Dave Harding 1 | 16/03/2014 00:50:40 |
148 forum posts 4 photos | Is it possible to cut gears on a Lathe if so how would you do that. |
Bazyle | 16/03/2014 01:17:32 |
![]() 6956 forum posts 229 photos | Yes. Two major methods involving different approaches. Put google into images mode and then enter "cutting gears on lathe" and you will find a mixture of examples. Then add 'youtube' to the end and you get some more. Reading that lot should use up most of Sunday for you. |
_Paul_ | 16/03/2014 03:52:01 |
![]() 543 forum posts 31 photos | Both Myford and Boxford had/have their own dividing heads designed for indexing on the lathe with the cutter then mounted between centres . Cutter mounted between centres setup: Toolpost cutter with gear blank mounted in chuck.
WALLACE | 16/03/2014 07:19:43 |
304 forum posts 17 photos | Seem to remember in MEW there was an (to my mind) elegant way of hobbing a gear on a lathe by using a stepper motor to rotate the blank. Simple electronics (TTL divission) plus an optical coder was used to generate the 'locked gearing' between the cutter and the blank. W. I |
JasonB | 16/03/2014 07:25:42 |
![]() 25215 forum posts 3105 photos 1 articles | If your gears are not too large a tooth then you could also index the spindle and use a tool ground to the correct profile to plane the cuts much like a shaper, this is the principal on an internal gear |
Bazyle | 16/03/2014 10:02:48 |
![]() 6956 forum posts 229 photos | BTW are you talking about clocks or big stuff? |
Ray Lyons | 16/03/2014 17:38:09 |
200 forum posts 1 photos | Search for "Hobbynut" on Youtube. Here is a practical engineer who gives an excellent demonstration on gear cutting using the lathe and milling machine. The methods he describes could easily be adapted for making in the lathe with a suitable dividing attachment. |
