Bantam cock injector size
Mark Tyldesley04/07/2014 13:29:41
61 forum posts
Hello
i have just purchased a 3.5g bantam cock, having steamed her yesterday, and confirming the injector does not work! Can anybody suggest what size/type of injector I should replace it with.
look forward to your replies
regards
mark
fizzy05/07/2014 09:17:54
1860 forum posts
121 photos
Have you tried soaking it and cleaning it? If it has been stood it has most likely furred up
Mark Tyldesley05/07/2014 10:35:29
61 forum posts
Hi,
Yes iv stripped it down countless times all is clean and in order, iv checked clack and that's working, just to explain alittle more, once water is coming out of drain, and steam applied it pushes even more water out of drain, someone mentioned blocking vent to see if water returns to tender, then releasing vent and achance it will start to pick up.
Other than that im stumped! So anew injector looks the way forward, so just wondered what size would be suitable, no 2?
Mark
Bob Brown 105/07/2014 11:08:25
1022 forum posts
127 photos
may be worth a read **LINK**
julian atkins05/07/2014 11:26:06
1285 forum posts
353 photos
hi mark,
bob's link to the late john cashmore's notes for Polly are excellent.
all commercial injectors are tested before being passed onto the supplier. 95% of all problems are due to faults with pipework and fittings, and filters or lack of them, or someone having damaged the injector.
i would recommend you contact Polly and see if they have any of gordon chiverton's excellent injectors available. 12 oz per minute would be ideal but has 1/4" x 40 tpi connections. a 'standard' medium sized 24 oz per minute injector will have 5/16" x 32 tpi connections.
usual disclaimer.
cheers,
julian
Nick Hughes05/07/2014 11:58:41
307 forum posts
150 photos
Posted by Mark Tyldesley on 05/07/2014 10:35:29:
Just as it should. Have you then tried closing the water valve SLOWLY, stopping when/if the injector picks up and starts feeding?
Nick
Claire Light12/02/2015 15:14:15
2 forum posts
Apologies for jumping on this thread quite some time after it was posted. The injectors mentioned made by Gordon Chiverton, I read with pride as Gordon is my father. Mark I hope you were able to fix your problem and perhaps even try one of Dad's injectors although I know that by the time you had posted last year, Dad had already had to retire (at 81yrs Young following the diagnosis of bladder cancer). He has not long turned 83 and I think it surprises him when I tell him someone has described his injectors as excellent (Julian - I hope they still give this result). Kind regards
Derek Drover12/02/2015 19:39:15
90 forum posts
I concur... I have a Chiverton No4 injector on my Simplex and its excellent. Cleaned regularly it gives reliable service. I'd previously gone through two other "commercial" injectors which were useless.
D
julian atkins13/02/2015 01:14:01
1285 forum posts
353 photos
hi claire,
ive sent you a PM
cheers,
julian
