Buying a Graham Meek Saddle Hand wheel Dial
WorkshopPete | 24/02/2014 16:19:50 |
87 forum posts | Hi All After a lot of time on various sites I have have managed to find a supplier of the Graham Meek design Myford Saddle hand wheel design. Apparently Hemingway kits did them for a while but have now stopped. The company Steve Tracey Tooling tel. 07952-547002. Talking to Steve he told me that he had agreed a design purchase from Graham Meek and has gone into limited production of both an imperial and metric version. I transfered the money £140.00 on Saturday evening and received my dial today (Monday) with excellent communications all the way. The Dial was double boxed in custom boxes and well packed with a very very comprehensive set of instructions. the quality is excellent and will look to be an original part of the lathe not an add on. I have no connection with Steve Tracey tooling other than a very satisfied customer. |
JasonB | 24/02/2014 16:45:17 |
![]() 25215 forum posts 3105 photos 1 articles | Could have just looked on this site, Steves version has been mentioned several times such as here Steve is also a forum member J Edited By JasonB on 24/02/2014 16:47:10 |
WorkshopPete | 26/02/2014 14:13:57 |
87 forum posts | Hi Jason yes that would have been easy but I could not find a thread to start looking this is always a problem with all forums but thanks anyway.
john fletcher 1 | 26/02/2014 17:30:30 |
893 forum posts | I am also satified customer, a useful add on to my lathe. I wonder why Myford didn'y fit them to the lathes when they were brand new ? Ted |
Steamer1915 | 26/02/2014 18:38:10 |
![]() 171 forum posts 42 photos | Hello Peter, Thank you for your kind comments, I hope the dial gives you good service.
Gray, I think that your offer being declined is typical of how "head in the sand" the original Myford became in its final years and I can't help but think that this attitude contributed their eventual demise. Even when they took a lathe that was fitted with one of your dials in PX against a new one, the dial was removed and left languishing in their stores. I know this because the "New" Myford owners approached me at an exhibition and asked if I had made the dials for the original Myford. When I replied that no one had made them for Myford, the retort was "They must have done, because we found versions of the dial in the stores". I pointed out the scenario as laid out above and nothing more was said. I understand that you made about 500 units over the years, and my own sales have been far more than I had been expecting. Best regards, Steve. |
Bazyle | 26/02/2014 21:19:53 |
![]() 6956 forum posts 229 photos | But would people have paid another £30 for an already expensive machine for a feature that while desirable is patently non essential. By not fitting it they opened the door to an add-on market that clearly does suit people to add when they can afford it. |
John Stevenson | 26/02/2014 21:50:32 |
![]() 5068 forum posts 3 photos | They could have don't it at no extra cost apart from the dial to go over an existing handwheel.
I have one here that works this way, just a standard handwheel, nothing special. |
WorkshopPete | 26/02/2014 22:44:22 |
87 forum posts | I suspect that towards the end Myford were in a desperate state old plant |
Trevor Drabble | 26/02/2014 23:04:24 |
![]() 339 forum posts 7 photos | When I purchased my reconditioned S7B from Myfords, it came with one of Graham's dials fitted , and as far as I am concerned, it is an excellent and indispensible piece of equipment . In actual fact , it was because of the dial that I chose this machine in preference to the other similar ones available at the time . Edited By Trevor Drabble on 26/02/2014 23:05:15 |
Steamer1915 | 27/02/2014 06:50:31 |
![]() 171 forum posts 42 photos | Hello Trevor, That is interesting. I was always under the impression that they only reconditioned lathes to a standard spec. I stand corrected. I believe that there is an analogy with using a Myford lathe with or without a gearbox. Whilst it is perfectly acceptable to use a changewheel model, once the gearbox option is taken, the user will wonder how they ever managed without it. Mr Fletcher, I think I met you at Harrogate? Glad to hear the dial is giving good service. Best regards, Steve. |
John Stevenson | 27/02/2014 09:59:00 |
![]() 5068 forum posts 3 photos | Posted by Steamer1915 on 27/02/2014 06:50:31: I believe that there is an analogy with using a Myford lathe with or without a gearbox. Whilst it is perfectly acceptable to use a changewheel model, once the gearbox option is taken, the user will wonder how they ever managed without it.
I strongly disagree with that statement having been there. When I had my ML7 I lusted after a gearbox for years, cursing every time I had to swap gears which was often.
Eventually I found a S/H box and fitted it, then bought the very expensive Myford Metric conversion kit and realised I had made the biggest mistake of my life.
Before what was a two minute job swapping gears, then became a ten minute job swapping gears and banjo only to have to swap back to get the fine feed back. I really cursed the day I fitted it.
It was only later I discovered the 33 / 34 gear trick that Brian Wood has recently wrote up in MEW that makes life a lot easier.
It's obviously that popular that Brian says RDG sold out in one day and I'm currently making another batch of 200 gears. |
Steamer1915 | 27/02/2014 11:56:06 |
![]() 171 forum posts 42 photos | Hello John, So to summarise, now that the 33/34 gear trick is widely known, the QC box is the better option? Best regards, Steve.
