JBFlies | 02/04/2014 08:17:31 |
6 forum posts | I have acquired a complete kit of parts for the Burrell 7HP Traction Engine as produced by Bassett Lowke. It is quite old (mid 60's I would guess) and all the parts / castings / fastenings etc appear to be there. I have all the plans except Sheet 1 which is quite a big omission. There is also no construction booklet and I feel there probably was one originally. I would be very grateful if someone had Sheet 1 of this plan set and hopefully also the booklet and I could arrange for a copy. Without it there is not much I can do with all the other parts I have. Thanks, John Begg, Christchurch, NZ |
JBFlies | 20/06/2014 10:13:27 |
6 forum posts | No replies. That is a bit surprising. I would have thought that someone would have built one of these. Are they actually a rare beast? |
JasonB | 20/06/2014 10:16:52 |
![]() 25215 forum posts 3105 photos 1 articles | Yes quite rare and you see more posts asking for drawings than you do engines. J |
JBFlies | 26/06/2014 11:21:20 |
6 forum posts | Hi Jason, thanks for the response. As it seems to be a more unusual model than I thought it is perhaps not the best subject for my next project. Do you know if they did make a good model once completed? Thanks, John
Detlef Gause | 26/06/2014 12:49:02 |
![]() 1 forum posts | there has been one sold at cheffins, incl. drawings, maybe you could ask them to forward your request ? Detlef |
Tricky | 03/07/2014 14:01:40 |
76 forum posts 8 photos | Hi John, I am currently building a Bassett Lowke 1.5" traction engine that was started by my father about 40 years ago.
The other thing you need to consider is that the original boiler drawing shows an all copper rivetted and soft solder construction with integral hornplates which isn't really acceptable now. I redrew the boiler to be silver soldered construction with separate steel hornplates and had it made commercially. If you want any more information please let me know. Richard |
derek blake | 30/09/2014 23:46:19 |
586 forum posts 151 photos | Hi guys, I'm new. I have noticed the above thread convention the 1.5 inch bassett lowke Burrell traction engine, I to need a set of drawings, my engine is a complete week and probably never run again but could anyone help me with a set of drawings to maybe give me half a chance.
Willing to pay.
Thanks Derek |
derek blake | 01/10/2014 11:36:13 |
586 forum posts 151 photos | Sorry my spelling was awfull. can anyone help with a complete set of the 1.5 inch drawings as above? i'm willing to pay. Thanks Derek |
Tricky | 01/10/2014 11:51:43 |
76 forum posts 8 photos | Hi Derek, I have scanned in my copies of the 1 1/2" Bassett Lowke TE drawings and can send a copy of them to you at no cost. If you send a Private Message to me with your email address I will contact you to discuss what format you want them in.
Richard |
derek blake | 01/10/2014 13:06:44 |
586 forum posts 151 photos | Great, thanks Richard, i have sent you my email |
derek blake | 02/10/2014 20:39:45 |
586 forum posts 151 photos | Hi Guys I'm stuck again with this engine, the cylinder block seems to of been machined wrong, all the inner holes etc but I can't figure the drawing out on how wrong they are. can anyone help with digital pictures of there's, or know anyone who would machine the inside for me? regards Derek |
derek blake | 02/10/2014 22:06:05 |
586 forum posts 151 photos | looks like I have the slide valve parts missing |
JasonB | 03/10/2014 07:35:30 |
![]() 25215 forum posts 3105 photos 1 articles | Depending on how badly placed the wrong holes are you may not be able to recover the casting, at the very least most of the mating parts may also need to be machined to suit any corrective work. Post some square on photos of the cylinder with a steel rule against it and the relevant part of teh drawing and we can have a look. J |
derek blake | 03/10/2014 09:17:21 |
586 forum posts 151 photos | Thanks for the reply, i will try and get some photos done, is there anyone who has built this engine and knows how the slide valve should look inside the cylinder block? and if i should even carry on with this engine, i'm being told that the copper hornplates are unsafe and i sould get rid, which seems silly as they have been working OK in the past. Thanks Derek |
JasonB | 03/10/2014 13:39:28 |
![]() 25215 forum posts 3105 photos 1 articles | This engine's boiler is made like the full size and the "hornplates" are a continuation of the boiler sides rather than separate plates as most designs now have. To get rid of them would mean a complete new boiler and boiler design. Unless they are leaking or in some otherway defective it would not be easy to "get rid" Has a boiler inspector taken a look at the boiler? Who has said its unsafe and why? Not sure what stage of build the engine is in but before doing any work on it I would suggest you get a hydralic test done on teh boiler as its not going to be worth bolting all the other bits onto a dodgy base.
J |
derek blake | 03/10/2014 13:45:01 |
586 forum posts 151 photos | Hi, thanks for your response. i agree i think it looks fine to me, an sending it away today for a test at £55..then i will know if to carry on. i am literaly trying to save this engine from the brink of the bin, thats how bad it is. Derek |
JasonB | 03/10/2014 16:28:16 |
![]() 25215 forum posts 3105 photos 1 articles | Even if the boiler gets the thumbs down it would still make a nice display engine and could even be made to work on air without pressurising the boiler so you could have a bit of a play at home. |
JBFlies | 05/10/2014 07:30:48 |
6 forum posts | As I indicated earlier, I have acquired a complete set of castings, all the machined gears, all the fastenings,. In fact everything for the complete engine except the mild steel stock (for axles etc). However I have encountered a major problem in that the boiler does not meet the NZ (or Australian) code and would require significant changes to do so. I have the modified boiler design, thanks Richard, but even that does not meet our NZ code. I wonder if the best option is to sell it all back to someone in UK as it seems that it meets UK requirements closer than ours. Is there a market for stuff like this? John |
JasonB | 05/10/2014 12:16:18 |
![]() 25215 forum posts 3105 photos 1 articles | There should not be that many alterations to bring the modified boiler upto your spec, probably needs radial stays if the drawing has girder and one or two there odd bits. Agree that the rivited and caulked boiler is now outdated. There is always a market but really depends on costs, shipping will be a major downer, I just bought a casting set from the US which cost me $125USD but the postage was another $108USD to post to the UK which will be against you if selling overseas. The other factor is that the current trend is to build larger scale engines, at the time BL offered these kits 1 1/2" scale was generally the largest a lot of people would tackle, now most want something that can hold its own on the rally field so 3" or large 2" is the practical minimum and 4" plus prefered. If someone really did want to make that particular engine then most of the castings could be done by fabication or cutting from solid so again a smaller market. J |
Roderick Jenkins | 05/10/2014 20:23:23 |
![]() 2376 forum posts 800 photos | Interesting coincidence - At the Fornsett show today I saw a model traction engine that I didn't recognise. The size was just the sort of thing I would like to build. The owner told me it was a 1 1/2 " Bassett Lowke Burrell. Very nice engine, un-painted and steaming like a witch on coal. He also said that the Plastow 3" was just doubled up from the Bassett Lowke drawings, so that may be an option. HTH Rod |
