Here is a list of all the postings Chuck Pickering has made in our forums. Click on a thread name to jump to the thread.
Thread: Further thoughts on Fusion 360 |
31/01/2019 14:45:23 |
Brian, another good tutorial series on Youtube is by Paul McWhorter. He takes you through several simple projects, covering the basics. Chuck |
Thread: Flying experience |
19/01/2019 18:26:22 |
I too, got seriously interested in flying Gliders while stationed at RAF Upper Heyford with the USAF in 1975-1977. I Often went to Brize-Norton and worked towing the winch cable to earn my instruction flight time. I believe I was the only yank there at the time. Enjoyed the social time at the Club Bar at the end of the day.
Edited By Chuck Pickering on 19/01/2019 18:27:11 |
Thread: Mini-Lathe Repair |
07/12/2018 13:36:51 |
Has anyone needing these gears tried 3d printed ones? I I used Fusion 360 and it's spur gear add in to design and print every gear in my 7x lathe. My 7x is almost 20 years old, and I haven't broken any of the headstock gears, so haven't tried 3d printed ones there. But, I have printed various change gears, including a 90/20 combo gear for extra fine feed and a custom banjo to accommodate it, and a replacement motor pulley that work fine. |
Thread: z axis arduino |
02/12/2018 15:29:40 |
I agree with Dave. I also just loaded the sketch to an Uno and uploaded with no errors. But, I have the TimerOne-R11 library installed...
Thread: “Every Boy His Own Manufacturer" |
16/11/2018 19:34:44 |
Google gives me this link as to what Dragon's Blood is, **LINK** Google also lists it on Amazon. It is also used in cosmetics. You might try a chemist(Drug Store to us colonials) such as Boots, if they are still around. |
15/11/2018 21:17:02 |
I recently discovered the book “Every Boy His Own Manufacturer”, published in 1872, thanks to an old thread being woken up on another forum.
Thread: First boiler build |
23/09/2018 16:25:27 |
I’m ready to make the end plate formers for my small horizontal pot boiler. The body tube is 1.625” od, and 1.512” id, thus a wall thickness of .056”. I have both aluminum, and oak available for the formers. Are there any hard/fast rules or formulas for making the formers? With either material, I plan to have a center hole for a mandrel to turn them on. I’m leaning toward turning the former out of aluminum, as I have enough copper tube for a couple more. I’m also making the end plates from pieces of the tube, so the end plates will be .056” thick. What would be the minimum radius for the flange? How wide should the flange be? I’m following Stan Bray’s design Boiler # 1, in chapter 14 of the book “Making Simple Model Steam Engines”, but I couldn’t find 2” or 50mm tube. I assume the former diameter would be tube id – (wall thickness x2) and the blank disk should be a diameter of tube id + (flange width x2), with some allowance for the radius of the flange bend. Last question, which is the best orientation for the end plate in the body tube, flange pointing in or out? Why? |
Thread: Boiler terminology |
15/09/2018 22:07:46 |
I believe the ball is stainless, it came from a ball bearing...
15/09/2018 14:18:45 |
Brian, I am re-reading the Harris boiler book and taking notes... I found what you referenced. Thanks for the re-direction. I knew I'd seen it before, just couldn't remember where. Ian, thanks for the input. I've learned so much here... I will continue my studies of model boilers and their function, and hopefully will build one soon. |
14/09/2018 22:35:17 |
This may not be the place to ask, and please point me to the correct forum if not... Obviously, I'm researching info to build my first boiler. I have a few books on boilers and have learned a lot from them and from asking questions here. What I haven't yet found, is how to determine the steam requirements of a specific engine. Or, stated another way, how to make sure I build a boiler big enough to run my engine? As I can't, or haven't yet, found a source of copper tube of decent size to build a large enough boiler to run all the engines I've built, I will probably build Stan Bray's double tube boiler. Being a very curious fellow, and wanting to understand the why, as well as the how, where can I find the calculations necessary to determine how big a boiler I need for a specific engine?
14/09/2018 12:06:02 |
Per the drawing in Bray's book, there is a 1/16" hole through the knurled screw.
13/09/2018 22:01:25 |
I have Stan Bray's book, Making Simple Steam Engines, and will probably build my first boiler from the plans in that book. This afternoon, I made an attempt at making the safety valve from that book. Below is a picture of my attempt. I've decided on 1/4"-28 thread for my various fittings. I used the spring from a 'clicker' ball point pen, and a 4.75 mm ball from a cut up ball bearing. I did not make the guide rod as in the book. Do I really need it? The adjustment screw is long to make sure I can adjust the valve to the working pressure that is yet to be determined. What do you think of my attempt?
13/09/2018 17:37:50 |
I have, what I believe to be a domestic steam heat radiator relief valve. I found it in my Dad's tool box. I fugure it's got to be 75-100 years old. The coin in the picture is an American Quarter for scale. I would like to make one like it but a bit smaller to use on a model boiler. Think it would work? I intend to make the valve and body long enough to give a good range of adjustment. |
13/09/2018 17:09:23 |
Thank you, Duncan. Interesting read, and it answered my question.
13/09/2018 16:53:21 |
I was researching info and designs for a small boiler safety valve when I came across an old post in this forum by Stub Mandrel. He was describing a problem with a sticking valve he was testing. He wrote: "I gingerly prodded the top pin of the safety valve to see if it was stuck and 'wham' a huge jet of wet steam hit the ceiling of my workshop, presumably as it primed. I lost 1/4" of water in the glass but it stopped wjhen I turned the gas off. A repeat outside saw the same., except teh geyser was about 12 feet high and created a localised shower downwind, much to the cat's alarm. It didn't close again until the pressure was nearly zero." What does he mean by "... presumably as it primed..." ? |
Thread: Political views within the forums |
12/07/2018 18:01:58 |
Posted by Bodger Brian on 12/07/2018 13:25:06:.
I engage in model engineering and participate in these forums as an escape from the 'outside world' and don't expect to see (or want to see) what another member's political views are, regardless of whether I agree with them or not. If a thread has a title that makes it obvious that it contains politics, fair enough, I can ignore it & move on. Thoughts? Brian
My thoughts exactly...
Thread: Making a stationary steam engine |
12/07/2018 17:41:18 |
Here's a link to download a pdf of the book referenced by Bob B.:
Thread: Slotting a change wheel bore |
07/06/2018 14:10:47 |
I know this is an old thread, but please bear with me. I have the original article on the Peterson slotting tool. I also found a set of Solid Works models of the slotter, but I can't remember where I got them. I am trying to modify the models to fit my 7x lathe. I successfully imported the SolidWorks drawings into Fusion 360. Has anyone modified this slotter for a 7x and be willing to share the drawings? I have printed the original body pieces via Fusion, to use as a pattern and will cast it in aluminum (I'm a yank, hence the yank spelling). I could machine the original to modify it but would rather modify the model.
Thread: Dial Indicators |
11/02/2016 18:42:22 |
Posted by Neil Wyatt on 11/02/2016 17:10:42:
The way to get precision and accuracy in your mind's eye is to think of target shooting. A tight bunch of hits away from the bull is precise, but not accurate. A loose bunch of hits clustered around the bull are accurate but not precise.
A tight group on the bull is b0th precise and accurate.
You can work with any or the three - precision without accuracy means you need to identify the error and allow for it. Accuracy without precision can be partly offset by averaging several measurements.
Obviously if you have both, you are in clover. Neil Great analogy, Neal. Had to copy and save that definition. Also shared it, with credit to you, on a couple Facebook groups I follow. Chuck |
Thread: Free Plan: Vertical Slide made from a Cross Vice |
14/09/2015 14:27:06 |
Posted by Ady1 on 14/09/2015 13:46:23:
ErrorThe article cannot be found.
