Does anybody own a Sieg Nano Lathe ?
Brian John09/07/2014 18:11:34
1487 forum posts
582 photos
Has anybody owned or used one of these Sieg Nano lathes ?
There are some old reviews on the internet which were not very favourable but things may have improved since then.
Roderick Jenkins09/07/2014 19:01:18
2376 forum posts
800 photos
Might be better known as the Draper version
Rod
Ketan Swali09/07/2014 19:55:05
1481 forum posts
149 photos
Bad copy...shizzle...lemon...nough said
Ketan Swali09/07/2014 19:56:53
1481 forum posts
149 photos
Not a beginners lathe.....not a watchmakers lathe....crap may be a good complement...ideal for Draper
Ady109/07/2014 21:11:39
6137 forum posts
893 photos
Mentioned it a couple of years ago and no-one was interested
A new "Unimat" on the block
Brian John10/07/2014 05:28:49
1487 forum posts
582 photos
Ketan : Have you used one or owned one ? Those reviews are quite old and they may have fixed the problems by now.
Ady1 : I searched this site before posting a new thread but could not find anything otherwise I would have added to your posting.
Ady110/07/2014 09:17:21
6137 forum posts
893 photos
That's ok, I was only pointing out the total lack of interest in this new unit, which to my eyes looked like it had potential at the time
On the flip side, the unimat market is still very buoyant with lots of activity
victor mcconville10/07/2014 09:26:54
20 forum posts
Hi Brian John,
I do not have a Nano, I have a Sieg Baby C0 Lathe.
Which is about the same Size.
It was delivered 6 weeks ago, one day after ordering.
A test piece of S/S was turned down to 0.010" dia (.25mm dia) before it broke off.
The three jaw Chuck run-out was less than 0.002".
Although only 150watt motor I cannot stop the chuck by hand so the power is good.
The tail-stock alignment was out by about 0.004" (0.1mm)but can be adjusted.
The only problem was the way the carriage/cross slide is secured to the ways, but now after a bit of work is very good and robust.
The statements above were the areas where there is no information anywhere on the net and were my main worries before ordering.
In my opinion this lathe will be much better than the Nano mainly because any faults can be corrected easily.
I already have a full workshop, this lathe is for clock parts and use in the house in the cold Scottish winters.
any questions please ask
Victor J
Neil Wyatt10/07/2014 09:27:56
19226 forum posts
749 photos
86 articles
Ketan is an importer of Seig products...
Brian John10/07/2014 09:34:51
1487 forum posts
582 photos
Victor : yes, I like the Sieg C0. It does look a better buy and it is not much heavier either. I will find an Australian seller to see what they are worth here. The Sieg ebay seller does not have a C0 which is why I had not seen it before.
Looks good :
http://www.ausee.com.au/shop/category.aspx?catid=46
Even better with an accessory pack :
http://www.ausee.com.au/shop/item.aspx?itemid=249
How do you fit a drill chuck to the tailstock ? Is this a thread unlike the other lathes which use an arbor ?
Edited By Brian John on 10/07/2014 09:41:02
Edited By Brian John on 10/07/2014 10:40:39
Ketan Swali10/07/2014 09:41:16
1481 forum posts
149 photos
Posted by Brian John on 10/07/2014 05:28:49:
I have not used or owned one. I have given one to an engineer for checking/testing. I had given the outcome of list of issues to SIEG. They disagreed. So we did not add to our range.
I am not prepared to go through the list of problems for various commercial reasons.
During the past two years I have meet two separate users who were looking for certain parts. They said that the machine needed 'a lot of fettling'.
Because of 'the look' (similar to watchmakers lathe), it also attracted a lot of interest from that particular hobby, because it is so cheap. However, it failed to meet the expectations 'for the price' of a well respected watchmaker who tested it out for us. His idea was to pitch it as an entry level machine to new people entering that hobby, but at the end, he agreed that the machine raised more questions then being able to address the need.
As a seller, I wish to invite as less or no problems post sales. At this price, there is no money in it for dealing with any user based issues.
Ketan at ARC.
victor mcconville10/07/2014 09:52:09
20 forum posts
Hi Again Brian,
The drill chuck screws on to the tail-stock 14mm x 1mm external thread as does the three jaw chuck.
The live centre is a slide fit inside the tail-stock sleeve.
Victor J
Brian John10/07/2014 10:44:55
1487 forum posts
582 photos
Ketan : Thanks for the information. I cannot argue with your evaluation.
Victor : Does the three jaw chuck screw screw onto the spindle ? I am a bit confused here.
victor mcconville10/07/2014 12:36:54
20 forum posts
Hi Brian,
The three jaw Chuck screws on to the headstock with an external 14 x 1mm thread on the spindle and an internal 14 x 1mm thread in the chuck, the chuck is located on a registered shoulder and gives the run-out on my chuck of 0.002" total.
Hope this helps
Victor
Brian John10/07/2014 13:51:44
1487 forum posts
582 photos
Isn't that unusual screwing the chuck onto the headstock ? I thought they all bolted on ? Can you still run it in both directions ?
How does the face plate fit to the headstock ?
Neil Wyatt10/07/2014 14:10:24
19226 forum posts
749 photos
86 articles
Not particularly, especially on older lathes and some new ones. Alternatives are bolt-on flange mount (cheap) and camlock (expensive). All depend for accuracy on an accurate register, and no way is inherently superior to the others for accuracy.
Not a good idea unless you have an arrangement to stop the chuck unscrewing, as on the later Myfords.
It screws on too.
RJW10/07/2014 16:35:24
343 forum posts
36 photos
Brian John & Victor, the Emco Unimat 3 has a 14mm x 1 thread on both the headstock and tailstock, so chucks and faceplates etc will fit either end, should fit the Sieg ok and widen the scope for tooling for you!
Check RDG and Chronos etc, no connection just a very happy customer!
John.
I.M. OUTAHERE11/07/2014 03:35:37
1468 forum posts
Brian I sent you a P.M
Ian.
Brian John24/07/2014 13:31:19
1487 forum posts
582 photos
I have sold the C2 and bought the Sieg CO lathe. Somebody mentioned earlier that the lathe should be bolted to the workbench rather than use the rubber feet. What is wrong with using the rubber feet ?
Edited By Brian John on 24/07/2014 13:31:59
Andrew Moyes 124/07/2014 14:36:46
158 forum posts
22 photos
Can I just correct a common misunderstanding here? The Myford 'safe reversing' feature on big-bore lathes is a misnomer in my opinion, as a user. The hole for the grub screw has a shoulder to stop the screw from contacting the vee groove in the spindle register. This is so that it does not pull the chuck out of truth. So, when the chuck starts to unscrew, it rotates about half a turn before the grub screw does contact the groove and stops the chuck coming right off. Still very worthwhile if it stops a chuck spinning off at speed but it does not mean you can use the lathe safely to apply a cut in reverse.
Andrew M
