Myford bearing taper
Articles
Lathe Bearings
Lathe Bearings
In The Model Engineer, issue 2427 of November 27 1947, E.H. Doughty, then Chief Technical Engineer of British Timken Ltd. wrote a lengthy technical letter to refute and address some of the adverse comment that had been made about roller bearings.
Neil Wyatt17/08/2014 20:19:47
19226 forum posts
749 photos
86 articles
I'm planning to make an accurate spindle running in plain bearings. I want to use a small version of the Myford -style tapered front bearing. This seems to be the best and simplest way to make a plain bearing adjustable for wear/play without using a split bearing. Can anyone tell me what the Myford taper angle is?
Brian Wood18/08/2014 09:53:37
2742 forum posts
39 photos
Hello Neil,
2 degrees and 25 minutes inclusive. Source Tubal Cain Model Engineer's Handbook 3rd Edition
Emgee18/08/2014 10:13:18
2610 forum posts
312 photos
Hi Brian
Viewing the picture of a spindle at CotswoldsPhil album
http://www.model-engineer.co.uk/albums/member_photo.asp?a=33350&p=542106
makes me think itis greater than 2deg25min taper.
Emgee
Edited By Emgee on 18/08/2014 10:13:51
Edited By Emgee on 18/08/2014 10:15:59
Brian Wood18/08/2014 10:27:49
2742 forum posts
39 photos
Hello Emgee,
I was only quoting what the great man had published, but I agree with you; checking Morse taper standards shows the half angle for say 2MT is not far away from half that value..
Maybe the figure should have been for the half angle, running a taper as fine as MT would grab and lock up in moments.
That would make the bearing taper Neil needs to be 4 degrees and 50 minutes, more in the category of self releasing too. Well spotted!
Regards Brian
CotswoldsPhil18/08/2014 10:29:29
196 forum posts
112 photos
Hi,
That's my picture uploaded just last week - glad to be of service. If the spindle was still on the bench I could check it for you. Just with a protractor over the picture says it's more like 20' inc.
Phil H
Brian Wood18/08/2014 10:41:32
2742 forum posts
39 photos
Hello Phil,
Tubal Cain's book could have a typo then, that would make the angle 20 degrees 25 minutes---it makes a lot more sense at that. I have in the past taken my spindle out and from memory it is as you say, a much steeper taper.
Sorry Neil, it's all looking like a bugger's muddle now, maybe someone else can weigh in with a correct answer.
Regards Brian
Neil Wyatt18/08/2014 10:51:15
19226 forum posts
749 photos
86 articles
I forgot it was on the mandrel nose drawing!
The great man was pretty good at getting confused about half-angles.
I spent a good while trying to check out the formula on page 3.1, (3rd edition), where x should be radius not diameter and the formula will then give the correct single-sided taper, not taper on diameter.
He doesn't seem to have registered that 2 * tan (theta/2) is not the same as TAN (theta), although the error at small angles is... small.
I was thinking about an included angle of about 5 degrees or 1 in 10. That would make it easy to adjust running clearance - a 20tpi thread for the thrust bearing adjustment would give 5 thou adjustment per turn. Assuming a precision run fit of 0.001", that would be 10 thou away from locking up.
Problem is that bigger angles are more critical for the adjustment.
More thought needed!
This is for a new headstock for a Super Adept by the way, aim is to make it a BGSC lathe. The existing spindle has 2 thou of wear and the front bearing has been cracked during an attempt to adjust it out. The bearing centreline drops by about 1/8" at the tailstock over the full length of the bed.
Other alternatives are small roller bearings or magneto bearings, but these all seem to have excessive OD's of about 1 1/4" to pass a 1/2" spindle, which is needed to accommodate an 0MT taper.
Michael Gilligan18/08/2014 11:04:11
23121 forum posts
1360 photos
Posted by Neil Wyatt on 18/08/2014 10:51:15:
Now there IS a surprise !!
John Stevenson18/08/2014 11:40:15
5068 forum posts
Well if I had know it was for a sooper non-adaptable lathe I wouldn't have bothered reading this post............yawn.
Neil Wyatt18/08/2014 13:09:51
19226 forum posts
749 photos
86 articles
I knew there'd be trouble if he found out!
It's alovely set of castings from which to make a small lathe!
Michael Gilligan18/08/2014 13:43:40
23121 forum posts
1360 photos
Posted by Neil Wyatt on 18/08/2014 13:09:51:
I look forward to seeing what can be done.
Although the single taper is perfectly viable, you might like to consider the "double cone" arrangement that was commonly used on Geneva Pattern, and early Webster Whitcomb lathes. [see here for a couple of good cross-sectional drawings]
These are usually hardened steel on hardened steel, but I'm sure that other material combinations would work too.
The idea is that the steep taper takes most of the thrust, and allows the other taper to be very shallow without risk of it sticking.
Edited By Michael Gilligan on 18/08/2014 13:52:20
Neil Wyatt18/08/2014 14:10:14
19226 forum posts
749 photos
86 articles
I know the double taper arrangement. My congratulations to anyone who can turn a mating double-taper bush and spindle to the required accuracy. I won't be joining them!
Robbo18/08/2014 22:17:55
1504 forum posts
142 photos
Neil,
I can't do spot-on measurements today, as have got the tremors - the joys of old age!
But a measure with a vernier on an old S7 spindle shows approx. a 10.3mm difference in diameters end to end of the taper, over an axial distance of 57mm.
You can probably work out the probable taper from that - sines, cosines, tangents etc are just something listed in the back of my book of logarithms to me.
Phil have corrected all the typos - and there were many.
Neil Wyatt19/08/2014 11:25:33
19226 forum posts
749 photos
86 articles
Thanks Phil,
That works out at about 1 in 6, or 1 in 12 on each side. I was looking at 1:10 but this made the front of the bearing a little thin for comfort, so 1:12 it will be.
Michael Gilligan19/08/2014 15:09:05
23121 forum posts
1360 photos
One inch in the foot is a very Imperial sort of Taper
Yes ... It seems very likely that Myford would have used it.
P.S. Neil ... are you retaining a 3/8" spindle diameter?
or is the rear bearing worn also?
Chris Trice19/08/2014 16:16:15
1376 forum posts
10 photos
I've got a spare Super 7 spindle here and just carefully eyeballing it, the taper I get is 12.5 degrees inclusive or 6.25 from the axis. If you're making your own spindle and bearing, I don't suppose it's critical.
Chris Trice19/08/2014 16:17:30
1376 forum posts
10 photos
That figure was got by transferring straight lines onto a piece of paper and then measuring it with a protractor.
Chris Trice19/08/2014 16:20:04
1376 forum posts
10 photos
Tubal must've missed a "1" off the start of his figure.
Neil Wyatt19/08/2014 17:23:46
19226 forum posts
749 photos
86 articles
Darn it!
I seem to have lost a long explanation of how I intent to go about constructing the headstock.
I'll do some drawings, maybe try a 3D model...
Chris Trice19/08/2014 23:32:28
1376 forum posts
10 photos
Based on your first post Neil, you appreciate that any thrust towards the headstock is actually taken by the angular contact ball races? I hope I'm not insulting anyone's intelligence but the comment about Morse taper angles doesn't make any difference because the taper plays no part in resisting movement along the bed. It's purely there so the running clearance can be controlled.
