ML7 Restoration
Thread or description and questions to you experts for advice during my ML7 strip down and restoration.
Matt C Beech24/02/2014 16:47:25
50 forum posts
24 photos
Hi everyone, started a bit of an adventure with an old ML7 I picked up last week.
To set the scene it's in rather a state, covered in muck and grime and it is clear the previous owner had been attacking it with a grease gun and filling up the oilers with grease. I was dismantling the main bearing oilers and found them full of grease too, to my disappointment. I have checked the bearings for scoring, and to my eyes they seem ok, so we may be lucky here.
Photos from the main strip-down can be found below (hopefully)
I'll add more progress and questions (I have a few) to this thread as I go.
Diane Carney24/02/2014 17:10:03
419 forum posts
11 photos
You will be following Alan Hearsum's currently running series then wink 2 ?
Diane
Matt C Beech24/02/2014 17:23:21
50 forum posts
24 photos
No, what's that? Sounds really useful & relevant.
Do you have a link?
Thanks!
Matt
Matt C Beech24/02/2014 23:00:32
50 forum posts
24 photos
Oh - I found what you meant. Here:
http://www.model-engineer.co.uk/sites/7/documents/ME4475%20contents.pdf
Hmmm - synchronicity...
Matt
Matt C Beech25/02/2014 00:20:53
50 forum posts
24 photos
So today I've pushed on with a few things:
1) Headstock spindle disassembly. Thanks for the advice form the forum here, it came apart nicely with a bit of care - photos here showing how I did it. I did however notice something odd with the cone pulley, where the channel in the inner bush for the oil is NOT aligned with the hole for the nipple. You can see it in this pictures below. After a bit of advice I put the cone pulley in the oven when it was cooling after dinner, and it came apart quite easily. So i've realigned it, but I think I'll be putting some Loctite on that to make it secure.
Matt
Matt C Beech25/02/2014 00:21:14
50 forum posts
24 photos
2) Derusting and restoring the backgear. I used a reverse electrolysis approach, which was a lot of fun. I was really pleased with the result, and am going through the other change gears as a similar process. I used a lead flashing Anode with sodium bicarbonate electrolyte and a 5amp 24v power supply. Worked like a charm.
Matt
Matt C Beech25/02/2014 00:21:28
50 forum posts
24 photos
3) Cleaning and stripping of the headstock castings. After a bit of digging I employed some Gunk degreaser followed by Nitromorse and some wire brush wheels on my drill. The parts came up really nicely, and will be painted with etch primer, high-build primer and then the tractol enamel top-coat when they arrive.
If you have any observations, advice, tips or tricks please let me know. (especially if you think I'm doing something wrong!)
Matt
Matt C Beech25/02/2014 00:25:35
50 forum posts
24 photos
4) The Oilers - and a query for advice
A short update this time, been generally cleaning all the headstock parts (nuts and bolts etc) and started work on the oilers.
Oh my word what a mess! I cleaned up the bearing for the backgear, and I think I see why the previous had taken it off. It was clogged full of grease, the last owner has filled all the nipples up with grease.
So I decided to disassemble the oilers for the main headstock spindle, and these too were full of thick heavy grease. I managed to take one apart and unscrewed the bottom where the ball bearing sits.
I have one question for hints and tips. In the bottom part of the oiler (shown in the second photo) there is a bronze insert into the steel casing holding the sights. It is screw-threaded into the bottom part, but I'm not sure how to get a purchase on it to unscrew it. I need to get it out to clean up the oil-drip sights.
Any ideas?
Edited By Matt C Beech on 25/02/2014 00:30:18
Michael Gilligan25/02/2014 08:52:25
23121 forum posts
1360 photos
Matt,
I am viewing on an iPad and cannot see any of the photos in your postings.
Matt C Beech25/02/2014 08:58:11
50 forum posts
24 photos
Michael,
Yes, that _is_ annoying! I just checked it on my phone and the flash picture gallery does not load.
I was trying to find a nice solution to show my pics.
Works OK on my desktop though.
I'll do some digging.
Matt
NJH25/02/2014 09:01:45
2314 forum posts
139 photos
Matt
I agree - an image, which can be expanded to show more images, appears in your first post but the next 4 contain just blank white squares under your text. This is on a good, old fashioned, Windows 7 machine. When I can get access to OUR iPad I will check it out there but that may take some time. My wife asserts that it is HER iPad and, as I like to eat and she is a great cook, I don't press the point!
Norman
Matt C Beech25/02/2014 09:09:35
50 forum posts
24 photos
Norman,
OK yes. That one I can fix (done now) so should work on all of them for the desktop.
Thanks for flagging it up. I'm still trying to get my head around making this forum software work the way I want.
Matt
Michael Gilligan25/02/2014 09:21:32
23121 forum posts
1360 photos
Posted by Matt C Beech on 25/02/2014 08:58:11:
... flash picture gallery does not load.
Thanks, Matt
That explains it ...
As you probably know, iOS devices don't do Flash.
ega25/02/2014 11:05:03
2805 forum posts
219 photos
Matt's excellent pictures don't appear on my Android tablet, either but my Flash-enabled Windows 7 machine shows them.
More power to his elbow!
Ian S C25/02/2014 11:55:25
7468 forum posts
230 photos
Matt, I can't get your photo album photos, or the photos you have posted to this site, have you actually posted any photos to an album. When you try, reduce them to something like 640 x 480 and you should get results.
Ian S C
Matt C Beech25/02/2014 15:15:37
50 forum posts
24 photos
OK - done a bit of digging, and I'll try and post links to picture albums directly too. I am not using the built in forum albums since all my pics are automatically uploaded by my phone, and if I can link to them it is much easier.
Part 0 - Strip Down
Part 1 - Headstock Spindle Disassembly
Part 2 - Derusting the Backgear
Part 3 - Headstock Castings Clean up
Part 4 - Cleaning the Oilers (and advice needed)
Edited By Matt C Beech on 25/02/2014 15:15:56
Michael Gilligan25/02/2014 16:53:04
23121 forum posts
1360 photos
Matt,
That works fine, thanks.
P.S.   It looks like you are getting decent results from the modern Nitromors ... I thought it might be too "planet friendly" to work.
Edited By Michael Gilligan on 25/02/2014 16:57:45
NJH25/02/2014 17:32:37
2314 forum posts
139 photos
Matt
I have sent you a personal message - just log in and go to In Box at the top of the page.
N
Edited By NJH on 25/02/2014 17:33:16
Bazyle25/02/2014 23:06:56
6956 forum posts
229 photos
Even worse bit of geekware. Just get some sort of google sign in and commits the cardinal sin of screwing up the 'back' button.sad Luckily don't do Myfords so not too bothered.
Matt C Beech26/02/2014 00:09:27
50 forum posts
24 photos
OK - done a bit more sorting after a lot of feedback on my photos. Sorry folks - you can tell I'm a bit of a noobie on this. Here are the links again - I think they all work this time, since I've put them on a public feed.
Full list of photos as I update them.
Part 0 - Strip Down
