Member postings for Tricky
Here is a list of all the postings Tricky has made in our forums. Click on a thread name to jump to the thread.
Thread: Raspberry Pi Pico
22/08/2023 13:22:07
Posted by SillyOldDuffer on 22/08/2023 12:54:16:
I was a professional programmer, paid to write in COBOL(s), FORTRAN(s), Filetab, C, C++, Sculptor, Perl, Informix-4GL, SQL, MS-BASIC, Visual-Basic, Pick-BASIC, and Delphi (Pascal-like). Also for my employer, I wrote reports on the applicability of Algol, Forth, BASIC, LISP, Pilot, Pascal, Python and Ada. Plus a comparison of the vices and virtues of the competing RDBMS of the day. Not only can I write BASIC, more than one variant, but I've had plenty of experience with other languages in all applications apart from real-time.
Oh dear Dave, you had a very limited experience of computer languages, no Coral 66, Pl/1 and its interactive subset CPS , IBM Assembler, APL and RPG. smiley
Richard
Thread: ER collet chuck for Super 7
15/08/2023 12:43:35
RDG do one specifically for the Myford. Se here.
Thread: Why do modern car engines have different types of bolt type heads like Torx etc?
27/07/2023 15:32:57
The replacement of oil derived fuel for ICEs is already under way. For example look at P1fuels.
Thread: Tony Seba’s Prediction
25/07/2023 08:32:37
With my experience of living in an all electric house with an air source heat pump the biggest increase in electricity used will be the heat pumps. Our yearly usage is 13000 kWh. sad
Thread: New IC engine deal
13/07/2023 07:13:23
It is interesting to look at this report from Volvo (owned by Geely) which shows the C02 over the lifespan of various versions of the Volvo XC40. The ICE version has a much lower carbon footprint for manufacturing and the crossover for the electric version is up to 150,000 Km depending on how the electricity used is generated. As my XC40 is 5 years old and I have only done les than 45,000 Km I think I must be saving the planet!
Link
https://www.volvocars.com/images/v/-/media/applications/pdpspecificationpage/my24/xc40-electric/pdp/volvo-cars-LCA-report-xc40.pdf
Thread: Major flaw in the world of engineering
22/04/2023 19:26:41
Posted by Mick B1 on 22/04/2023 19:22:15:
That's fair enough. The 3 jaw mayn't have the same grip, but it's horses for courses. I tend to find I need to use hex bar, both for models and railway work, plus I've never gone for records on cubic inches per minute metal removal. So the 3 jaw suits for me, with soft jaws to hold parts where there's not much to get hold of, and occasionally the 4-jaw independent for odd profiles and eccentrics. Hot-rolled black bar is something I've not seen in a while, though presumably it's still available.
You can hold hex bar in a 4-jaw SC chuck!
Thread: Solid edge community edition download problems
11/03/2023 09:52:52
There seems to be misunderstanding as to how Windows uses standard user folders. These are all of the form c:/users/name/foldername where name is a user name, Default or Public and foldername is Documents, Pictures Video and Downloads. These folders are also Libraries which are virtual containers for user content. Any user created folder such as c:/pictures or D:/pictures is completely separate from the windows created default folders and could not be accessed by reference to the single name Pictures unless a location change has been performed as Dave has shown in the Picture-Properties-Location tab.
I also asked Solidedge to save a picture and it came up with a dialogue box that allowed you to select the file location. I selected Pictures and it saved it OK. It does not automatically store it in pictures.
Graham has said that he created the D:/pictures folder himself, not that it came with his PC.
As Solidedge does NOT automatically use the Pictures folder I suggest that there is a different reason for the install to fail.
10/03/2023 14:02:00
I have all my user folders referenced as d:/users/richard/... and have used this on many computers and it is the Microsoft recommended way of doing it.
I do not think the problem is with Solid Edge as, if you search for error 1606 during install, there are many references to problems with program installs and one of the main reasons seems to be corruption of the registry, especially if a program uninstall went wrong. There are various solutions including using compatibility mode to install the program and let it try to correct errors or use a PC optimisation tool to search for errors.
Richard
10/03/2023 12:10:39
I use Windows 10 on my desktop and always have my user folders ( my documents, pictures etc) on a separate drive to the system and I have just installed Solid Edge without a problem. I do not think that Solid Edge does need to or actually does access the Picture folder, certainly not in my case.
Is your computer standalone or part of a network? Also is it your personal machine or a company machine as this can affect permissions?
Richard
Thread: Microsft 'Edge'
19/02/2023 12:03:04
Microsoft Edge, Chrome and Opera are all Chromium based browsers and you can install add-ons to Edge from both Microsoft and Google so I cannot see what the problem is. I have used Edge and Bing from when they were first released with no problems.
Richard
Thread: Revisiting The Red Devil by David Wardale
03/10/2022 13:07:26
I don't think you can criticise the whole of British industry concerning diesel engines for BR as companies such as Paxman had been making successful diesel engines for naval use such as submarines from before the second world war, see here
Thread: latest issue
27/07/2022 15:16:08
Not an isolated problem as I have just received my print copy and that has the same problem, no pages 195-202 and 219-226 but 2 lots of pages 203-210 and 211-218.
27/07/2022 13:11:49
The digital version is OK, I haven't received my print version yet.
Thread: MAX-T
14/07/2022 15:26:22
Peter,
Are you sure it is MAX-T as T-Max are inserts made by Sandvik and will be of good quality.
Richard
Thread: Change Wheel Programme from MEW
06/07/2021 15:35:10
One of the worst Cobol programs I had the misfortune to try to debug had been written by somebody who thought he understood structured programming and contained several pages of nested IF... ELSE... statements making it almost impossible to debug.
One useful feature that is not used now is Decision Tables which make the logic of a problem clearer. In the early 1970s we used them in a system that enabled a list of equipment for a new coalface to be produced from a simple list of parameters such as length of face, type of supports etc. The logic was in the form of decision tables embedded in the Cobol source which was then put through a pre-processor to create source code. The decision tables were created by the user engineering department so they had control over them. Initially we used an ICL Cobol pre-processor but I converted them to IBM using a pre-processor obtained from the States and written by Grace Hopper! I also split the original large program (2 boxes of cards) into sections which could be compiled separately and then dynamically linked at run-time so making amendments easier.
Richard
Thread: horizontal boiler stays
19/05/2021 08:00:47
We live in an area with a lot of dairy farms (South Cheshire) and I understand the water pressure is high because the farms use a lot of water. We had to install a pressure reducing valve to reduce it to 3 bar as it was causing us problems. There are also a high number of water leaks in the distribution system that need to be repaired because of this.
Richard
Thread: Bernard Towers' Lantern Chuck
30/04/2021 16:32:51
lantern chuck 1.jpgThis is my version of Bernard's Lantern Chuck. I did have a problem with some of the dimensions on the drawing in MEW 302 as they were a mixture of imperial and metric and there was a spurious 1.2 (inches ? ) which was obviously wrong. I think it would have been better to have the drawing in either imperial or metric or as 2 separate drawings. The other thing I found was that with my fat fingers it was a little difficult to get a screw-holder and screw into position ready for shortening.
lantern chuck 2.jpgI was quite pleased to get the 2 parts screwing together nicely as I used a carbon steel tool that I inherited with the lathe from my father and must be over 60 years old for the external thread and a home-made silver steel internal threading tool. At least on my Myford S7 the 8tpi leadscrew makes it easy to cut a 32tpi thread.
Richard
Thread: Improved performance over standard V belts?
31/12/2020 17:39:22
As someone who has actually used one I found on my Myford S7 that the vibration on the original belt from motor to countershaft made it almost unusable in high speed but replacing the belt with a Powertwist belt reduced the vibration considerably.
Thread: Delay to Issue 299
07/12/2020 15:47:53
Mine arrived 30 minutes ago from Whitchurch (Shropshire) sorting office but I am still waiting for an Amazon order posted a week ago and supposed to have been delivered by Saturday, so I think the delay is in the Royal Mail delivery system.
Richard
Thread: Bassett Lowke 1.5" Burrell Plans Required
09/11/2020 16:32:09
The drawings I use are scanned in versions of the originals and originally I made the plates to these plans but once I started trial assembly of the cylinder and motion I found the holes were in the wrong place so I remade them to fit the eccentrics and connecting rod! Also I re-designed the boiler to have separate hornplates so the width between the hornplates was different to that on the plans.
Richard
