Rai Liiv | 02/09/2014 10:46:52 |
4 forum posts 3 photos |
Thank you for any help. Cheers |
Ian Parkin | 02/09/2014 12:53:13 |
![]() 1174 forum posts 303 photos | Its a micrometer stop that goes before the saddle near the headstock and stops the sadlle at a point set by the rod sticking out |
Rai Liiv | 02/09/2014 13:26:25 |
4 forum posts 3 photos | Hi there Thanks for that - do you know what kind of lathe it is from or is it a universal device? Cheers Rai |
Hacksaw | 02/09/2014 19:25:12 |
474 forum posts 202 photos | Slightly off topic...sorry for hijack etc ! I want something like this ! But ?? If you're, say using power surfacing feed ( Smart &Brown model M) , when the saddle contacts the stop, is there a clutch/slip mechanism in the power drive somewhere ? Or should I chicken out and do the last bit of surfacing by hand ? |
Robbo | 02/09/2014 19:27:54 |
1504 forum posts 142 photos | Micrometer saddle stops like this were/are available for a wide range of lathes. Boxford use one similar to this, which looks as though it clamps onto a 'V' shaped bedway, but the Boxford ones I have seen are smaller, having only one clamp bolt where this has two. Maybe a different version. Perhaps from a Colchester? Edited By Robbo on 02/09/2014 19:29:38 |
Neil Wyatt | 02/09/2014 21:19:15 |
![]() 19226 forum posts 749 photos 86 articles | Rai An end view and something to give a scale may help identify the lathe it's for. Given the apparent age it's probably for an American lathe as most UK ones of that vintage had flat beds. HI Hacksaw, > is there a clutch/slip mechanism in the power drive somewhere 1 - Probably not, although some lathes have this feature it would be obvious as there are lots of trip levers etc.. > Or should I chicken out and do the last bit of surfacing by hand ? 2 - Yes. |
Les Jones 1 | 02/09/2014 21:40:14 |
2292 forum posts 159 photos | Hi Hacksaw, Les. Edited By Les Jones 1 on 02/09/2014 21:44:31 |
Hacksaw | 02/09/2014 22:31:42 |
474 forum posts 202 photos | High speed screwcutting !! Cripes I couldn't do that....I buy threaded rod in Scats instead . Jesting aside , I have seen in ME various trip linkage desigs for Myfords , but none of my disenage levers/knobs seem suitable for a quick knock off . I could make one of those /\ /\ gadgets out of an old mic though... |
Les Jones 1 | 02/09/2014 22:46:15 |
2292 forum posts 159 photos | My lathe is not a Myford but is uses a similar lever arrangement to engage the half nut so it should be possible to modify the idea to fit. I may also use a lazy way of doing the same thing by having the feed lever spring loaded in the disengaged position and using an electro magnet to hold it in the engaged position. It would only then need a DC power supply and a micro switch as a limit switch. When the limit switch was actuated it would remove the power from the electromagnet and the spring would then disengage the feed. Les. |
Hacksaw | 02/09/2014 23:08:12 |
474 forum posts 202 photos | Now thats food for thought... .I have some metal roller microswitches from a garage door opener .... and a 24v motor brake electromagnet... thinking cap on ! |
WALLACE | 02/09/2014 23:42:29 |
304 forum posts 17 photos | I reckon it's from a Harrison L5 or 5A - it looks very familiar ! If you keep an eye on the saddle as it approaches the stop, it's easy to drop the auto feed lever while keeping your left hand on the saddle hand wheel to just take up the final 20 thou or so before it hits the stop - assuming you're not using high roughing feeds. Best to try and keep the saddle moving without stopping otherwise you get a slight mark on the work piece - well, at least I do ! W. W. |
John Stevenson | 03/09/2014 00:48:14 |
![]() 5068 forum posts 3 photos | Well I can't tell you what it came off but I modified an identical one to fit my CVA lathe.
Just visible in this picture |
Nicholas Farr | 03/09/2014 08:55:36 |
![]() 3988 forum posts 1799 photos | Hi, definitely a saddle/carrage stop, there is a photo of a Boxford one in this **LINK** the little knerled screw at the top is for locking the rod in position once it is set. I would think it would work on any lathe that would accomodate the V or could be modified like the one in John's photo. Regards Nick. |
Rai Liiv | 07/09/2014 09:21:54 |
4 forum posts 3 photos | Hi there Well! I have finally found it! It is a Harrison micrometer carriage stop and the photo, taken from the site http://www.lathes.co.uk/ and many thanks to them, is specifically on a Harrison L5. I have it on EBay at the moment and I thought it was some kind of mini tailstock that could be fitted to the main bed somehow. Ah! Well. All's well that ends well! The link to the page is here - http://www.lathes.co.uk/harrison/page19.html - for more photos. Many thanks to all those who gave time. Cheers Rai |
Chris Trice | 07/09/2014 10:26:29 |
![]() 1376 forum posts 10 photos | Hmmm... Powerful electomagnets and swarf. This should prove interesting. Edited By Chris Trice on 07/09/2014 10:27:04 |
Chris Denton | 07/09/2014 13:02:59 |
275 forum posts | I need one of these for my Harrison. How much do you want for it? |
Rai Liiv | 07/09/2014 13:27:59 |
4 forum posts 3 photos | Hi Chris I do not want to get in any trouble for 'spamming' a forum but it is on EBay at the moment under 'lathe attachment - mini tailstock'. So, as you can see from my title I did not know what it was and that is why I joined this forum and started this thread. I always let my articles go to complete auction so cannot make you an offer. Cheers Rai |
Chris Denton | 09/09/2014 09:08:07 |
275 forum posts | Hi, I forgot to bid! If the buyer doesn't come through then let me know please. |
