C J | 17/04/2014 21:55:22 |
![]() 113 forum posts 86 photos | I recently bought a Nippy vice in good condition but on cleaning it realised that the "V''s" on the upper jaw plates don't match (or mirror) each other. In other words, my vice has two plates for the movable jaw instead of a pair of plates ! I can't turn one plate over as the fixing screw-holes are counter-bored and I can't countersink the holes on the underside (to fit countersunk screws) as the plates are hardened.which rules out filling the holes up with weld and re-drilling them. I really need a matching plate, could it be possible that some reader of this forum has a spare "fixed" upper jaw plate for a nippy vice?
colin hawes | 18/04/2014 12:53:44 |
570 forum posts 18 photos | If the jaw is case hardened you could locally grind it to reach soft metal or you may be able to drill with a sharp carbide tipped drill. Colin |
C J | 18/04/2014 15:46:14 |
![]() 113 forum posts 86 photos | Thanks for replying. I'm now considering taking the carbide tipped drill route to cut a countersink on the underside of the plate but I will have to see how much metal I have to play with as per the drawings. It's one of those small but challenging problems.
C J | 18/04/2014 16:37:58 |
Edited By C J on 18/04/2014 16:46:00 |
C J | 18/04/2014 16:38:18 |
Edited By C J on 18/04/2014 16:46:28 |
C J | 18/04/2014 16:46:54 |
![]() 113 forum posts 86 photos | |
Keith Long | 18/04/2014 17:02:34 |
883 forum posts 11 photos | Hi CJ From your images - if the counterbored holes are in the right place can you just replace the countersunk screws with cheese head - modified for height as necessary, or make up some drilled "slugs" to fill in the counterbore with the end face countersunk to take the existing screws. The slugs wouldn't really need hardening but could be made from silver steel, hardened and tempered to taste if you wanted. Keith |
jason udall | 18/04/2014 17:18:04 |
2032 forum posts 41 photos | Soft jaws? |
roy entwistle | 18/04/2014 19:35:24 |
1716 forum posts | Isn't the Nippy vise made by Record of Sheffield I believe they are still in business or are they now Irwin I would have thought a phone call would help Roy |
Oompa Lumpa | 18/04/2014 19:47:10 |
888 forum posts 36 photos | Can't you just remove it, put it on the back jaw where it would fit (if you swap the screws about) and make a new one for the front? graham. |
Mike Poole | 18/04/2014 21:22:32 |
![]() 3676 forum posts 82 photos | The Nippy vice was made by Murray Son ltd Mike |
julian atkins | 18/04/2014 21:51:33 |
![]() 1285 forum posts 353 photos | has anyone tried fitting a tommy bar to the handle? have often thought it would be a useful addition. how would you got about drilling the handle which appears to be extremely hard? cheers, julian |
C J | 18/04/2014 22:25:31 |
![]() 113 forum posts 86 photos | The plate also has a V running along the edge as below which does make it harder to replicate
Michael Gilligan | 18/04/2014 22:38:58 |
![]() 23121 forum posts 1360 photos | There must be quite a few versions of this vice around ... mine is by Jones & Shipman, of Leicester Bought it new, in the early 1970s. MichaelG. |
C J | 18/04/2014 23:10:47 |
![]() 113 forum posts 86 photos | Thanks for all the info and suggestions. I've since inspected the plate and see there is enough material on the underside to add a countersink to the smaller bores (shown in the above photograph) and use two 1 /2" 1/4 " Whit screws with 90 degree angle countersink heads.. Yes, I could just use domeheads but I want the top of the vice to be flush and will grind the countersinks out with a dremmel if I have to.
C J | 23/04/2014 16:53:17 |
![]() 113 forum posts 86 photos | Job done, fixed jaw plate now reversed. Many thanks for the helpful messages. I bought a 10mm 90° solid carbide spot drill off eBay to cut the countersinks and some 1/4" x 1 1/2" countersunk Whit screws from my local engineering supplies. I have never drilled hardened steel before so this was a first for me. |
