Member postings for JBFlies
Here is a list of all the postings JBFlies has made in our forums. Click on a thread name to jump to the thread.
Thread: Bassett Lowke 1.5" Burrell Plans Required
05/10/2014 07:30:48
As I indicated earlier, I have acquired a complete set of castings, all the machined gears, all the fastenings,. In fact everything for the complete engine except the mild steel stock (for axles etc). However I have encountered a major problem in that the boiler does not meet the NZ (or Australian) code and would require significant changes to do so. I have the modified boiler design, thanks Richard, but even that does not meet our NZ code.
I wonder if the best option is to sell it all back to someone in UK as it seems that it meets UK requirements closer than ours. Is there a market for stuff like this?
Thread: Stuart D10 Metric Plans
30/07/2014 08:38:06
Great comments and I can see both points of view. I thought that more modern ST plans would have been converted but understand that is not the case.
I quite like the thought of building in Imperial for the extra challenge. Can't be too hard.
29/07/2014 08:18:45
I have a set of castings and about to finally start work on making my D10. I say finally because this has been a long time in the gestation. The plan that came with the castings many years ago are in Imperial units. I am now firmly embedded in metric. If someone had a copy of the D10 plans in metric that would be most helpful.
JBFlies, NZ
26/06/2014 11:21:20
Hi Jason, thanks for the response. As it seems to be a more unusual model than I thought it is perhaps not the best subject for my next project. Do you know if they did make a good model once completed?
Thanks, John
20/06/2014 10:13:27
No replies. That is a bit surprising. I would have thought that someone would have built one of these. Are they actually a rare beast?
02/04/2014 08:17:31
I have acquired a complete kit of parts for the Burrell 7HP Traction Engine as produced by Bassett Lowke. It is quite old (mid 60's I would guess) and all the parts / castings / fastenings etc appear to be there. I have all the plans except Sheet 1 which is quite a big omission. There is also no construction booklet and I feel there probably was one originally.
I would be very grateful if someone had Sheet 1 of this plan set and hopefully also the booklet and I could arrange for a copy. Without it there is not much I can do with all the other parts I have.
Thanks, John Begg, Christchurch, NZ
