The Diamond Tool Holder
JOHN BRIDGE 108/05/2014 21:05:36
104 forum posts
11 photos
Has anyone tried 1 of these if so how do you rate them.
John Haine08/05/2014 21:15:37
5563 forum posts
322 photos
Yes, I have one and I think that it is very good, as long as you grind the tool properly. Actually it's not so much the grinding but honing a radius on the leading edge to prevent the sharp tip cracking off. I also don't like the supplied grinding jig and have made my own to better control the angles and allow a range of angles. When some current building work is done I could post some photos.
john.
Simon Collier08/05/2014 23:03:10
525 forum posts
65 photos
I have used one since I started in the hobby in 2006. I rarely use anything else. When they released a left handed one, I bought it immediately. If I do use carbide insert tools for heavy, rapid metal removal, I finish with the Diamond tool. I have ground tool bits with various radii, for, e.g., loco wheel root radii. I can't recommend it highly enough. Apart from the annoying loose washed under the retaining cap screw, I find the sharpening jig fine.
Robbo08/05/2014 23:26:12
1504 forum posts
142 photos
If you use the "search" box at the head of the post, and use "tangential", and "diamond tool" as the search parameter you will find numerous threads and posts about this.
TrevorK09/05/2014 08:34:55
45 forum posts
4 photos
I too am using their toolholders and have used their Crobalt tool steel on cast iron, which worked well.
I'm not sure I'm getting the best possible finish and would be interested to hear/see how you hone the radius John H.
mechman4810/05/2014 12:30:07
2947 forum posts
468 photos
I use one for most of my machining 95% of the time; I am tempted to get a left hand version but cannot justify the expense for what I do. Was considering getting a piece of the Crobalt tool steel to try out, am going to Harrogate show tomorrow so will see what's available. I use a small hand diamond lap to take the front corner off the cutter creating a fine radius which I find gives a decent finish for most materials.
George
John Haine10/05/2014 15:47:55
5563 forum posts
322 photos
I also use a small diamond hone to put a small radius on the corner.
Russell Furzer12/05/2014 02:21:37
53 forum posts
8 photos
Me too - fantastic bit of kit.
_Paul_12/05/2014 03:00:34
543 forum posts
31 photos
The Eccentric Engineering design was developed by Des Burke in 1985, I do like them I have a bought one from Eccentric Engineering and a couple of shop made one's all equally good results with simple one facet sharpening using cheap HSS tooling, there many different shop made designs around on t'internet.
The original idea is quite old this advert for one type dates from circa 1879:
Paul
Barry McDowell12/05/2014 03:32:14
12 forum posts
I have been using one for about 18months since I have had my lathe. They are a great bit of kit I would recommend the Diamond Tool Holder to everyone.
Barry
JOHN BRIDGE 114/05/2014 15:47:44
104 forum posts
11 photos
Thanks to everyone for your input.
