Imperial Threads with a 1.5 mm metric leadscrew using a 63-tooth gear
Wolfgang Oestreicher | 26/06/2014 21:00:20 |
2 forum posts | I have a SC3 mini lathe with a metric 1.5 mm pitch leadscrew and I want to cut Imperial Threads. |
Michael Gilligan | 27/06/2014 07:30:30 |
![]() 23121 forum posts 1360 photos | Welcome aboard, Wolfgang ... Near the middle of the first page of that article, you will find the explanation. ... Short paragraph, just to the left of Fig.2 MichaelG. |
Les Jones 1 | 27/06/2014 08:30:01 |
2292 forum posts 159 photos | Hi Wolfgang, Les. |
Chuck Pickering | 27/06/2014 12:16:10 |
36 forum posts 2 photos | Little Machine Shop Has a calculator here that lets you select the imperial or metric lead screw, imperial or metric thread to cut, and also allows you to add any transposition gears you may have, and gives the change gear selection meeded to cut the desired thread.
Chuck |
Neil Wyatt | 27/06/2014 13:50:15 |
![]() 19226 forum posts 749 photos 86 articles | I have had nightmares about this! There is little information out there that is definitive but it appears the majority of mini-lathes have 1.5mm pitch leadscrews but some have 2mm pitch. But... when I wrote the article I produced tables for both metric pitches, so I've uploaded them to a pdf (with the tables in handy print out and laminate style!) linked to by the article here: I hope that helps, Neil P.S. an odd situation - a 1.5mm/2.0mm metric leadscrew fitted with a handwheel with a 60/80 division graduated collar will give you better 'thou' accuracy than anything you can fit to an imperial leadscrew (e.g. the 64 division wheel I have fitted to my 16 tpi leadscrew)..
Michael Gilligan | 27/06/2014 14:27:39 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 27/06/2014 13:50:15:
But..P.S. an odd situation - a 1.5mm/2.0mm metric leadscrew fitted with a handwheel with a 60/80 division graduated collar will give you better 'thou' accuracy than anything you can fit to an imperial leadscrew (e.g. the 64 division wheel I have fitted to my 16 tpi leadscrew)..
Neil, I know that "the Editor's decision is final" but I have to ask why you can't put 125 divisions on the HandWheel ? MichaelG. |
Danny M2Z | 27/06/2014 17:12:52 |
![]() 963 forum posts 2 photos | With an instinctive premonition of doom, when I ordered my (metric) Australian C3 minilathe I also purchased an imperial leadscrew as an 'optional' extra. It came with a whole bunch of new change gears and indexing chaser. It is a pita to swap but well worth the additional $110 (2006) * Danny M * Edited By Danny M2Z on 27/06/2014 17:15:58 |
Neil Wyatt | 27/06/2014 17:52:10 |
![]() 19226 forum posts 749 photos 86 articles | > why you can't put 125 divisions on the HandWheel I could. But I wouldn't be able to read them without taking my glasses off and sticking my nose down to lathe-bed level Also, I hate numbering that has an awkward bit on the end, like the 75-division dials on my mill. Neil |
blowlamp | 27/06/2014 18:51:27 |
![]() 1885 forum posts 111 photos | Posted by Neil Wyatt on 27/06/2014 13:50:15:
Neil. Thanks for the article and gear tables, but some combinations could do with a bit of a tune-up to squeeze a bit more out of this handy little lathe. I downloaded the NThreadP program from the lathes.co.uk site and it seemed to better some of the gear pairs shown in the charts. Cheers, Martin. |
Neil Wyatt | 27/06/2014 20:15:20 |
![]() 19226 forum posts 749 photos 86 articles | Hi Martin, I think i said I was sure there could be improvements - I calculated them all with a spreadsheet and stopped when I felt I had sufficient accuracy for each thread. I think most, if not all, are within the tolerance for rolled threads and commercial screws, if not to micrometer standards! Brian Wood is giving the tables a tune up, though. Neil |
Wolfgang Oestreicher | 29/06/2014 22:44:42 |
2 forum posts | Hi Neil, Thanks for the feedback and update! However, there seem to be some strange values e.g. for 28 TPI [50 35 20 63] (error -33.4 % !) or 36 TPI [50 65 40 65] (error 0.6 %) regarding the 1.5 mm metric leadscrew? The Little Machine Shop calculator states e.g. for 28 TPI [35 55 57 60] an error of 0.036 % and for 36 TPI [35 63 55 65] an error of 0.061 %. Obviously there are significant differences between the calculation methods and there seems to be a trial and error strategy appropriate... Wolfgang |
Brian Wood | 30/06/2014 10:37:38 |
2742 forum posts 39 photos | Hello Wolfgang, You found the obvious mistake---couldn't miss it really!! As Neil says, I looked over the tables and corrected the sort of error you found, there were some impossible gearing arrangements too which I also rectified. I did send them to Neil too but clearly the gremlins are powerful. I can send you the whole lot by email if you send me your address, I don't think I have the patience to make jpgs of them all so that I can put them in my albums My address is [email protected] If others would like these copies please get in touch. . Regards Brian |
