Brian |
