watchmakers lathe plans
AussiePete11/02/2014 09:57:15
2 forum posts
Hi people I'm new here and already need help....
I was contemplating building a watchmakers lathe as I need some non engine projects and while searching for a possible lead I found an article which mentions such a project in Model Engineer August 1965 but cant find the plans (plan WE13) anywhere. Any help would be appreciated.
Pete
JasonB11/02/2014 10:39:58
Available from MyHobby Store
It did use a few iron castings and I don't think they are available now but you could cut from solid or fabricate
J
Edited By JasonB on 11/02/2014 10:51:13
Michael Gilligan11/02/2014 11:28:24
23121 forum posts
1360 photos
Pete,
Welcome aboard !!
If you are thinking of a traditional watchmaker's lathe [either Geneva Pattern, or Webster Whitcomb] then you have a tricky job ahead. The "proper" bearings are glass-hard, steel-on-steel, with a double cone shape.
If you just want to build a small lathe; have a look at the excellent book by L.C. Mason.
Edit: added hyperlink.
Edited By Michael Gilligan on 11/02/2014 11:32:32
David Clark 111/02/2014 12:10:01
3357 forum posts
112 photos
10 articles
Hi There
WE13 is still available from MyHobbyStore.
Two sheets but I don't know the price.
regards David
JasonB11/02/2014 12:19:19
Try clicking my link above for the price DCwink 2
John McNamara11/02/2014 12:19:27
1377 forum posts
133 photos
G'day AussiePete
Good to see ya.........and Welcom aboard.
If you are building a small lathe look out for a small granite or cast iron surface plate also a dial indicator and stand will help to check for parallelism and flatness. You should be able to scrape the bed to within a tenth or two.
john
Melbourne OZ
Edited By John McNamara on 11/02/2014 12:19:48
AussiePete11/02/2014 13:41:33
2 forum posts
Thanks for the quick responses guys. Jason thanks for the link I spread myself thin lol
Thanks John from Sth Oz hope the fires aren't too close to you. Yes I have those bits so looking forward to the project though not in 40+C days we are having for the last month...should drop to mid 30's by the weekend
Pete
Lars-G Kjellander11/02/2014 17:39:32
9 forum posts
4 photos
Hi AussiePete
Many years ago I was in the same situation thinking of building a small lathe. And at that time I found an article i M.E. Vol.150 No.3704 - Vol. 152 No.3730 (1983-84) - about a building project of: "A 2 5/8 in. Centre Lathe" - "A Design for Home Construction Using Stock Materials" by J. Neave. 2 5/8 in centre height, 1 1/2 in over cross slide, 9 1/2 in between centres 27in overall length, approx. 65 lbs weight.
I eventually ended up buying a Sherline lathe instead, much quicker, life is short and project list tooo long smiley
Lars
