parallel flute end mills
fizzy11/06/2014 21:28:21
1860 forum posts
121 photos
What are these used for? Why not helical?
Frank.N Storm11/06/2014 21:51:22
50 forum posts
Posted by fizzy on 11/06/2014 21:28:21:
Best as doorstop for a very small door....
I bought one, years ago, and found it totally useless.
Regards, Frank
Michael Gilligan11/06/2014 22:10:54
23121 forum posts
1360 photos
(a) According to this supplier:
"For tight tolerance slots and keyways."
(b) Because helical ones don't do that very well.
John Stevenson12/06/2014 09:09:04
5068 forum posts
I would not say they were totally useless or you can throw every router cutter away as these are mainly parallel.
They are good for light finishing cuts.
roy entwistle12/06/2014 15:16:37
1716 forum posts
I find them ideal on brass and gun metal
Roy
Muzzer12/06/2014 16:11:31
2904 forum posts
448 photos
If you are doing any maching using the edges on the end of the cutter, the helix angle will be related to the material it's intended for. So aluminium would require a fast helix, copper and brass a slow (or parallel) helix and you can even buy a reverse helix. I suspect the latter is actually best used for thin sheet material, as it will push the work against the table.
Of course, you could have a parallel flute cutter with any kind of cutting angle if you are mainly cutting radially and I expect you can get different combinations of helix angle and cutting angle according to both material and type of cut. But one advantage of the spiral is a smoother cutting force which is presumably why parallel edged cutters are best used for light finishing cuts.
Murray
Neil Wyatt12/06/2014 21:03:32
19226 forum posts
749 photos
86 articles
I made an 'emergency' slot drill from silver steel to the 'LBSC' design. Mill away two sides then file relief on the edges and ends. Harden and stone an edge. To my amazement, it worked, and also worked well for light facing cuts using the end.
