ALDI multipurpose saw
Michael Cox 103/09/2014 14:56:46
555 forum posts
27 photos
ALDI are selling their multipurpose saw again starting Sunday 7 September.
This is a good piece of kit that will cut through up to 6 mm sheet steel with ease and leave a good edge. The saw is only £29.99 which is considerably cheaper than other metal cutting circular saws. Spare blades are also available at £4.99
I have reviewed the saw here:
http://mikesworkshop.weebly.com/work-zone-multi-purpose-saw.html
No connection with ALDI other that as a satisfied customer.
Les Jones 103/09/2014 20:08:56
2292 forum posts
159 photos
Hi Mike,
I also found that the blade works well as a slitting saw. I used it mounted in my X3 mill to cut the slit when I was making your design of table for my bandsaw.
Les.
Michael Cox 104/09/2014 09:14:50
555 forum posts
27 photos
Hi Les,
I know that John "Bogstandard" has an Evolution Rage saw mounted for use as a slitting saw and that this worked very well. This blade is very similar to the ALDI blade.
I hope the bandsaw table works out well for you. It is surprising how many times the vertical mode is used when it is only a question of flipping the table into position. Prior to the flip down table I hardly ever used the vertical mode.
Gary Wooding04/09/2014 09:45:17
1074 forum posts
290 photos
Hi Mike,
Some years ago I purchased an APTC115 bandsaw, which, because of space limitations remained in its packing case until recently, when I finally assembled it. The packing included the original receipt - dated 27/01/1997. Yes, that's right, its been languishing in its case for 17 years!
It works fine, but because it didn't come with the vertical table I need to make one. Is it possible to see your design?
Gary
Michael Cox 104/09/2014 12:34:03
555 forum posts
27 photos
Hi Gary,
Have a look on my website **LINK** and click on bandsaw modifications. Also on the yahoo 6 x 4 bandsaw group there are some drawing for the hinged table.
I hope this helps. If you have any problems then get back to me.
Les Jones 104/09/2014 20:20:14
2292 forum posts
159 photos
Hi Mike,
The table works very well and is much more convenient than the original table. The only modification I made was to add a magnetic catch to hold it in the position for using the bandsaw normally. I went a little OTT machining the radius on the edge of the plate.
Milling a radius on the edge of a 6mm plate
Note the tailstock supported the end of the plate while machining but was removed to take the picture.
Les.
Engine Builder04/09/2014 21:51:27
267 forum posts
Neat use of the drilled block for workholding, I like it!
Les Jones 104/09/2014 23:12:43
2292 forum posts
159 photos
Hi Engine Builder,
Here is another setup using a 1"-2"-3" block to machine the V groove in a jig for sharpening tangential tool bits.
Les.
Diane Carney04/09/2014 23:29:42
419 forum posts
11 photos
Going back to the OP: I have also heard that Aldi are selilng a 1200 watt Ash Vacuum for £29.00. Perfect for smokeboxes and woodburners!
Diane
Engine Builder05/09/2014 08:47:35
267 forum posts
Thanks Les for the pic, I had not considered using the blocks for lathework holding. I must put some on my Christmas list.
Gary Wooding05/09/2014 09:15:58
1074 forum posts
290 photos
Thanks Mike, I'll certainly make one - I like the seat too.
Gary
Ray Lyons05/09/2014 09:56:04
200 forum posts
I have had one of these saws for some time and would recommend using full protective gear when using because the shrapnel gets everywhere. Full face mask and gloves at least.
I think I have become an ALDI/LIDL addict. My reliable and ancient VAX lost a wheel, not a disaster but enough of an excuse so a few weeks ago, I bought a wet/dry vacuum cleaner from LIDL. This has all the fittings for the shop/car. I like the additional power socket for power tools and when used, flick the switch over and the vacuum responds to the power tool use. I used it on Wednesday on my thickness planer and when finished, the drum was full to overflow, enough for a half fill large plastic bag. From now on I think it will be used more in the workshop than the home.
Having acquired so much shavings/sawdust which has a limited recycling value, I saw that ALDI were selling one of those waste paper log makers and yesterday, I bought one. I thought that perhaps a mixture of wood shavings and shredded paper would make useful fuel for a wood burner. The next job will be to get a woodburner for the shed.
With winter coming on, I wonder if ALDI or LIDL will put a workshop stove on their specials.
Engine Builder09/09/2014 17:32:02
267 forum posts
My nearest Aldi is about 30 miles away so combined with a day out I called in and picked up a saw and a couple of spare blades.
I do a lot of aluminium casting and use alloy car wheels for the doner metal. Cutting them up is not easy. I have an Evolution saw which cuts through the thinner sections like a knife through butter but the teeth get clogged and when they are cleared can break off easily so it's quite expensive on blades.
I have tried the special thin aluminium cutting discs in an angle grinder but the discs wear quickly.
I thought I would give the Aldi saw I try. I was a little disappointed at first as after a couple of cuts the spring return on the blade guard came off exposing the blade. I found a replacement spring in workshop though and it's fine now.
I am very pleased with the saw's performance for my purpose. It is slower than the Evolution but I have just cut up a complete car wheel and all the teeth are still on the blade.
Not sure if blades are easy to get in the future,bu there is a connect email and phone number on the literature.
David Colwill09/09/2014 19:30:11
782 forum posts
40 photos
Thanks for the heads up on this. I now own one which will be used for chopping wood up for the wood burning stove and other jobs. I also bought some spare blades and noticed that they say wood , plastic and soft metals. I would take this to mean non ferrous. The blade look the same. Any thoughts?
Regards.
David.
